Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-29-2009, 05:27 PM   #1
Send a message via Yahoo to WhiteMaxima9600
STARTER STUCK IN ENGINE......TRIED ALMOST EVERYTHING
Well today I'am officially perplexed on this situation! I swear i have been as calm as I could be while dealing with this with still no answer. If you have not read my other post basically this is the deal.
I replaced my starter with a reman unit, turned over fine the first 5-6 times then developed a slight grinding sound upon turning over. Problem got a little worse after bout a week or so. Finally one night it sounded like the teeth were not catching the flywheel correctly and it just barely started.
I removed both starter bolts and the starter just stayed in place!! I tried hammering it with a block of wood, prying with a small tool, prying with screwdrivers etc.. and it did not budge. Today decided to turn engine over with ratchet and it turns over in both directions smoothly no sound at all from starter or flywheel. Then I decided to take the starter apart while it was still on the car and the shaft inside is loose. So I don't think it's engaged to the flywheel.
What else is there for me to do??? Nothing I have mentioned has made any difference at all. I'ts still as tight to the housing as if it were still bolted down Im open to any suggestions as this has been going on for almost 2 weeks and Im ready to throw a match on it at this point
__________________
SHIFT_ RELIABLE
96 Pearl white GLE, 20% tint, 03 17" SE wheels, Carbon fiber dash kit, Custom spoiler, Tein S-tech springs,Tokico, 10"comp vr, 10" IDv.2 Fosgate 800 watt amp, pioneer head unit
WhiteMaxima9600 is offline   Reply With Quote
Old 10-29-2009, 05:37 PM   #2
take a pipe wrench and see it you can start to twist it
smai555 is offline   Reply With Quote
Old 10-29-2009, 06:21 PM   #3
Not really sure i want to to that. I would like to still be able to swap it out for a new one if i ever do get it out. Plus I just don't think it would be safe for the housing. The last thing i would want to do is break something other than the starter. Thanks
__________________
SHIFT_ RELIABLE
Old 10-29-2009, 08:03 PM   #4
spray penetrating oil?
where are you located?
Old 10-29-2009, 08:20 PM   #5
All I can imagine is that a flywheel or flex plate bolt loosened off. A bolt may have jammed the starter in place, or any other foreign object. Just a pipe dream, but not impossible. I would put the starter back together and try rocking it back and forth well prying on it. If you can't do that, the only thing to do would be to loosen the trans bolts a bit and anything that's in there will drop out.
Did you try starting it a few times with no bolts in it? I would. That should loosen up anything. It may damage things, so try at your own risk. Best of luck and keep us informed.
atomicplague is offline   Reply With Quote
Old 10-30-2009, 09:07 AM   #6
If the starter and the engine are not locked up/frozen I would expect the starter to turn when you apply power to it. Does the starter crank at all? You could install bolts and try applying power directly to the starter from the positive termimal of the battery see if it cranks. Not sure if that's going to help it get unstuck but can't think of much else other than prying it out or busting the starter apart to remove it.
This is one strange problem, I would expect that starter to practically fall out once the two bolts holding it are removed. I would expect that your pushing/hammering on it would get it loose.
One other thing, can you take apart/remove the small assembly on the starter that the power wire runs to. Maybe you can gat access to any stuck parts? There is a good parts diagram of the starter in the EL section of the FSM maybe that will help you.
Nopike is offline   Reply With Quote
Old 10-30-2009, 10:53 PM   #7
Yeah, I already tried to turn it over and it's like the starter is completly dead, it doesn't make a sound. I know the last time I changed it, it just fell out when i removed the bolts. It's the craziest thing Ive ever seen
Ive already took apart the starter and got down to these 3small little gears. I poped them out and there is a shaft that moves around freely inside so im assuming that it's not locked to the flywheel. I even turned the crank pulley and the gears don't turn at all on the starter assembly so it can't be frozen!
__________________
SHIFT_ RELIABLE
Old 10-31-2009, 04:29 PM   #8
Man.. Im starting to wonder if it would be easier just to do a 5speed swap. Looks like im gone half to drop the tranny just to get this S.O.B. out!!!
__________________
SHIFT_ RELIABLE
Old 10-31-2009, 05:36 PM   #9
have you tried prying with a pry bar or even hit the top of the starter and than lifting the bottomw with a pry bar, and doing the process a few times? 5 spd swap would require quite a bit to conveert
__________________
the Maxima parts man
maxfever1987 is offline   Reply With Quote
Old 10-31-2009, 05:38 PM   #10
why r you always caged
__________________
Old 10-31-2009, 06:23 PM   #11
Send a message via Yahoo to williamgd2
Since the starter is already dead spray the piss out of it with pb blaster penitrating oil and take a hammer of sledg hammer to it. it will come out
williamgd2 is offline   Reply With Quote
Old 10-31-2009, 08:10 PM   #12
Quote:
That may just be what it will come to, I have just been tryin to be careful not to break the trans. housing with all this prying and hammering. So.....as I have said before, YES, I have been prying (very hard) and YES I have been hammering from every angle with nothing moving. Hell I even took the thing apart and tryed hooking a piece of wire around the solenoid and prying the crap out of it towards the driver's side and it still won't won't budge.
