Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-08-2009, 08:09 AM   #1
Strange headlight problem on 1995 Maxima no low beam on one side
I had this in the noob thread since 2 nights ago and brought that thread to a stand still...
My left headlight just went out the other day, I have high beams on both, but no low on the driver side. No cracks in the headlight lense whatsoever.
Here is a list of what I've found so far:
1. Daytime running lamps still work in this headlight
2. Removed and reseated bulb, no low beam.
3. Tried new bulb, no low beam.
4. Hi beams work on both headlights.
5. Connector is not melted, I'm using standard 9004 bulbs. Nothing fancy.
6. a test light shows there is power to the harness on the middle connector.
Any ideas? Relay prehaps? (memory tells me I had this issue on an old 91 sentra.....details are foggy)
lbrowne is offline   Reply With Quote
Old 10-08-2009, 08:25 AM   #2
Maxima.org, my g/f's nightmare
JtzMax's Avatar
Send a message via Yahoo to JtzMax
Odd .... it wouldn't be a realy issue if you're getting power to the connector. I'd say to try another bulb and clean the connector with some canned air or the like. Are you probing the backside of the connector? If so, probe the front so you know the pin is still ok (not loose and making poor connection). Are lights are postive switched (meaning that the 9004 bulb burns 2 different fillements, one for hi, one for low). So, in short - if you have power to the connector, you should have low beam output.
__________________
CAI, Test Pipe Cat, JDM N1 Cat back, FSTB, Aluminium dash kit, STS, Razo shift knob, Clear markers, CC mod, .ORG Stickers (bright blue), Blue LED switches / map lights, A6 Bi-Xenon retrofit, rebuilt 5spd - My write up --> http://forums.maxima.org/showthread....121&highlight=
JtzMax is offline   Reply With Quote
Old 10-08-2009, 08:51 AM   #3
Step three above indicates I tried a new bulb Fresh out of a package actually.
When I tested for power with the test light, I tested the front side of the harness where the light physically plugs into the bulb.
Definitely got me stumped so far.
Unless the new bulb is toast too! lol
Old 10-08-2009, 09:27 AM   #4
Swap the two bulbs. Just to make sure the new one works. It has happened before
__________________
Signature pictures are to be no larger than the allowed size of 550 x 325 pixels
tosheto is offline   Reply With Quote
Old 10-08-2009, 02:22 PM   #5
JtzMax's Avatar
Quote:
My point exactly
__________________
Old 10-08-2009, 02:36 PM   #6
There are three wires running to the headlight GRD-BLK, HI-Yellow, Lo-Green/Yellow.
Test for power to the LO terminal/wire. You can compare your readings to the passenger side to be sure.
Nopike is offline   Reply With Quote
Old 10-08-2009, 08:19 PM   #7
JtzMax's Avatar
He did test it .... that's the oddity of it. He's getting power, but no light output. That's why I think maybe it was a bad bulb out of the package, it's been known to happen.
I recall one time, I hung a new light (in the living room) but it wouldn't turn on. I checked everything (except the bulbs - of course) several times. Back and forth, atic, living room, atic, living room .... my g/f changed the bulbs from another fixture, worked fine. One of those ... DOH! moments. lol
__________________
Old 10-08-2009, 08:59 PM   #8
Since you have drl, it's probably the drl module near the coolant filler location. Some folks opened it up and retouch the solder joints to fix it.
gordonych is offline   Reply With Quote
Old 10-08-2009, 10:25 PM   #9
Haha I had a few headlights problems as well. One day I decided to try out Pilot Automotive headlight bulbs and after a few days the passenger side burned out and so I got them returned the the store gave me another set, same brand. And when I put it in, nothing happened on the same side, and when I put on my old Xtravisions it lit up, apparently the brand new bulb was defective before I even got to use it.
And so instead of returning the bulb I bought myself a cheap set of Xtravisions and digested angry and stupid feeling I had for using cheap bulbs.
Oh and one thing I noticed is that Xtravisions and bulbs from the same company that are "top notch" aren't any brighter than the other, I mean you can probably tell if you stare at your headlight beam long enough but other than that I didn't see any difference between the cheap Xtravisions and the $50 top notch silvania bulbs.
__________________
1997 Nissan Maxima GLE
Leo_Koneval is offline   Reply With Quote
Old 10-08-2009, 11:52 PM   #10
Send a message via AIM to FallenOne
Actually, my Silverstars are bright as hell. Ill get pics. ( please no. its cold.. )
FallenOne is offline   Reply With Quote
Old 10-09-2009, 01:38 AM   #11
Quote:
Really? I used them both and it doesn't seem to make a different at all, except for the price haha
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
