Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-27-2009, 08:39 PM   #1
ATTN: Lowered Maximas
My maxima is on Eibach prokit springs and konis. Im about to get an alignment. I've seen/heard about "special" alignment configurations in regards to lowered vehicles. FWIW I did notice uneven wear on my last pair of tires (inside was more worn than outside on the front tires) so does anyone have any ideas about what our specs are when lowered on this setup? Should i have the shop align the wheels to stock spec? or can does anyone have any specifics that i can request they follow....
Any help is appreciated.
__________________
SHIFT_Infinitely
Mods:
-Retrofitted Maxima HIDs
-20% tints including sunroof
-White climate control and stereo displays
-Painted grill with silver graphite paint, left infiniti symbol chrome (looks hott)
-Clear front signal markers and headlights.
-791XV with r/s and trunk pop
LOOKING FOR SIDE SKIRTS AND I35 GRILLE!!!
Nakulbhatt87 is offline   Reply With Quote
Old 10-27-2009, 09:18 PM   #2
i think you might need eibach camber bolts,
__________________
the Maxima parts man
maxfever1987 is offline   Reply With Quote
Old 10-27-2009, 09:26 PM   #3
Have them align it to stock specs. Or you can ask for -1* of camber.
__________________
00VI | 5.5Gen BBK | 00 5 spokes | Kumho Ecsta SPT | Cleared Tails | FX retro | LED interior | SNOMAX's LCAs | Raxles
FS: Plug and Play E-manage Ultimate, E-manage Blue & VAFC/SAFC Harnesses
Florida Gators: (11-0) | CSU (62-3) W | Troy (56-6) W | Tenn (23-13) W | Kentucky (41-7) W | LSU (13-3) W | Arkansas (23-20) W | Miss St (29-19) W | Georgia (41-17) W | Vandy (27-3) W | SC (24-14) W | FIU (62-3) W | FSU
MOHFpro90 is offline   Reply With Quote
Old 10-27-2009, 09:56 PM   #4
If the tires are wearing on the inside your camber is at a negative angle. To correct it you need to add camber so when they pull your specs find out the camber angles and have them adjusted. More than likely with a "smaller" drop like that of the eibach springs your looking at negative 1-1.5 degrees. I dont know that there is much you can do with a factory setup to adjust that but a camber kit will give you more range if needed. Keep in mind that if the wheels are much wider than stock then you will need to add more camber to prevent inner wear. The specs may show all in green (green= range of factory spec) but all tires have a different amount of contact patch and the wider they are the more contact is made on the inside.
(note once specs are green the tires are technically working the way they were designed to. Meaning if the major contact and grip patch is inside then thats where he major wear will be. But you can adjust to whatever you want it may effect the tires performance but if your not track racing idk if it will matter much)
Stretch21 is offline   Reply With Quote
Old 10-28-2009, 11:17 AM   #5
Send a message via AIM to njmaxseltd
You don't need a camber kit with Ebach springs. It's a mild drop.
When you lower a 4th gen the toe goes outward quite a bit. Thats what causes the inside of your tires to get chewed up pretty quick.
Have the toe set to spec and make sure camber is within spec. You can adjust camber slightly with the play in the lower strut bolt holes. Simply losen them, pull the top of the hub outwards to correct excessive negative camber. Make sure both sides are equal.
You can actually measure camber with a level if your mechanical enough. You can even check and set the toe on our cars with a tape measure and two pieces of nice straight one inch pine trim. Plenty of room under our cars to draw a straight line between the front and rear of our front wheels. Get 1/8 to 1/16 inch toe in and your good to go.
__________________
As the 4th gen ages, its owners get younger.
njmaxseltd is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
