Drop the engine or no?
Old 12-05-2012, 05:00 PM
bkies's Avatar
I have several things that i need to replace and fix and my 96 maxima. I am going to replace the radiator the EGR valve the knock sensor, coil packs, plugs, and the rear valve cover gasket. I know its a lot of work and my question is; would it be easier to drop the entire engine out of the car to replace this stuff or just work on it with the engine in the car. I will be working at a shop and have everything i will need just needing some opinions on this.
bkies is offline
Old 12-05-2012, 05:07 PM
tosheto's Avatar
Not worth it I think. I have done all those things you have mentioned and it will not be that hard or take as long as taking the engine out. You said you will do it at a shop and that will make your job easier. Plus you can do half of the repairs one day and the rest another day. If you pull the motor the car will not be running.
tosheto is offline
Old 12-05-2012, 05:34 PM
Max139617's Avatar
As for the radiator,knock,coilpacks and plugs you DO NOT need to drop the engine. I don't know about the egr and the rear gasket.
Max139617 is offline
Old 12-05-2012, 05:38 PM
SLOW
Nealoc187's Avatar
for those simple things no way would i drop the engine.
Nealoc187 is offline
Old 12-05-2012, 05:42 PM
nsnrider's Avatar
+1
All that work can be done under 3 hours time, tops.
nsnrider is offline
maxinout93's Avatar
no all those things can be done with the engine in the car
maxinout93 is offline
Old 12-05-2012, 05:50 PM
EvoTillIDie's Avatar
No way....save yourself the time & hassle...keep the engine in
EvoTillIDie is offline
Old 12-07-2012, 07:52 PM
Snypa's Avatar
not worth dropping. all those things are very much accessible.
Snypa is offline
Old 12-07-2012, 07:59 PM
Trini Boom's Avatar
You want to drop an engine for these little things?? Why couldn't we access a shop to do things like the RMS and Rear timing cover o-rings??....
Trini Boom is offline
Old 12-08-2012, 05:07 PM
Max streets's Avatar
3.5swap then drop it other than that no.
Max streets is offline
Old 12-08-2012, 07:06 PM
maxfever1987's Avatar
Keep the engine in and do everything you need done, once the uim if of everything else in easily accessible
maxfever1987 is offline
03-12-2020 12:06 AM
captchaos
03-15-2016 12:18 PM
fastcarny
10-06-2015 10:42 AM
NissanNismoZ
09-12-2015 07:30 AM
jfl330
09-04-2015 01:44 PM
Quick Reply: Drop the engine or no?
