new design for 4th gen motor mount
Old 08-31-2009, 02:36 PM
max ride 41's Avatar
i was talkin to butch at courtesy nissan, the passenger side front mount, ( belt side) was re-designed to help with easing the weight from other mounts thus helping weight dispersion when accelerating. i ordered one, 148.00, you have to buy new screws to go with it. im anxious to see it.
max ride 41 is offline
Old 08-31-2009, 03:39 PM
B_Eaze's Avatar
Good stuff.... You know as OP and first to order you r obligate to post pics
B_Eaze is offline
Old 08-31-2009, 05:03 PM
aackshun's Avatar
Keep us informed, I had to put all my other modding on hold because now my shifter is moving w/ the accelaration aka I need new mounts...
aackshun is offline
Old 08-31-2009, 05:13 PM
i'll get the mount next week, i'll be away basking in the sun at the beach!!! as soon as i get back ill be puttin it in and i will def post pics!!
Old 09-07-2009, 09:38 AM
aackshun's Avatar
Give us an update!
aackshun is offline
Old 09-08-2009, 02:15 AM
ColombianMax's Avatar
I was also gonna get this mount at the dealer but I had some other expenses.. from what the local dealer told me is that most of the 4th gen mounts were superseeded as well as the bolts.
I keep going through idiotzone manual trans mounts, it only holds up for a month and then I have to go buy a new one and return the old one cuz its an order part only. Running on a JY trans mount and I'm just gonna try to get my money back and pick one up at the dealer instead.
ColombianMax is offline
Old 09-09-2009, 07:51 AM
I need a truck
Conrad283's Avatar
In for the pics ...
Conrad283 is offline
Old 09-12-2009, 09:31 AM
Originally Posted by NissanBeast
Is this new update for all the motor mounts or just a specific side?
Last I talked with parts at nissan it was for most of them. I can verify for ya since i gotta go there anyway
Old 09-12-2009, 09:35 AM
KRRZ350's Avatar
It's made of steel instead of aluminum, and it's basically the same thing as a 5 & 5.5 gen mount, just grab one from the wrecker for an 02/03 and you will usually end up with a nice condition mount.
KRRZ350 is offline
Old 09-12-2009, 04:07 PM
well, the mounts here and i just got back. frickin rained almost every day at the shore!! 4 inches of rain in 1 day alone!! ( thursday ) as soon as i pick up the mount, ill post picks.
Old 09-14-2009, 05:06 PM
ok, here's da pics of the new oem mount guys, im not seeing any major design change other than the new bolts and the metal base is much thinner than the original???
Old 09-14-2009, 05:22 PM
Hooooooonda.....
DAVE Sz's Avatar
you got that from courtesy? Looks like a flimsy ebay mount to me. Plus it's black. Are mounts from the dealer black now, all of them?
DAVE Sz is offline
Old 09-14-2009, 05:31 PM
yes, courtesy, and apparently there making the base lighter, ( cheaper imo ) and im not to thrilled with this mount. i agree, it looks like ebay junk.dont know about the painted mount, but i just called to see if i could get the original mount or back order it. this thing looks like $hit.
Old 09-14-2009, 05:42 PM
Hooooooonda.....
DAVE Sz's Avatar
I'm gonna go out on a limb and say they got it from the same supplier as the cheap ebay junk and marked it up a ton. Those ebay mounts have always looked like that. Very disappointed with courtesy right now.
Just to make sure, what part number is it? It came in a sealed NISSAN bag with nissan tags and everything right?
DAVE Sz is offline
Old 09-14-2009, 06:15 PM
Just the tip.
JNCoRacer's Avatar
Possibly their Key Value part?
JNCoRacer is offline
Old 09-14-2009, 06:36 PM
yes, sealed up in a nissan bag. part # 11210-2yooe
Old 09-14-2009, 06:53 PM
ok, here's what it should look like.... see any difference, class???
Old 09-14-2009, 10:09 PM
Big difference... wait so which mount is this? the one that goes by the timing chain cover?
Old 09-14-2009, 10:17 PM
yes
Old 09-15-2009, 04:32 AM
I need a truck
Conrad283's Avatar
Hmmm ... That redesign is about as good as the lower radiator support.
