Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-25-2009, 01:09 AM   #1
weird isssue can even title this right, help me please.
okay so my car is having a weird issue. i go in and start the car and it didn't want to start. i kept turning it over and it would hesitate finally it turned on and then it shut off then again i turned it over and it turned on again this time it stayed on, but then when i would accelerate it it wanted to shut off again i let go of the gas and it stayed on. i then went and pop the hood and started turning the tb knob and every time i would turn the tb knob the car wanted to shut off when the air was going in. so i left it alone. came back from work right now and again kept trying to start it and it wouldnt turn finally it did let it sit for 2 minutes and next thing i hear is a whine out of no where pulley or belt area also the injectors were clicking super fast and loud. the car moved when i put it on drive but not stepping on the gas when i would try to step on the gas it wanted to shut off but the car will stay on i turned on the a/c and it stayed on. what can it be it bugged me all day i need help fast please.
Mod wise only the hack box and its never given me a problem.
Nismo32 is offline   Reply With Quote
Old 10-25-2009, 03:55 AM   #2
The Dirty Pearl
pmohr's Avatar
What is a 'TB knob'?
So...codes?
What is the idle at?
'Turning over' is most commonly interpreted as starting, not cranking.
It is misfiring, or just hesitating?
Did you do anything, have anything done, or did anything happen to the car immediately prior to this happening?
__________________
Quote:
Originally Posted by 2damax View Post
This jerk is right so often I just search threads hoping he gets something wrong so I can catch him
Quote:
Originally Posted by kizzmyazz View Post
ok so what i found out is that because of the FMU, i dont need to get injectors because it will neutralize the oil pressure to prevent detotnation
FSMs | A32 CEL Decoder | Howto Videos
pmohr is offline   Reply With Quote
Old 10-25-2009, 07:53 AM   #3
nsnrider's Avatar
Send a message via Yahoo to nsnrider
sounds like you maf went out.
Your IACV might also be bad.
More things might be bad but we definitely need more info.
__________________
Sold my 2k3 Max.
nsnrider is offline   Reply With Quote
Old 10-25-2009, 07:54 AM   #4
nsnrider's Avatar
double post, sorry
__________________
Sold my 2k3 Max.
Old 10-25-2009, 10:51 AM   #5
Quote:
So...codes?
TB knob is that thing next to the TB with the cables on it for acceleration
idle is above 1000
it wont crank the first few times then it does and starts
it just hesitates and struggles and when i accelerate it, it sounds like something is blocking it.
only did the oil change but that was months ago, changed the VC gasket for the oil leak that i still have even after doing everything i was suppose to and last month i did the Hack box.
Codes havent checked that yet will check right now.
Old 10-25-2009, 11:28 AM   #6
okay okay so i tried to get the code and the cel stayed still wont give me anything. when i accelerate it wont pass 3k rpm it just wont go over it it hits around 2800 and comes back to 1000 also the fans are turning on when i turn the engine on it never did that before and there is a clicking noise from what sounds to be the injector in the back, ill post a video asap. can it be the fuel filter or the fuel pump???
Here are the videos
this is acceleration http://www.youtube.com/watch?v=qVhr9Ty3mXs
this the clocking noise http://www.youtube.com/watch?v=rSS4nO33qEI
Old 10-25-2009, 12:19 PM   #7
still wont let me check for codes i did the whole process and it wont flash
Old 10-25-2009, 12:39 PM   #8
if you can't go past 3000 rpm most likely your maf
as for the clicking sound, i'd say that's normal its just the injectors mine are loud as hell too.
eFLO is offline   Reply With Quote
Old 10-25-2009, 12:54 PM   #9
i was also reading on a honda site that it can also be a blockage in the exhaust. my cat conv is burned out and my flex pipe is cracked though... how can i check if its the MAF?
also on the first video what can be causing that rattle?
Old 10-25-2009, 09:37 PM   #10
I had the same thing happen to me. It turned out to be the Mass Airflow Sensor. Got it changed and the EGR went. Cleaned that out, and now it's working like a...well...a 13 year old car. On the '96 Max I pulled the 4400 code which is apparently interchangeable with the EGR and the MAF.
__________________
That is not dead which can eternal lie.
