Gauge light issue
Old 09-08-2009, 06:28 PM
mtnbikeair's Avatar
Gauge light issue
My gauge lights stopped working the other day. I had to jump my car from my dads truck, dont know if that could have done it. But I have checked every fuse that seemed related, I know the dimmer isnt set down. So any ideas?
mtnbikeair is offline
Old 09-08-2009, 06:30 PM
MOHFpro90's Avatar
Bad dimmer possibly. Or a bad ground.
MOHFpro90 is offline
Old 09-08-2009, 07:11 PM
No more Maximas...
pmohr's Avatar
I've said it many times before, guess I'll say it again.
If you're having an electrical issue, you check EVERY fuse, not just the ones that 'seem relevant'.
So are we to assume that all of the other illumination controlled lights come on when you turn on the parking lights or headlights?
You say you 'know' that the dimmer switch isn't all the way down, but did you actually check it? Always check the simple things first, even if you 'know' they're not causing the problem.
Have you checked that you're getting illumination power at the cluster? Have you checked the ground? Bypassed the dimmer switch?
pmohr is offline
Old 09-09-2009, 10:20 AM
bharatiya's Avatar
I had same issue, it is due to Alty sending wrong Voltage. The very reason you may had to Jump start. My case was a higher voltage (as the sensor was busted) your might be other way around.
bharatiya is offline
Old 09-11-2009, 05:08 PM
mtnbikeair's Avatar
Thanks for the help, I took phmohr's advice ( it would be dumb not to) and checked all the fuses. I blew a tail light fuse under the hood and that caused all the problems.
xUNIxPanther
12-06-2020 09:08 PM
trasmadean
01-20-2018 05:05 AM
dr3am
25
10-22-2015 08:53 PM
homeyclaus
09-03-2015 06:15 PM
acw
08-13-2015 12:50 AM
Quick Reply: Gauge light issue
