4th Generation Maxima (1995-1999)Visit the 4th Generation forum to ask specific questions or find out more about the 4th Generation Maxima.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
If you leave the egr solenoid and temp sensor plugged in and get rid of everything else, you won't get an egr code with a 95-96 ecu. As for the wiring and pin relocation, good luck...
__________________ 1996 5spd w/DE-K/HotShot headers/Apexi WS JWT Short Ram/VAFC2 KYB AGX/Eibach SportLine/97+ front end...
The EGR setup is totally different on the '99. The '99 has a 4 step motor to control the EGR.
I've been pretty lazy with respect to fixing my EGR problem although it seems like a fairly easy task. I could be wrong though
From the image above, Green goes to airbox post MAF. Pink goes to vacuum source and Blue goes to EGR valve. Pay close attention to the nipples on the egr valve that the hoses are attached to as the EGR function wont work correctly unless the hoses are connected to their respected nipples.
As for the wiring, you will need a pig tail from a 95-98 engine harness for the egr valve. Connect terminal 2 to ignition source, and terminal 1 should be pinned on the ECM at location 103.
__________________
Mods:| Cammed VQ35 | SSIM | HR springs | ARP rod bolts | OEM Nissan rwd head-gaskets | Budget Y-pipe and Catback | NWP Spacers | Dynomax Superturbo muffler | EdgeRacing Converter | Transgo Reprogramming Kit | Hayden Transmission Cooler | JWT Pop Charger | Emanage Ultimate | SSV4 | Innovate LC-1 WB | DR mod | ES motor mounts | ES x-member bushings | ES LCA bushings | Polyfilled tranny mount| 15" RX-7 BBS wheels (12lbs/rim) | Street tuned: 13.0 AFR, 7200 Rev limit, advanced timing |
Thanks!!! Got everything including pig tail. Getting pretty good at soldering!
Any idea if the '95 valve itself is a "direct bolt-on"?
but you're using the 95 ecu. If you get rid of all the egr stuff besides the solenoid and temp sensor, you won't have a problem. Just saying.
That's just it, the '99 has 4 pins for the EGR solenoid, '95 has one. To prove my point, I did exacted as you state and do have a code. The car drives fine, I just need to get rid of the code to pass yearly state emissions....
I would assume so but you can verify by comparing your 99 EGR setup to the one you acquired.
Also if you can just check the resistance between terminal 1 and 2 on the EGR valve....I wonder if you could use a resistor to fool the ECM....
I PM Ghetto EGR Relay Fix dude and he said the resistor wasn't reliable and still throw codes.... I'm not to sure why it wouldn't work if the connections are good. I may give it a shot.
This is my plan of attack now (might be plan b if the resistor doesn't work) I took the pin from the '99 fuel pump relay and spliced it to the EVAP canister control valve wire and put it in ECU pin 103. FSM states that it is wired the same as the '95 solenoid is. Now I need to verify the voltage. If all goes as planned I think it will be replace with the '95 solenoid and I can use the harness and swap out the plugs.
Make sense?
Yep. EVAP is wired exactly as you would need it for the EGR valve. Give it a shot and let us know how it went.
__________________
When you get a second can you look at the rear O2 wiring for '95 and '99? I switched pin 107 to 105 and still get a code. I'm thinking it's a grounding issue. The '99 O2 sensor is a four wire and is grounded by the fourth wire ('95 is three wire). The '95 O2 circuit is ground by pin 112 on the ECU.
You think I should ground pin 112 and see if it will work? I will need to disconnect the ground on the '99 O2 then, right?
If this doesn't work then I'll get a '95 O2 sensor...
Also, I'm getting a P1320 code, didn't have it on the '99 ECU so I'm going to double check the CKPS REF pins. Any other ideas? Because, I'm 99% sure the pins are correct.
Again THANKS MAN!!!
Are you getting P0136?
I'm actually running an O2 sim in the rear and havent had a code. You can try and ground pin 112 to any other ground wire in the harness that is grounded through the intake manifold bolts. If this gets rid of your code, I'll update the writeup.
__________________
Yeap, P0136... I'll give the ground a shot and let you know.
