Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-29-2009, 01:14 PM   #1
NEED HELP changing p1400 cod EGR SOLENOID VLAVE
For thosw who have changed the EGR SOLENOID VALVE, the green valve next to the intake manifold, how did you chane it?? i mean to ask is how did you change it since the 10mm bolt is underneath the valve. I know you can take off the upper intake manifold and try to reach it than but is there an easier way to do so??thank you.
__________________
the Maxima parts man
maxfever1987 is offline   Reply With Quote
Old 10-29-2009, 01:23 PM   #2
Get a 10mm flex head ratcheting wrench (the Gearwrench brand is available at Lowes, Sears, or Ace Hardware). Bend the head 90 degrees, cup it in the fingers of your left hand, slip in onto the nut, pull your hand out, and turn it. Have a magnetic pickup handy because you'll likely drop the nut once it comes off. You can also bend the little platform it's mounted on if you need to.
Anyway that's how I did it. There might be some other easy way, but I couldn't see any way to get a stubby wrench or a flex head ratchet and socket into that small space.
ATTappman is offline   Reply With Quote
Old 10-29-2009, 01:45 PM   #3
A crows foot wrench works just as well. It's basically just the head of an open-end wrench that fits on a socket extension. I found one at Sears for a few bucks a while back.
__________________
**If I can't fix it, it deserves to stay broke.**
DBear is offline   Reply With Quote
Old 10-29-2009, 02:22 PM   #4
ratcheting 10mm closed wrench. break the nut free, do the rest with ur fingers. use a panel popper to pry off the hoses easily. cakewalk.
Semper13 is offline   Reply With Quote
Old 10-29-2009, 04:42 PM   #5
i will try both methods, one of the has to work for me. thanks for the responses guys
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
