00VI Manual
Old 08-18-2009, 02:23 PM
MOHFpro90's Avatar
00VI Manual
This is v.1 of my 00VI manual I have written. I have seen an abundance of threads and questions lately, so I figured I would put it out prematurely. I am still working on this, and it will be updated when I feel that significant changes have been made.
This would not have been possible without the willingness to search for the information that is already out there. There is more information on this board from guys such as Tatanko, pmohr and Ceasars Chariot than the government has on Watergate.
I gave credit to various people as I went through, though Im sure I have missed some. If credit has not been given where it is due, tell me, I will gladly put it in.
(click on the picture to take you to the download link for the PDF)
MOHFpro90 is offline
Old 08-18-2009, 03:40 PM
maxboy325's Avatar
Sweet! Downloaded
maxboy325 is offline
Old 08-18-2009, 06:29 PM
ajm8127's Avatar
Very nice! Good to see some members putting in a little extra effort. I have a feeling I might be looking at this document one or two times for an upcoming project...
ajm8127 is offline
Old 08-18-2009, 07:36 PM
Nrw
Nrw's Avatar
Awesome! Downloaded
Nrw is offline
Old 08-18-2009, 07:40 PM
No more Maximas...
pmohr's Avatar
Nice.
Just note that Tatanko's site is now hosted on my server: tatanko.boredmder.com
pmohr is offline
Old 08-18-2009, 07:56 PM
Turbo'd Saab
DrunkieTheBear's Avatar
i don't have a pdf reader...
DrunkieTheBear is offline
Old 08-18-2009, 07:58 PM
Product_Of_Korea's Avatar
very nice Kyle.
Though i do see some typo's
Product_Of_Korea is offline
Old 08-18-2009, 07:59 PM
Old 08-18-2009, 08:02 PM
MOHFpro90's Avatar
Originally Posted by pmohr
Nice.
Will make the edits next version. Should be soon, within the week I hope.
Originally Posted by Product_Of_Korea
very nice Kyle.
Workin on it
Old 08-18-2009, 08:23 PM
balkan's Avatar
Very nice. Thanks a lot!
This will come in handy in the near future.
balkan is offline
Old 08-18-2009, 08:28 PM
Hooooooonda.....
DAVE Sz's Avatar
Yeah the grammar is iffy. I'm also not too happy about the "the 00 IACV is iffy at best on the 4th gen ecu".
All you have to do is screw in the lil bolt on the TB a lil further in to open the TB plate up a bit. Get the idle at around 700rpm and the 00IACV works perfectly. Mine even raises rpm when power steering is used, not sure how but it does.
Also not sure if you mentioned that as long as the EGR temp sensor and the EGR solenoid are plugged in, you won't get a EGR malfunction code...
And for #4 and #5 on the vacuum hose diagrams. #5 works perfectly fine with the stock hose coming from the EVAPCPVCV. So only #4 needs to be modified and ONLY if you're using the 4th gen IACV...
The vacuum diagram also doesn't mention the small vacuum port under the brake booster port #1...
DAVE Sz is offline
Old 08-18-2009, 08:34 PM
MOHFpro90's Avatar
I copied and pasted from Pats site, I will edit it...
As per Pat, the small port below the normal break booster is something rare, and is something to do with Cali emissions or something to that effect. It is not normal, rather more uncommon than common.
Some of the information I pulled from various sources, hence the credits where they're due. I might say Lower Intake Manifold vs LIM, 00 vs 01 vs A33 vs DEK etc etc.
Old 08-18-2009, 08:44 PM
Under the radar
Max_Out's Avatar
Very nice! I could of used this about 2 months ago.
Kudos!
Max_Out is offline
Old 08-18-2009, 08:46 PM
Hooooooonda.....
DAVE Sz's Avatar
Originally Posted by MOHFpro90
And uh, There is no vacuum port below #1...
I have 1 right under the brake booster port.
I don't have a toaster but I doubt they spell 1 word 5 different ways like you did.
DAVE Sz is offline
Old 08-18-2009, 11:10 PM
shadyonedeath's Avatar
Both my manifolds had that port. But they were plugged with a rubber cap from factory. Can be seen cut off in my 00vi thread in All motor section. What are they for btw? Why plug them from factory?
shadyonedeath is offline
Old 08-18-2009, 11:39 PM
Decimus Meridias's Avatar
thanks a bunch for your work. Now you've got me thinking I need to spend some $ and get started.
Decimus Meridias is offline
Old 08-19-2009, 12:00 AM
aackshun's Avatar
Great job with the manual!!!
aackshun is offline
Old 08-19-2009, 12:51 AM
tosheto's Avatar
for some reason the link does not work for me
tosheto is offline
Old 08-19-2009, 03:08 AM
sleepless's Avatar
Same here, at first it brought me to a google sign-in page.
