ground wire points
Old 10-13-2009, 09:47 PM
3000vr4tt's Avatar
ground wire points
so i was installing ground wires on a friends max......and so i tryed following the same ground points that i have on my 3000gt vr4......only wires i have left are 2..which on my 3000gt were alternator to the frame...and tranny bolt to the battery..can anyone help with pics or anything to find these bolts or where they are located? or any other points to use...thanks guys
3000vr4tt is offline
Old 10-13-2009, 11:40 PM
fastisnothing's Avatar
http://forums.maxima.org/5th-generat...grade-how.html
http://forums.maxima.org/audio-elect...other-how.html
Known as "The Big Three"
Any other questions, try using the "Search " drop down triangle at the top of the forum.
Good Luck.
Anthony.
fastisnothing is offline
Old 10-14-2009, 11:48 PM
whiteSE's Avatar
another good one is where the starter bolts upt o the tranny
whiteSE is offline
Old 10-15-2009, 05:31 AM
Whatchyou say?
JtzMax's Avatar
I agree with the SEARCH ... this has been covered almost as many times as SeeFoam! * and NO, don't even ask what SeeFoam is ... how it works ... what it does ... or anything even close -
There's a Neg terminal on your battery, try that! You can use any place on the trans or the engine, find a spot and clean it well, strap your wire on and go.
JtzMax is offline
Old 10-16-2009, 01:40 PM
Sentientbydesig's Avatar
Pathetic grounding designs...
The negative battery terminal and factory grounding points are your friends. Add the transmission into the loop and you're done.
Sentientbydesig is offline
Old 10-22-2009, 11:50 AM
3000vr4tt's Avatar
i know what seafoam is..im not a noob wit cars...just this search features kinda hard to find s*** sometimes
Old 10-23-2009, 07:44 AM
Whatchyou say?
JtzMax's Avatar
LOL .... I hear ya man. Sometimes setting the 'priorities' at the bottom left can help. Also, hitting just the 4g forums is a plus too.
JtzMax is offline
pktaske
05-06-2016 07:49 AM
pktaske
09-04-2015 08:40 AM
Quick Reply: ground wire points
