Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-26-2009, 06:21 PM   #1
Air Conditioning Problem - How to Test if Clutch or Compressor is the problem?
So my air conditioning, which I do not use regularly, only puts out warm air now. After searching a bunch of threads, I tried listening to hear if the clutch turns on, but do not hear anything. I took it to a place to recharge, and those guys told me it was charged - 100psi on the high side, and 40psi on the low side.
How would I check if the clutch and/or compressor is seized? Ease the tension on the belt (how?) and then try to spin the clutch?
I am a relative noobie to any of the inner engine workings. I understand how the engine works, but have only replaced oil/spark plugs and simple things. Any help (pictures?) would be appreciated.
Thanks.
__________________
1999 Maxima SE 5 speed - Silver
Mods? Typical stuff - Eibach, Stillen, Budget Y, 5Zigens....Check my homepage if you're curious.
triax37 is offline   Reply With Quote
Old 10-27-2009, 08:15 AM   #2
Send a message via AIM to njmaxseltd
Quote:
Those numbers don't make sense. Take it to a different mechanic.
If the system isn't running, static pressures should be equal on high and low sides. If its' running, 40 is to high on the low side and 100 is to low on the high side. Again, those numbers don't make sense.
njmaxseltd is offline   Reply With Quote
Old 10-28-2009, 07:20 AM   #3
If I remember correctly, when the compressor is running, the low side s/b about 25, and the high closer to 200 (actual readings depend on ambient temperature). I would take it to a qualified A/C shop, guesswork on this kind of problem leads to nothing but frustration (speaking from experience)....
slfalco is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