I don't think that is caged Just my way of being careful I guess, I mean what good will it be to get the thing out but have busted up the transmission? Thanks for all the help again, btw the comment above about a 5-speed swap was a joke
__________________
SHIFT_ RELIABLE
Old 11-01-2009, 12:28 AM   #13
Send a message via AIM to HandsonMaxima.
i find myself glued to this thread to hear about what the problem is. everytime i see it at the top of the thread list. i find myself here wondering what youve done next!
also dropping the tranny seems to me like the best idea.
somehow a sledgehammer+allumin bellhousing is full of bad endings to me.
__________________
Mods;custom exhaust, DTM, 01VI,r34's, Shortram, BudgetY- black corners,blues, and no CEL.
Comming soon; nothing.
HandsonMaxima. is offline   Reply With Quote
Old 11-01-2009, 02:19 AM   #14
it there any chance that you have removed the Wrong bolt thinking they are the starter bolts? it might sound ridiculous but I am surprise that no one asked
Donald199 is offline   Reply With Quote
Old 11-01-2009, 09:10 AM   #15
you ever replaced a starter? its pretty obvious which bolts belong to it. but legitimate question to most other senerios, myself having made that mistake a few times.
__________________
Old 11-01-2009, 07:35 PM   #16
Quote:
OP had another thread going about this he has pictures to prove bolts are out.
Old 11-01-2009, 07:46 PM   #17
Oh, yeah the bolts are out. I JUST replaced this starter not a month ago. The old one just fell right out. I don't know what the crap happend with this one though. It looked exactly like the one I took out of it. Here's the pics, PROVING the bolts ARE OUT.
As you can see BOTH bolts are out, and the dam* thing is still just sitting there. Right now the whole back part of it is taken off (moter assembly, black part) and it still won't budge.
__________________
SHIFT_ RELIABLE
Old 11-01-2009, 08:08 PM   #18
OK, here's some updated pics of my starter taken apart somewhat. Sorry for the blurry pics. As you can see the inside has a ring gear and 3 small gears, behind that is a shaft with another gear (not in picture). I pulled out on the shaft and it moves back and forth about 1/2 inch or so. Does not seem to be binded up or anything??
__________________
SHIFT_ RELIABLE
Old 11-02-2009, 08:08 AM   #19
The starter gets ground thru the trans case. Is it possible the starter shorted out and has welded itself to the case?
__________________
'97 SE 5spd Super Black
FSTB, Addco RSB, K&N panel filter,
"4DSC" decals, AE shift knob.
Winter Mod - sand bag in the trunk
Curt Deiner is offline   Reply With Quote
Old 11-02-2009, 08:14 AM   #20
Quote:
Unlikely, but even if that happened it would be a very small/poor weld, easy to break off. Good suggestion anyways.
Old 11-02-2009, 11:46 AM   #21
Ya know I thought that myself But as much as ive pryed you would think a small weld would break. My real problem is.... I just can't get enough outward pry on it, I can pry up, down, sideways but not outward the way I really need to pull. I hooked a wire around it but it snapped before i could really pry on it. I used the motor mount as a pry point and pulled towards the fender. Any other suggestions?
__________________
SHIFT_ RELIABLE
Old 11-02-2009, 11:59 AM   #22
i really think you should drop your tranny before you break something expensive, just undo the bolts and drop it out, compared to the time youve spent its nothing.
after a day its what i would of done.
but i would have gotten a very heavy rod such as a post ram and pounded down on it. that ought to get enough force.
__________________
Old 11-02-2009, 12:36 PM   #23
a chisel or a really sharp putty knife?
Old 11-02-2009, 12:41 PM   #24
At some point you may just have to bite the bullet and destroy the starter. Maybe you can, very carefully, cut it off with a large Dremel like cut off tool. Or just keep taking the entire starter apart until all that is left is the flange that attaches it to the engine. Just a possible suggestion, I have not really taken a very close look at what you are up against.
Old 11-02-2009, 01:23 PM   #25
yo man...this been a problem for u for awhlie. What was the original issue again??? I forget.
I jus remember you performing a lot of maintenance on the car lol....
cashoit is offline   Reply With Quote
Old 11-02-2009, 01:38 PM   #26
Send a message via AIM to i2vicious2 Send a message via Yahoo to i2vicious2
try turning the crank pully w/ a 19mm socket to see if the teeth on the starter are stuck....
__________________
d2 coilovers, Qtp eletric cutout, OBXV2 3.5 Headers,
97-99 complete swap..(center console, front end, rear end)
VAFC, I30 Headrest...............
"i think i need a bigger box"
See me......
I2VICIOUS
i2vicious2 is offline   Reply With Quote
Old 11-02-2009, 01:54 PM   #27
Bolts back in lightly to get a decent ground, and then bump it?
