4th Generation Maxima (1995-1999)Visit the 4th Generation forum to ask specific questions or find out more about the 4th Generation Maxima.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Hi boys, ever since I did the 9007 mod, I've been getting flashed the high beams occasionally. I think with the different beam pattern, I need to aim them down a bit. I did look in the " How To" section, but couldn't find how to aim them down a tad. I think it's one of the long screw things you turn to adjust. But which one aims up and down and which one aims left and right? Thanks in advance for the quick answer.
Jeff
Hi, well I have been testing them out for a week now and I'm getting flashed by oncoming traffic. The different beam pattern must be higher. The light is much better, but don't want to blind anyone.
Parked in front of a wall or garage and try to aim
but good luck bro, i don't think aiming the beam pattern what's wrong
its that freaking glare, its like all this idiot's with HID kits and no projectors
When I did the 9007 on my max, I had to aim the headlights down a tad. They were aimed up a bit because of the different bulbs. Shine the lights at a wall straight on when you are parked about 20-30 feet away and use the adjusters to aim them down a bit.
Update: I went to the place I get my inspection sticker and he told me to pull into the inspection bay and line up the lights on the board. From what he told me, they're exactly where they should be to the inch. He said that the occasional flashing I'm getting from on coming traffic is probably because they're bright, not because they're out of alignment. So I guess these fart knockers who are flashing me are just gonna have to deal, because there are a lot more brighter and blinding headlights out there compared to my 9007's.
Been a LONG time since I've heard that phrase.
__________________ 1996 Maxima GXE "My boy blue"
TS ECU|RSB|FSTB|Leather/Heated Seats|12"sub-Alpines-Rainbow SLCs-Audison SRx2|Spoiler|5.5 Gen 17's|Custom Red Clears|Viper 771|R34 TSX Retro|5th gen muffler|300zx Fuel filter
Quote:
Originally Posted by pmohr
Oh I'll show you a dingy. A reaaaaaaaaaaal small one.
I tried this modification. Although many will say otherwise, the beam pattern from the 9007 is not suitable for the 4th gen housing, it was designed for a 9004 headlight.
did you find out which screw aims the Headlights Downwards?
i don't know wtf you're talking about the the beam pattern is the SAME. You're not changing the reflective housing, you're just amping up the light output.
I don't have a problem with my head lights. I did have to lower them a bit, but i never get flashed or complaints, even when driving behind friends.
__________________ Paying a man to work on your car is like paying another man to sleep with your wife.
-Hank Hill
99 SE-L - 00vi - Y/E
orientation of the filaments, my son.
__________________ SHIFT_no bailout.
A32. QN0. 5MT. FTW.
Current mods.
JVC HU. | 35% tint. | Blackout center caps. | Indy fogs. | Blackout Maxima badge. | Custom blackout SE badge. | Clear bumper lights. | A33 OEM clutch. | HTP MAF adapter, AMSoil cone filter. | NGK Iridium spark plugs. | eBay FSTB. | WarpSpeed y-pipe. | White & bright clock. | Custom 2.5" b-pipe. | Custom G20 sidemarkers. | E46 Bi-X, 6K D2S. | Thrush glasspack. | Magnaflow muffler. | Full tank of 93 octane.
You can't be wrong and strong at the same time.
__________________
50 Watt Ballast + 85122 = Six Lanes of Daylight!!!!!!
To the OP, the reason your getting flashed is because of the glare or scattered light that makes your lights appear brighter to YOU but also shines in on comming traffic's line of sight. In fact you are causing a hazard to other drivers on the road.
The 9007 conversion put the light output axis 90 degrees off, which distroys the already poor beam pattern of your headlights.
Hey, I've dinking with those adjustment screws to see which way to aim them down a bit and they won't move. It appears I can use a philips screwdriver or a wrench?
1993 Maxima GXE Super White, Ebay FSTB, 97-99 SE Rims, KYB GR2s, BlehmCo Lower Tiebar, BlehmCo parallel link kit, RSTB, BlehmCo swaybar links,Rear Addco swaybar, z31 rear disc upgrade, Assurance TripleTreds.
1995 Maxima GXE-5 Dark Blue Pearl , 00-01 SE RIMs, I30 leather w/rear headrests, No rubber- all ES Poly in front end suspension, Pioneer InDash Navi, Kzoosho LED tails and FX35 HID retrofit
Hi, I got it. I just aimed them down a bit. I will go for a drive soon when its dark and check the aim on the road.
Thanks for your help, I wasn't looking at the correct adjustment screw. Duh!!