Did that, it said re-directing, then ...
      I'm thinking it's a google problem. Was having issues just signing into gmail after this happened
      sleepless is offline
      Old 08-19-2009, 07:54 AM
      ajcool2's Avatar
      Very nice job man. To anyone planning on doing this I would strongly suggest going with setup number 1 since its so easy. When you start doing customizations you just make the whole process alot harder than it should be. Its crazy how it took me so long to complete my swap and now I can take it completely apart by myself in about 20 minutes or less. Also if anyone if looking for DEK parts let me know I have plenty.
      ajcool2 is offline
      Old 08-19-2009, 07:59 AM
      The Golden One
      IlyaK's Avatar
      Maybe I'm just dumb but...I need to sign in to download...I don't have a google account...
      IlyaK is offline
      Old 08-19-2009, 08:53 AM
      ajcool2's Avatar
      Yeah I had to sign up for an account to veiw it.
      ajcool2 is offline
      Old 08-19-2009, 09:06 AM
      Hooooooonda.....
      DAVE Sz's Avatar
      I don't know what they're for but I ran my FPR vacuum there...
      DAVE Sz is offline
      Old 08-19-2009, 11:39 AM
      MOHFpro90's Avatar
      Alrighty guys, the PDF is hosted elsewhere and should continue to work. If for some reason it does not, let me know.
      Old 08-19-2009, 01:09 PM
      No more Maximas...
      pmohr's Avatar
      If this host doesn't work out, I can throw it up on my site.
      pmohr is offline
      Old 08-19-2009, 02:03 PM
      tosheto's Avatar
      Now it works. thank you
      tosheto is offline
      Old 08-19-2009, 02:08 PM
      MOHFpro90's Avatar
      T'was what my IM was about earlier, though my room mate offered to host it for me. Ill hit you up if I need it. Thanks man.
      No prob. Working on v2.
      Old 08-19-2009, 02:22 PM
      Hooooooonda.....
      DAVE Sz's Avatar
      It was hosted at google docs so as long as people had gmail it should've worked...
      DAVE Sz is offline
      Old 08-19-2009, 02:23 PM
      No more Maximas...
      pmohr's Avatar
      And there's the problem. Hosting a document with a stipulation such as that doesn't help everyone.
      pmohr is offline
      Old 08-19-2009, 03:16 PM
      MOHFpro90's Avatar
      Exactly. Ive moved the host, and its done. I wasnt aware of this stipulation, glad someone pointed it out. Ill let you know if I need it hosted man, thanks for the offer.
      Old 08-19-2009, 04:17 PM
      maxed_out_99's Avatar
      does the 00vi bolt up to the vq30de or do you have to change the ecu or what
      maxed_out_99 is offline
      Old 08-19-2009, 04:21 PM
      No more Maximas...
      pmohr's Avatar
      Seriously?
      Have you read the stickies in AM? Read Tatanko's site? Read the manual in the first post? Have you done any reading on it at all?
      Every single last bit of information you could ever want on the 00VI is available on this site, you just need to search for it.
      Yes, it bolts up. And no, it doesn't bolt up. It all depends on what you mean by '00VI'. Yes, you can change the ECU. No, you don't have to.
      Search.
      pmohr is offline
      Old 08-19-2009, 04:44 PM
      exsjulio's Avatar
      This is AN AWESOME SOURCE.. thanks for the work towards the org!!!
      exsjulio is offline
      Old 08-19-2009, 05:06 PM
      LushMoney's Avatar
      wow absolutely awesome!! thanks alot
      LushMoney is offline
      Old 08-19-2009, 06:19 PM
      MOHFpro90's Avatar
      You sir, are the reason I made this manual. Would you at least give me the respect and at least read the first page of the manual?
      And thanks guys.
      Old 08-19-2009, 07:43 PM
      Wow you have alot to learn................
      Read this write-up PLEASE!!
      Old 08-19-2009, 07:53 PM
      ajcool2's Avatar
      Search.
      lol
      ajcool2 is offline
      Old 08-19-2009, 08:24 PM
      HandsonMaxima.'s Avatar
      Wow, just browsed through for a second and already learned something new about my swap. I have a bad IACV gasket, nifty. Thanks for the amazing write up!
      HandsonMaxima. is offline
      Old 08-19-2009, 08:54 PM
      Hooooooonda.....
      DAVE Sz's Avatar
      That thin, orange gasket right? I have the same problem but changing the gasket didn't help...
      DAVE Sz is offline
      Old 08-19-2009, 09:57 PM
      Maybe we have a gnome in our intakes? or perhaps a snake rather hah. Ill replace mine and if it doesnt work, ill search/troubleshoot since i know now its not normal. Actualy i dont even remember having one on my IACV. i guess ill look tomm.
      but i dont want to thread steal here. back to the topic.
      Quick Reply: 00VI Manual