And with strange æons even death may die.
urbancityriot is offline   Reply With Quote
Old 10-26-2009, 10:10 AM   #11
Sounds pretty typical of a failed temp sensor as far as the starting.
asand1 is offline   Reply With Quote
Old 10-26-2009, 12:31 PM   #12
Do a search and try to clean the MAF and see if that helps. The IACV (idle air control valve) isnt that hard to replace. But it most likely will be better to replace with parts from the JY rather than ebay. I hear MAFs online arent too reliable
cashoit is offline   Reply With Quote
Old 10-26-2009, 12:46 PM   #13
MAF 413.28 WWW.TXNISSANPARTS.COM NEW PART ... I RECOMMEND JUNK YARD OR NEW .... REMAN IS JUNK
rcg9999 is offline   Reply With Quote
Old 10-26-2009, 01:13 PM   #14
[quote=Nismo32;7266376]okay okay so i tried to get the code and the cel stayed still wont give me anything. and there is a clicking noise from what sounds to be the injector in the back, /quote]
Just a wild guess, but could his cel be staying on an IAC clicking because his ecu srew is resting at the clockwise position??
Old 10-26-2009, 02:35 PM   #15
video http://www.youtube.com/watch?v=NaoqUJ9i12c
rattle and pop and still wont pass 3000 rpm. and leaking oil like a mofo still.
Old 10-26-2009, 02:40 PM   #16
i reset the ecu and tried to get the code again the light is still on i know i had the inhibitor code but even that wont flash the light stays still i disconnected the battery for 30 minutes went through every connection replugged it all connected the battery cell stilll on did the process of clockwise till you pass stop wait 2-3 sec then counterclockwise looked up at the dash and the CEL would not blink still
uploading another video on this one you'll hear a pop inside the engine.
Old 10-26-2009, 03:41 PM   #17
video with the pop http://www.youtube.com/watch?v=liq55PXcsoM
Old 10-26-2009, 09:40 PM   #18
Send a message via AIM to HandsonMaxima.
sounds to my kinda like your ecu is shot? injectors clicking like mad because there stuck in "start mode" trying to find a pattern?
__________________
Mods;custom exhaust, DTM, 01VI,r34's, Shortram, BudgetY- black corners,blues, and no CEL.
Comming soon; nothing.
HandsonMaxima. is offline   Reply With Quote
Old 10-27-2009, 12:04 PM   #19
okay so today i went and got a mechanic to check it out he had the code reader o?d? II and it would not give him a code the CEL was on he ran the machine and it just said ERROR.
Old 10-27-2009, 12:20 PM   #20
So he couldnt pull any codes or anything??
Might need a new ECU bro
Old 10-27-2009, 01:09 PM   #21
Is your ecu screw all the way to the left where it should be??
Old 10-27-2009, 05:37 PM   #22
Quote:
yes the screw is all the way to where its suppose to be
Old 10-27-2009, 10:47 PM   #23
wow, i was actually right, blown ecu.
__________________
Old 10-28-2009, 10:24 AM   #24
okay so its not the ecu or else the car wouldnt start right? found out its the MAF so ill clean it and go from there and then found out it was the timing chain great meaning switching the water pump also. total cost with labor is 600-700 almost the same as getting another engine DE or maybe DE-K?? what path should i take... and what was that website where you can buy engines from???
Old 10-28-2009, 12:39 PM   #25
The Dirty Pearl
pmohr's Avatar
Just because it starts and drives doesn't mean that the ECU isn't at fault.
How did you 'find out' that it's both the MAF and timing chain?
What website? Craigslist? eBay?
There's a junkyard inventory site, but you can't buy anything from them. car-part.com
__________________
Old 10-28-2009, 12:51 PM   #26
the timing chain i know the rattle by the TC valve i had a 95 240sx se and that was the same rattle when my chain was messing up i mean it can be the TC tensioners not the actual chain itself. the MAF everyone keeps saying its that, i had 3 mechanics come check it out and they all say the reason it wont pass 3000 rpm is because of the MAF, i cleaned the MAF and the sensor and still having the issue, what else can be causing this issue can it just be the ECU that is causing all of this i really need help here. you've seen the videos i posted what else can it be that im missing. yea i was asking for that one car parts.com why cant i buy from there??? cant i call the locations it gives me and ask??
