4th Generation Maxima (1995-1999)Visit the 4th Generation forum to ask specific questions or find out more about the 4th Generation Maxima.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
So the battery light is on, i just put in a new alternator but that didn't fix the light, i checked all the fuses. The car when running generates 14.8 Volts and when i turn things on (CD player, air) it drops to 13 something.
any ideas? the battery itself is new.
The break light is also on, the hand brake is down, and there is plenty of brake fluid.
also i noticed the air control back light is flickering at times. ... i hope it's not a short somewhere.
I know you said you checked all the fuses...but just to make sure, check the battery fuse in the fuse box in the engine bay, driver's side.
Check/clean your main ground wire at the battery terminal and on the bell housing.
Do a load test. Turn on your lights/high beams, AC set to max, rear defroster on. Voltage should drop momentarily and then climb back up to around 14v.
__________________
Mods:| Cammed VQ35 | SSIM | HR springs | ARP rod bolts | OEM Nissan rwd head-gaskets | Budget Y-pipe and Catback | NWP Spacers | Dynomax Superturbo muffler | EdgeRacing Converter | Transgo Reprogramming Kit | Hayden Transmission Cooler | JWT Pop Charger | Emanage Ultimate | SSV4 | Innovate LC-1 WB | DR mod | ES motor mounts | ES x-member bushings | ES LCA bushings | Polyfilled tranny mount| 15" RX-7 BBS wheels (12lbs/rim) | Street tuned: 13.0 AFR, 7200 Rev limit, advanced timing |
1993 Maxima GXE Super White, Ebay FSTB, 97-99 SE Rims, KYB GR2s, BlehmCo Lower Tiebar, BlehmCo parallel link kit, RSTB, BlehmCo swaybar links,Rear Addco swaybar, z31 rear disc upgrade, Assurance TripleTreds.
1995 Maxima GXE-5 Dark Blue Pearl , 00-01 SE RIMs, I30 leather w/rear headrests, No rubber- all ES Poly in front end suspension, Pioneer InDash Navi, Kzoosho LED tails and FX35 HID retrofit
For those that do not know when the alternator output goes to zero the brake light and battery light does come on in Maximas... at least the 3rd and 4th gens that i've had.
