Rack & Pinion leak
Hi,
I have a 97, Maxima GLE with 133k miles on it. Recently I started hearing sound when I take out the car in the morning. Its more pronounced when I turn (and turn left I believe). I do hear some noise when I turn right as well (not as much as left). Its there for about 5 min and then it goes away. I took it to mechanic. He lifted it and showed me the problem. The Rack & Pinion Bellow is fully torn and the power steering fluid reservoir is below min level. His recommendation is to change the R&P completely which is about $500. I asked the guy few questions and wanted to check with you guys so he is not screwing me.
Q: What happens if I dont change R&P?
A: The PS pump will be damaged (which is more expensive to change). The state inspection will not pass (I am due on state inspection).
Q: Does the R&P has to be changed fully? Can just the Bellow be changed to fix the problem?
A: No the full R&P needs to be changed. Changing the Bellow will not fix the problem.
Please give me ideas to do the sensible thing here.
Thanks!