Old 10-28-2009, 12:55 PM   #27
The Dirty Pearl
pmohr's Avatar
If it rattles, it's the tensioner (or possibly one of the guides). The chances of the fault being with the chain on a VQ is...unlikely.
Have you actually tested the MAF and associated parts, or are you assuming that cleaning will fix it?
Actually no, I haven't seen the videos.
You can't buy from car-part because car-part doesn't sell anything. Again, it's just a search engine.
__________________
Old 10-28-2009, 01:11 PM   #28
I was gonna suggest earlier that the pop sounded like backfire from valve timing being off and the ratle sounded like valve/piston interferance. If the chain sounds loose that would add to the liklyhood.
Old 10-28-2009, 02:45 PM   #29
no i have not tested the MAF. dont have a voltage reader, some say by cleaning it might help but it didnt.
okay but i can call the places it says on car-part that have the engine right? or no?
the pop was a backfire the mechanic said the clicking noise (not the rattle) might be a valve or a spring in the front.
i am going back and forth deciding whether to spend any more money on this engine which has 216,723 miles on it or go for another engine with less miles and maybe less problems.
Old 10-28-2009, 04:53 PM   #30
so i just had a real mechanic come over lol. he said to double check the fuses, check the ground on the ecu and that the problem will rely on the MAF sensor. so i need to check that and order a MAF great.
Old 10-28-2009, 04:54 PM   #31
The Dirty Pearl
pmohr's Avatar
Again, testing components before replacing them actually helps sometimes. But you know, minor details.
You're going to buy a new MAF, but can't spring the $5 for a cheap multimeter?
__________________
Old 10-28-2009, 06:34 PM   #32
You should do a compression test to eliminate the possibility of mechanical failure, ie broken valve spring or skipped tooth.
Old 10-28-2009, 06:51 PM   #33
wooo wooo wooo who said anything about new??? i dont even have the money. i just said i dont have a voltage meter not that i cant afford one.
Old 10-28-2009, 06:57 PM   #34
The Dirty Pearl
pmohr's Avatar
New meaning new to you.
Then get a multimeter, and actually do some further diagnostics before just replacing the MAF to see if it fixes the problem. This is only if you mind throwing away money, that is. Otherwise, carry on.
__________________
Old 10-28-2009, 07:09 PM   #35
i dont understand this How do you test a MAF sensor
can someone newbie this up for me to understand??
also can it be the ground on the ECU that might be causing me not to read the codes or is it straight out blown???
got the digital meter reader thing now what i do? where do i touch. what page of the fsm
Old 10-28-2009, 10:50 PM   #36
did you check the flux capacitor?
but really ...
set the meter to read dc volts
put the black stick on ground/neg term.
red stick as the instructions read
with each wire should show x amount of volts
Terminal 54 (wire color W), so the white wire engine warm and at idle should read 1.0-1.7V
At engine speed of 2,500 RPM, the signal should read 1.5-2.1V
Terminal 55 (B wire)brown wire is a ground and should not show voltage with the engine running.
Terminal 4 (W/B wire) white with brown stripis the ECCS relay with is a self shut off unit, and will actually change voltages. When the engine is just shut off, it will read 0-1V, but after a few seconds will read battery voltage ((11-14V).
Terminals 67 and 72 (wires both R)red wires is ECU power and will read battery voltage when the ignition is on.
you will want to stick the probe (red stick) in the back side of the connector(plug)
make sense?
smai555 is offline   Reply With Quote
Old 10-29-2009, 06:38 AM   #37
The Dirty Pearl
pmohr's Avatar
FWIW B is black, BR is brown;
__________________
Old 10-29-2009, 10:40 AM   #38
how the hell do i remove the ECU i cant get it out
Old 10-29-2009, 10:57 AM   #39
thanks for the correction
Old 10-29-2009, 07:18 PM   #40
The Dirty Pearl
pmohr's Avatar
I've found the easiest, but slightly more time consuming way is to remove the two 10mm head bolts, and slide the entire bracket, ECU, and wiring harness out at the same time.
Personally, I get at the bolts by taking out the center stack (radio, vents, clock, etc) and going straight from there to the two bolts, directly behind the HVAC plumbing. Takes ~10 minutes to do it that way.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