Old 09-15-2009, 05:23 AM
ya think???? fickin nissan, i wonder what rocket scientist re-designed the mount. money grubbing ******...
Old 09-15-2009, 07:57 AM
Blackwind's Avatar
i wouldn't put that ish on my kids scooter.
Blackwind is offline
Old 09-15-2009, 09:50 AM
Hooooooonda.....
DAVE Sz's Avatar
It was $150!!!
How much are the normal mounts?
DAVE Sz is offline
Old 09-15-2009, 11:16 AM
It was $150!!!
Damn, that's an entire engine assembly with accessories and all at the JY lol
Old 09-15-2009, 12:26 PM
FallenOne's Avatar
holy whack batman, thats total
Anyone working at Nissan got the same mounts avail?
FallenOne is offline
Old 09-27-2009, 04:19 AM
well, put her in, looks ok i guess. seems pretty sturdy, its a dampening mount so they redesigned the rubber insert to better move with the engine. ill post pics when it decide's to stop raining.
Old 07-07-2014, 08:23 AM
Alaskus's Avatar
Bumping an old thread I know...
Max I know you are still around, get you tell me what procedure was in replacing the bolt for the mount? The one the mount slides onto? Vice grips? Thread c
Locker at all? Thanks man!
Alaskus is offline
Old 07-07-2014, 03:20 PM
ugufru's Avatar
I don't know why I'm bumping thing except that I feel that it should be pointed out that the old mount appears to be aluminum and the new "cheap ebay" ones appear to be made out of steel. Wouldn't they be thinner for that reason? Does anyone have 5 or 5.5G mounts to post for comparison?
I'm probably putting new ones in a 1995 SE.
ugufru is offline
Old 07-07-2014, 03:21 PM
ugufru's Avatar
ugufru is offline
Old 07-07-2014, 09:09 PM
Alaskus's Avatar
Yes, one is aluminum and the other steel.
The issue that I am having, and have risen this thread from the grave was not about that point. Since the aluminum ones are far and few between, and to use the more abundantly available steel mounts, I (and you) would need to swap out the hardware in the mount bolted to the timing cover as the threads do not line up right with the thinner mount.
So hopefully Max Ride 41, or another org'er can give a bit more detail on their experience.
Alaskus is offline
Old 07-08-2014, 05:40 PM
CS_AR's Avatar
Once you get a new mount installed or decide what to do with the old one, you might want to look into a torque bracing bar. I love the one that's installed on the 99 SE 5MT. Also, I can tell it is saving the engine mounts.
Here's a thread on the topic below.
http://forums.maxima.org/5th-generat...t-opinons.html
CS_AR is offline
Old 07-09-2014, 05:38 AM
CMax03's Avatar
Any Nissan brands on it? Looks like some afftermarket crap! But those 2 vertical blocks on the middle elastomeric portion is new in the design...I would fill the voids with 3M Window Weld now while it's out and let it cure for about 2 days in the sun!
CMax03 is offline
Old 07-09-2014, 08:26 AM
Fakie J Farkerton's Avatar
2009
Fakie J Farkerton is offline
Old 07-09-2014, 06:59 PM
it's a nissan mount that i got from courtesy as i stated in earlier post. i did'nt save the bag it came in and this thread is 5 years old+. if you want the original mount you can go to a j/y as stated and throw new polyurethane bushings in.
Old 07-09-2014, 08:31 PM
Alaskus's Avatar
You swapped the hardware though? The bolt, i mean so it would accommodate the steel vs the aluminum height? how did you go about the swap of those? Vice grips/thread locker?
Alaskus is offline
Old 07-11-2014, 06:57 PM
Trini Boom's Avatar
You do need the bolt to replace the mount completely. Be advised if you are doing the tranny mount, it was also redesigned as well and is no longer aluminum and will need to reorder 4 new bolts.
Trini Boom is offline
vingodine
45
05-21-2016 12:46 PM
iflexsteel
09-15-2015 03:37 AM
homeyclaus
09-03-2015 06:15 PM
Rage Maximus
09-03-2015 12:26 PM
george__
08-18-2015 07:06 PM
Quick Reply: new design for 4th gen motor mount
