4th Generation Maxima (1995-1999)Visit the 4th Generation forum to ask specific questions or find out more about the 4th Generation Maxima.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
99 calispec with abs
well got my 300zx filter, my stubby screwdriver, pliers and a can of wd40.
pulled the fuelpump fuse, cranked 6-7 times popped the filter out of the bracket. but can'tget that damn screw-clamp off. the screw won't budge and its cramped as hell.
any tips?
thanks
Just soak it good w wd40, loosen the screw alot, and pry it off w a screw driver. I did mine w a pair of pliers and a screwdriver in a church parking lot lol.
any tips?
thanks
You can't get the screw clamp off? Or you can't get the screw clamp to move at all?
__________________ 1996 Maxima GXE "My boy blue"
TS ECU|RSB|FSTB|Leather/Heated Seats|12"sub-Alpines-Rainbow SLCs-Audison SRx2|Spoiler|5.5 Gen 17's|Custom Red Clears|Viper 771|R34 TSX Retro|5th gen muffler|300zx Fuel filter
Quote:
Originally Posted by pmohr
Oh I'll show you a dingy. A reaaaaaaaaaaal small one.
..it's on there pretty tight lol..there's hardly any space to work with. i'll give it another go later otherwise i'll just ask my mechanic to swap it for me when i go for an oil change.
Did you use the wd-40 on it? Is it rusted, or just really tight?
this is fuel man ....beware of any heat saurce near by
As long as he doesn't touch the metal hairdryer grate to the fuel he should be fine. Even then i kinda doubt it'd get that hot to ignite the fuel.
it's more like i can't really get my hand in there to hold the filter well while i try to turn the screwdriver, so i cant really apply much force. but it is pretty damn stuck
Surely you can't be serious. You act like I recommended a blowtorch or a heatgun. You do realize just how hot the fuel gets going through the fuel rail...
__________________
99 Max SE 5 spd, SC'd, MEVI, Cattman Headers, LED tails, R34's with S2000 projectors, 13.1" Brembo BBK, EU.....381 HP/323 TQ
Why is the Maxima fuel filter so hard to get the hoses off? It makes no sense at all! Every other vehicle I own is very simple! Even my Pathfinder (which has the same basic filter as the Max) the hoses come off easy. Hands down the Maxima fuel hoses are the worst to remove!
is damn hard to take if off there's so much pressure inside i can't take it off my cousin did it for me.
Well you must remove the pressure, but even with doing that it is still almost impossible to remove the hoses. The fastest way to remove the pressure is to pull the fuel pump fuse, and let the car run out of gas, and also open the gas cap. It is just so odd to me that the Max is so hard.
I couldn't figure out how to change mine with the cramped space either, I doubt I would've ever figured it out if my friend didn't do it for me. He took off the Air Filter housing, along with everything attached to it including the Mass Airflow and whatever that box is called after it up until the hose that is clamped down to the engine. Once that was out of the way it took a few minutes to replace it. Most of the time spent was taking off/putting back on the air filter housing, and that he was showing me what he was doing. I too put in a 300zx fuel filter. Some fuel did spill out cause I didn't depressurize it, actually it kind of shot out. If you did what I did make sure you dont aim it at your face and you'll be fine. I never used wd40 when I did this.
I don't have ABS on my 96' so I'm not sure how much difference there is when changing the filter.
Take the intake tubes out from the TB to the air box. This will give you more room to get your hands down around the fuel filter. Also, a warm engine compartment will make the hoses softer and easier to work with.
__________________
As the 4th gen ages, its owners get younger.
well, you guys may think i'm crazy but that damn screw will not budge and i've rounded it a little so the screwdriver barely catches on it anymore. weird that it's on so tight.
i notice there is also a screw clamp on the hose further down where my finger is touching, so i tried turning that one and it is WAY easier to undo. so can i remove that clamp and pull the filter up to me and try to get it loosened?
I used a flat screw driver to wedge up the barb while I twist/wiggle the hose off. The hose was on crazy tight with very little room to use two hands. When that PITA filter finally came off I threw my hands up like Rocky Bolboa splashing gasoline everywhere.
There is a hose puller tool that may be used, but I have never attempted to use it. Does anyone have any info, on this tye of tool, or where to get it?
Thanks,
Zack
For a good homemade hose grabber tool, get a cheap pair of slip-joint pliars (linemans pliers or even a pair of longnose visegips might work) and hold a grinder to roughly take out a round section at the top about the size of a sharpie marker. I've used hose pinchers and other grabbers, and these prove to have the most control/versatility - and are the cheapest.
I originally found an ancient set of pliars fitting this description in my old mans toolbox, I unsuccessfully tried to find them in stores (because he wouldn't give them to me) - only to realize upon closer examination that they were 'modded' pliers - so I made my own.
It would look something like this (photochopped), but the tip would be wider/have more contact surface so as not to damage rubber hoses while twisting/pulling.
