4th Generation Maxima (1995-1999)Visit the 4th Generation forum to ask specific questions or find out more about the 4th Generation Maxima.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Does anyone have a recent how to on replacing the alternator? After searching, the only thing I run into is links to Motorvate.ca which, on my computer, does not function. Thanks
Run a search for username PMOHR. He has a link in his sig for FSM's. Use one of those.
__________________
SS Headers and Y-pipe, Random Tech Cat, Megan Racing Catback, Eibach Pro Kit (garbage with blown struts ), 2nd gen Altima SE 17" Wheels
I don't know what you are trying to do, but when I was doing my alternator two weeks ago...I just unscrewed the bolts holding the compressor in. I let it dangle and it moved from side to side nicely giving me enough space to yank the alternator out.
If you remove it, you will have to recharge your system.
So basically, what I did for the alt:
- Loosen belts - 12 or 14mm socket?
- Remove belt pulley that is below the adjuster (little one) - 12mm socket I believe
- Remove four bolts holding the compressor in (2 on top and two on bottom - from the front of the car) - I believe these were 14mm.
This should give you the ability to move the compressor around a bit. Maybe what you need.
Do you have a Haynes manual? Just look at that for the bolt locations of the alt. I can scan it later tonight if you want, but it's all in there. It's not very hard, but I had power tools so...
Yea, I have the manual. But sometimes the guys on this forum come up with different ways to do things. The knock sensor is one example. If you go by the manual, you'll be removing the intake manifold.
Use the manual. I just don't know how to explain the bolt positions to you. lol.
But to remove the compressor, do what I did above. VSamoylov (banned member on here) gave me the idea of just detaching the compressor so it wiggles around. I was planning to drop the whole thing. lol.
this is a moderately difficult fix, but worth it if you stick with it. shops will charge 2hrs labor for this.
You have to be careful when removing the radiator fan shroud, it's fragile. As Ilyak said, moving, not removing, the AC condensor is the way to go; Even so, I recall having just barely enough room to remove/replace the alternator unit, and it being a pita each time.
Be wary of the special nut that attaches the alty to the block (it is the one closer to the firewall,has a flange). torque it to spec, trust me you don't want it to come off down the road, as you won't notice until it's too late.
the motorvate site has been down for a while. It offers little beyond what's available here from pmohr and Ilyak, except an extra pic or 2.