Couldn't hurt, I guess.
__________________
LTB II, CAI, H&R, Illuminas, ES shifter, subframe, engine mounts, sway bar bushes, Megan OE-RE, Watkins STS.
SteveB123 is offline   Reply With Quote
Old 11-02-2009, 05:46 PM   #28
SLOW
Nealoc187's Avatar
Send a message via AIM to Nealoc187
I'd try what the guy above suggested, or just bang it with a hammer (preferably brass or copper hammer if you have one). Also try applying heat to the housing of the starter, you'd be surprised what a bit of heat can do to things that are otherwise seized.
__________________
95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto DR
3.5L swap with I/Y/E
12.92 @ 104 - 1.69 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
96 GXE - I/Y/E/MEVI/JWT ECU
13.42 @ 102 - 1.87 60' - M&H Slicks
13.82 @ 102 - 2.17 60' - Street tires
95 GXE - Stock winter beater
14.28 @ 95 - 2.07 60' - Street tires
High Flow Fuel Injectors
Injector Cleaning & Servicing
www.DeatschWerks.com
Nealoc187 is offline   Reply With Quote
Old 11-02-2009, 10:44 PM   #29
Already turned crank with ratchet, everything turned fine. Already tried to bump it over, starter is dead as a door nail. Already hammered, pryed etc.
__________________
SHIFT_ RELIABLE
Old 11-02-2009, 10:51 PM   #30
some C4?
__________________
1996 Nissan 240SX sold
1995 BMW 740 IL totaled
1995 Nissan Maxima SE sold
2005 Acura RSX type-s crashed
1995 Nissan 240SX blown engine
1997 Nissan Maxima GXE Current
and im just 18
whiteSE is offline   Reply With Quote
Old 11-04-2009, 02:44 PM   #31
Maybe the starter spline gear is stuck with the fly wheel? If you turn the engine over with the ratchet, do you see the starter three small gears move?
If you get really desperate, you could get a new starter and install half of it to the old starter that is still stuck on the engine and see if you can start the car (install the two big bolts first). This is a crazy idea so don't yell at me.
UncleMax98 is offline   Reply With Quote
Old 11-04-2009, 04:34 PM   #32
where have you hit it? i would try right above the hole(toward rear of the car) in a straight down motion to see if you can at least spin the starter
Old 11-04-2009, 04:50 PM   #33
wow i hope this doesnt happen to me. I replaced my starter with the same starter you have and it does make that quick grind noise upon turning over too. I hope it doesnt get stuck when it s***s out
__________________
'98 Infiniti I30t
Black on Black
So Many Mods
Bamfy98 is offline   Reply With Quote
Old 11-04-2009, 05:30 PM   #34
khantalha+'s Avatar
Send a message via MSN to khantalha+ Send a message via Yahoo to khantalha+
well i guess ur gonna have to take the tranny out and see if it slides out with the trans...
__________________
95 SE (VQ35DE EATER) - 96 GXE (Weekend Fun) - 98 GXE (Daily Driver/Grocery Getter) = sold
Quote:
Originally Posted by irish44j View Post
khantalha, in case you didn't see my other post - your signature is not appropriate for this forum and needs to be deleted. Please take care of it...
Lots of NEW/USED 4th Gen Parts , Click here, if dont see what ur looking for then PM me...
khantalha+ is offline   Reply With Quote
Old 11-04-2009, 06:36 PM   #35
I got someone to watch the gears when I turned it over and they did not turn so I don't guess it's on the flywheel, but who knows? I have been working like mad and have not had time to fool with it lately. The crazy idea u have just might work!
Does anyone know how I maybe could hook up the small starter motor to see if it tries to turn off the car? I'm just not sold that motor is burnt up
__________________
SHIFT_ RELIABLE
Old 11-04-2009, 08:31 PM   #36
imo, if you feel as though the starter motor is fine you could always try a volt meter.
have someone crank the car and if the volts go down it's a possiblity the starter is jammed.
__________________
1992 maxima SE auto 159k (r.i.p)
1992 maxima SXE 174k
1991 infiniti Q45 158k
1997 maxima SE 115K
1992maximase30 is offline   Reply With Quote
Old 11-06-2009, 01:52 PM   #37
khantalha+'s Avatar
any luck?
__________________
Old 11-08-2009, 05:43 PM   #38
Sledgehammer.
StickShiftV6 is offline   Reply With Quote
Old 11-08-2009, 10:04 PM   #39
i actually thought of that as soon as he said he had it taken apart.
+1 for thinking outside the box with me.
btw can people stop saying sledge hammer, hes not gonna do it and neither would you if it was your bellhousing at stake.
__________________
Old 11-09-2009, 12:29 AM   #40
Nah, to be honest I have yet to have a day off of work since halloween! So she's just been sitting there, it sux badly. Hopefully when im off this week, I can try some more. I'll keep ya posted with the results!
__________________
SHIFT_ RELIABLE
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
