4th Generation Maxima (1995-1999)Visit the 4th Generation forum to ask specific questions or find out more about the 4th Generation Maxima.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
I have a 97 SE with 134K miles. It has the OEM struts/shocks and springs. The suspension is feeling stiff, very stiff actually. I thought the suspension got softer over time but it feels like it is getting stiffer. Almost feel like there is no dampening at all. The dust boots are gone. When I replaced the axles last year I noticed the dust boots had separated and pretty much fallen off. Could there be a piece of dust boot stuck in the shaft giving it a stiffer ride?
Aside from the axles and the sway bar end links that were replaced last spring, the underside of the car is OEM.
Chances are it's no good anymore, especially if the car has spent most/all of it's life in MI (the roads aren't as smooth as let's say florida).
How stiff is stiff?
Unless your floating down the road slowly bouncing, your struts are fine. Unless its hurting your back and rattling your teeth, your probably imagining its worse than it is.
As far as clunks and the like, inspect it and replace strut mounts, bushings, and joints as needed.
It's only been in MI about 5 years or 30k miles.
Quote:
Originally Posted by asand1
How stiff is stiff?
It's not so much bone jarring but it is loud. Not like a clunk of anything but just a loud "bam" when the suspension compresses. I'm probably going to change out the suspension anyway.
I also have a very slight wobble at 5-10mph. Wheels are on tight, so I'm not sure why it wobbles. I wonder if something underneath is bent. Could a bent axle cause you to wobble? I put new axles on last year and the wobble started immediately after that.
did you get an alignment? checked for loose Tie rod ends? well.. wheels balanced? umm... make sure the tires aren't unevenly worn? i dunno, i can possible guess and safely say the lower control arms? I'm just naming everything i know that might contribute to it.. if i am missing anything please add on to my list. o_O hope this helps?
__________________
This was from Youtube.com immortal4942 (1 day ago)
I got an alignment last year. Wheels are balanced. Tires wear evenly.
One other thing I notice is at low speed coasting(about 5-10mph) I can feel a slight side to side wobble like a tire is loose or something but I made sure the lug nuts were tight. Even had the tire shop that put the tires on rotate and balance the tires again. Still same thing. Would a bent axle cause this? Worn wheel bearings? At highway speed I feel a light vibration like a wheel is out of balance but like I said, I had that checked. There is no noise at all with this issue, it's just feel.
im not sure...but i was plannin on replacing the entire steering system: control arms, tie rods, rack and pinon, everythin. There is alot of stresses put on the steeriing from those hard takeoffs hehe
Someone mentioned the bounce test. Go to each corner of the car and push down. If it goes up and down more than once, more than likely the strut is blown. My car has the same mileage as yours and I noticed shaky behavior when cornering sometimes. I did the bounce test and the rear went up and down.
I replaced all 4 struts. Only the rears were blown, I could move the piston in and out with my fingertips. It made a huge difference replacing just the rears. When I did the fronts there really wasn't much of a noticeable difference in ride and handling. Replacing the blown ones though made a huge improvement.
__________________
White '97 SE 5 spd, all the goodies but auto (is that a goodie?) STOLEN : (
"I can feel a slight side to side wobble like a tire is loose or something"
Have a buddy follow you and watch to see if you have a bent rim.
"just a loud "bam" when the suspension compresses"
Sounds like a bad bushing. Does it sound like front or rear? Determine what corner its eminating from and inspect. Pay close attention to your LCA, strut/shock mounts, and rear axle pivots. Could also be your sway bar bushings, end links, or rear axle link.
this is how you know if your suspension is worn out:
__________________
Quote:
Originally Posted by nalc
RWD = fun? Yeah, maybe if you only watch Fast and Furious Tokyo Drift.
Quote:
Originally Posted by nzelinsky
Is there any corvette's that are close power to a maxima? I saw one that didnt really seem fast it was a newer model, but not that new... I dont know any corvette models and it didnt have any badging so I couldnt tell what it was.
Quote:
Originally Posted by MinervaMaxxxima
Aaron, you're great.
Quote:
i will never tell him this in person but bigles' car is hawt
OEM suspension at that mileage? Sounds like you do need new struts/shocks. You should feel a huge improvement.
As far as the "wobble", have you considered your tires? You said the wobble started after you replaced your axles. Did you get new tires around that time? Could be a bad one, but sounds like something more mechanical... Not sure what a bent axle would feel like.
Have 97 Max with 176K. Just had to replace front strut mounts. Car was riding rough with banging feel in front previously. I had replaced the front struts at 108K with Monroe sensa tracs. Maybe the Monroes are tough on strut mounts. I also replaced back struts at 130K with Gabriels.
