Heated seats + Heated Mirrors
Alright so did some searching and found a good 4-5 threads in regards to this topic one mainly struck me for being more informative but did not quite get the answer I'm looking for. I did not bump it as I just helped bump an older 5 year old thread minutes ago
Alright here's some info, I've got a 95 GXE that was prewired for one power seat after adding a certain fuse or relay far behind the kick panel almost near the firewall.
I worked at a junk yard for nearly a year and collected many goodies over that period of time but never got around to installing it all and now that its been a year since I got the parts and summer is almost over, I'm going crazy installing all these things within the past week or so.
Start reading from here if you dont wanna read a little background
1. I'd like to know if there's a plug and play harness you can get for the heated seats that will not require any splicing whatsoever as if the option came with the car. And yes I do have the switches for heat.
2. Same question as above is there a plug and play harness?...Just about 2 weeks ago there was a 96-98 i30 at the jy with the same paint code as my max(BM1) checked if the mirrors had two plugs and they did so I grabbed the mirrors hoping mine would too but mine isnt wired for it.
3. If there are no direct harnesses for plug and play for the mirrors, I'd have to run a wire or two from for each mirror coming from behind the defrost switch and dash through the door harness grommet and voila, correct? if so can someone enlighten me as to which wires I need to tap into?
4. As for the seats, if there's no direct harness, I've got the seats and switches..what would I need to tap into? I was reading in one of my searches about only into ACC sources but could use some confirmation.
Thanks in advance and sorry if there's a thread redundancy.
These 3 threads should help you tremedously with all your heated seats questions. I've checked, and all your heated seat questions have answers within. Now go read! LOL
http://forums.maxima.org/4th-generat...t-install.html
http://forums.maxima.org/4th-generat...s-install.html
http://forums.maxima.org/4th-generat...ted-seats.html
If you still have questions, feel free to ask here. Can't help with the mirrors, sorry.
op did you get your setas and stuff working yet? also since you have the switch dont expect them to light up when you turn the switch on, i thought it should light and went really crazy thinking i fried somethng up, but when in reality the swicth light goes bad quick
Nah dude, I've been so busy I haven't even read those threads posted earlier in this thread. Wait, did any of those even contain any info on how to wire the heated seats? if not maybe you can offer some guidance Its starting to get cold
My efforts/links were in vain.
Trust me read those threads, when i started to piece together this project there was one man who i relied on and it was The Wizard, he is the man. trust me when he posted to read those threads he was right abt it. I can only repeat what those threads say in them. Each one has very very useful info here is one more thread my personal one maybe this can add some more info
http://forums.maxima.org/4th-generat...-question.html
now i can hook up my heated seats...ive been putting it off for the past month...ive got all the switches but the wires are all hacked to hell..and ive had a tough time trying to decode them and plus im worried that ill goof up something...great post thanks guys
tarun900
19
12-20-2021 06:57 PM
