Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 09-11-2009, 10:18 PM   #81
Quote:
Originally Posted by DJ420 View Post
Check out my sig.. that's 8000K in both headlights AND foglights. While retrofitting to projectors IS the best way to go about it, it is NOT necessary. The HIDs will perform better, and it will reduce/eliminate glare. However, if you do not retrofit, you can still use a plug n play kit.. I recommend aiming your gheadlights down evenly, so that the bulk of the light output is below the trunkline of a vehicle in front of you. There is always going to be stray glare, but you can keep it to a minimum this way!
Are retrofits the correct/best way to put HIDs in your ride, cosmetically/functionally? Yes.
Do you HAVE to retrofit in order to install HIDs in your headlights? No.
Are mine retrofitted? No.
Do I care what anyone thinks about it? NO.
I do plan to retrofit them in the future. I also plan to do LED tails, turns, and corners.
For your headlights, you need a 9004 Retrofit kit. For your fogs, you need a H3mini Retrofit kit. If you want to keep the functionality of your HI-beams, you will need a BI-Xenon kit. If lows are good enough for you, a single kit will do.
8000K=blue like mine. 10000K=darker blue. 3000K=yellow for fogs. 6000K=lighter than mine (almost white). 4300K=WHITE.
Don't let all the .org hard-asses get to you.. some people have nothing better to do! lol
I see that you are local, so PM sent..
Call me an ******* but anyone driving behind me with those lights usually get me behind them with high beams. What are they gonna do? Flash me? Only option is to shoot me but it is still worth the risk. I call it giving others a taste of your own medicine. I can usually see the beam reflecting off of their side mirrors to their faces, tinted or not ROFL.
EsQueue is offline   Reply With Quote
Old 09-12-2009, 05:00 PM   #82
Decal Specialist
erty67's Avatar
Send a message via AIM to erty67
believe it or not, DJ420's lights aren't that bad. Trust me, I see him in my rear view often I have the 9007 mod and I'm constantly getting beamed by oncoming drivers. I think mine produce more glare than his.
erty67 is offline   Reply With Quote
Old 09-12-2009, 07:29 PM   #83
Send a message via AIM to mightyMax95
Quote:
that's because the 9007 mod is bad, second only to drop in HIDs. 9007 bulbs don't just use a higher wattage low beam filament than the 9004 bulbs, they also have a differently orientated filament for which the maxima headlight housings are not designed. and yes the fluting/reflection angles used to focus the light are that precise.
__________________
Originally Posted by mightyMax95
well, i got the water pump in
Reply Posted by streetzlegend
if the car starts, ur not a nooblet anymore!
i'm just gonna start answering all ?'s i have for you with, "ebay"
Reply Posted by kzoosho
lol, u could
Originally Posted by Matt93SE
Took me a ton of money to learn that physics will ALWAYS win against a FWD car.
mightyMax95 is offline   Reply With Quote
Old 09-13-2009, 12:46 PM   #84
When I first got my I30, I slapped in some 6000K HIDs............Did it look good? Yes! Was the output better than stock? Hell Yes!! However, the light was scattered everywhere with NO cut off whatsoever...........what really made me decide to get a retro was one time I was driving past a car and my light reflected off his rear view mirror and blinded the hell out of me.
What I did then was made some custom glare shields to block out the light reflecting off the bottom of my headlights.....that helped a lot, but made the cutoff even worse.......finally I decided to do it properly. Once you retro, you'll realize how terrible HID kits in halogen housings really are.
__________________
50 Watt Ballast + 85122 = Six Lanes of Daylight!!!!!!
Either Retro or Go Home!!!
queenambeach is online now   Reply With Quote
Old 09-13-2009, 12:53 PM   #85
Crusher103's Avatar
Send a message via AIM to Crusher103
HIDs in stock housings:
dont do it, been there done that.
retro-fit vs stock housings
look less glare than the stock housing with much better output. Do That!
__________________
96 Black I30t VLSD 5spd A.K.A Big Black(has a bad attitude)
Eibach springs//Koni yellows//Koyo OE Radiator//F&RSTB//Black retro'd Cefiros w/E46 Bi-Xenon projectors/ZKW clear lense'd//Budget y-pipe//test pipe//Apexi WS2//WAI//Grounding kit
3.5 in progress
CLICK ME FOR WHEELS FOR SALE AND TIRES FOR CHEAP
Crusher103 is online now   Reply With Quote
Old 09-13-2009, 01:16 PM   #86
Nothing compares to a retro........Nothing!
__________________
Old 09-14-2009, 04:26 AM   #87
This would piss off anyone.
Old 09-14-2009, 04:50 AM   #88
Send a message via AIM to ChrisMan287 Send a message via MSN to ChrisMan287 Send a message via Yahoo to ChrisMan287
Quote:
Originally Posted by aackshun View Post
Also say good bye to having useful high beams.
Not true:
That was before I got my '97-'99 housings and before I aimed them more downwards. Haven't been flashed for having my "high beams" on ever since.
__________________
http://www.cardomain.com/ride/3135334______http://www.cardomain.com/ride/3171620
4th gen. items FS:
-2 sets of 9004 bulbs ($10/set).
-1157 red LED bulbs ($5).
-OEM bumper lights ($20).
-License plate light assembly ($10).
-PM me if interested.
-Shipping/PayPal fee not included..
ChrisMan287 is offline   Reply With Quote
Old 09-15-2009, 10:07 AM   #89
Bad Mother Fornicator
DJ420's Avatar
Send a message via AIM to DJ420
Chrisman - Some people just dont want to hear it, no matter what you SHOW them. I've stood, knelt, and sat in front of my car. Ive sat in cars that were in front of my car. I've been thorough. I'm not saying it's 100% perfect. I'm saying it's 100% doable.
I barely get beamed, had the setup 2 years now.. probably been beamed 3 times. There IS stray light, but NOT MUCH AT ALL, like Erty said. Like I already stated, I have mine aimed down. I also baked mine apart, and while "AEing" them, also painted the entire inside bottom black, as well.. thats what gives my headlights a darker look when off. Probably also helped avoid stray light shining up high.
The pics that have been posted showing HIDs in reflector housings are just TERRIBLE!! Those must have been the worst install pics you could find. Mine dont look like that, at ALL. If I can find some straight-on pics of my setup, Ill post them up later..
__________________
Built. Powered. Dropped. Braced. Tinted. Luxury Performance. Entertainment Powerhouse.
SO MuCH MoRE!! Maxus09: 2nd Place Heavily Modified 4th Gen Maxima & Judge's Choice!!
You Can Check Me Out Right HERE! Check Out New England Modified HERE!
DJ420 is offline   Reply With Quote
Old 09-15-2009, 10:59 AM   #90
Coolsaber57's Avatar
Do you want to know how many times I've been high-beamed?
You can take all the precautions you want (i.e. aiming them down, painting the reflector, etc) but it still has glare and could still potentially be dangerous.
__________________
1996 Maxima GXE "My boy blue"
TS ECU|RSB|FSTB|Leather/Heated Seats|12"sub-Alpines-Rainbow SLCs-Audison SRx2|Spoiler|5.5 Gen 17's|Custom Red Clears|Viper 771|R34 TSX Retro|5th gen muffler|300zx Fuel filter
Quote:
Originally Posted by pmohr
Oh I'll show you a dingy. A reaaaaaaaaaaal small one.
Coolsaber57 is offline   Reply With Quote
Old 09-15-2009, 01:36 PM   #91
Some people don't want to hear it, no matter what you SHOW them. HID in halogen housings are dangerous. Fine, you say you aim them down, but then you end up with ah sh*tload of foreground lighting constricting your pupils. Now, areas outside your beam pattern (that's if you even have one. ) will be a lot darker reducing your eyesight capability.
Also since our headlight use 9004 bulbs, even with aiming them down, certain sections of reflectors are designed for the high beam. These areas don't get illuminated with the low beam halogen, whereas with the HID capsule these areas are lit up ALL the time blasting on comers with GLARE!!
__________________
Old 09-15-2009, 03:17 PM   #92
Some people, especially those in rice rockets...and that's also including Neons, Cavaliers, Focus, etc....don't want to hear it, see it, or admit it that having HID kits in halogens housings are glaring, blinding, dangerous, and not cool. The most common excuses are "they're aimed really low", "my doesn't glare like that", or "I've only been flashed a few times". Denial is a natural part of being humans because we all know there's an excuse for everything (i.e. we believe in what we want to believe). Just because you haven't been flashed or been told to your face that your headlights are glaring, it doesn't mean you're okay to drive around in it. Let's face it, folks, there's no excuse for HID kits inside halogen housings. Respect others' safety, starting with your own!
imports_only1 is offline   Reply With Quote
Old 09-15-2009, 03:28 PM   #93
Crusher103's Avatar
+1 atleast someone can put this is proper words, HIDs in 9004 housings DO NOT work despite how u aim them, i have been there and done that glare was impossibly bad
Look at this:
__________________
3.5 in progress
Old 09-15-2009, 03:31 PM   #94
Crusher103's Avatar
even the H4s have trouble dealing with HIDs:
even during the day:
retrofit or just forget it
__________________
3.5 in progress
Old 09-16-2009, 02:37 PM   #95
Quote:
Originally Posted by ChrisMan287 View Post
I had hid drop-ins and pointed them down. I never got flashed but if I can see my light entering their vehicles, I know that it is bad.
The video above shows the user switching from High beam to Higher beam.
queenambeach I like your slogan.
Either Retro or Go Homo!!!
Old 09-16-2009, 11:07 PM   #96
FS Projector Headlights with HID
__________________
lol, u could
Old 09-17-2009, 02:18 PM   #97
Send a message via AIM to aackshun Send a message via Skype™ to aackshun
Not true:
I meant that after he pointed them down, they would be even more useless than what I saw in the video, I found my camera, about how far were you from the wall? I'll take a video too. This is getting interesting.
__________________
WTB A 17" Wheel, don't care what it is, how it looks, as long as it's functional (wanting a full size spare).
A/C Compressor (Doesn't fit on 99's) $70 Shipped
Scoshe Dash Pocket $10 Shipped
Stock Midpipe $20+Shipping
Used Cone Filter $5+Shipping
aackshun is offline   Reply With Quote
Old 09-24-2009, 04:56 PM   #98
Quote:
Originally Posted by eFLO View Post
just awesome man. nice azz retrofit
nice look
kelvin1018 is offline   Reply With Quote
Old 10-06-2009, 06:10 AM   #99
Nice thread, I learn a lot.
But I have one question;
we say that on stock 4th gen housing , HID makes glare, but is-it on both housing, 95-96 and 97-99 ???
Because, if I take, for exemple, volvo s60 with halogen headlights and we put hid, it works juste fine, probally the housing look like 02 maximas...
oVeRdOsE is online now   Reply With Quote
Old 10-06-2009, 06:27 AM   #100
Send a message via AIM to Eyce
Same with 97-99 my friend
Eyce is offline   Reply With Quote
Old 10-06-2009, 06:30 AM   #101
The 95-96 housing WILL glare as well. The fluted lens might help a little bit, but not much at all. Look, some halogen housings will take HIDs better than others, as I don't know the Volvos that well, I can't comment, but I know for a FACT that Maximas and Infiniti's that didn't come with OEM xenon lights, glare like a mofo when you put in a kit.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
