Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
New! Use your Facebook to securely log into this site, click logo to login
Sponsored by:
Click Here
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 07-29-2009, 01:08 PM   #1
I want to use a non NATS key the hard way... How do I?
Searched, couldn't find any info...
No, it's not stolen! I'm just sick of buying freaking $100 keys! We go through like 1-2 a year!!! Drop them they break, chip falls out, too many keys on the ring, the key breaks, etc...
I know I can put a NATS key in the column but I don't want to. I don't want someone to find out it's in there and taking it for a joyride!
How does it all work exactly?
My understanding is... The antenna reads the key then sends the signal to the IMMU and if the key is legitimate (programmed) the IMMU allows the car to start. Right?
So, if I emulate the signal from the antenna (key 'X' is read and signal 'Y' voltage is sent), if should work, right?
On the wiring diagram it looks like there are two signal wires and if I put the key in and measure the output, I should have the voltage that I have to send, right?
Too simple?
Juscruzn is offline   Reply With Quote
Old 07-29-2009, 01:21 PM   #2
Send a message via AIM to njmaxseltd
Quote:
Not quite, the pickup sends the key signal to the IMMU, if it's a legit key the car can be started. It's not a voltage you can measure per say, unless you have an oscylicsope(sp?) to look at the actual signal and something to duplicate it with.
You can hide a key near the cylinder, then you'll basically be bypassing the system. Ton's of 4th gens on the road without IMMU systems don't get taken for a joy ride on a regular basis.
Honestly, how in the world do you lose or break keys? 10 years and I still have all my keys and key fobs.
Do you lose your house keys that often as well?
njmaxseltd is offline   Reply With Quote
Old 07-29-2009, 01:23 PM   #3
LandShark has Cosworth
grey99max's Avatar
Too simple?
I feel the same way - my car has lost its' mind twice at the drag strip and left me "immobilized". The NATS signal that goes to the ECU goes over one wire, so it must be a data stream of some sort?? Too simple if it's a just a voltage, right? But, if the ECU ain't happy, no one leaves the barn.
I wonder if a remote wireless starter is possible with the NATS Maximas? I suppose you could ask any good car thief how they would do it.
grey99max is offline   Reply With Quote
Old 07-29-2009, 01:26 PM   #4
Willing to learn
oldngivout's Avatar
You're making it harder than it really is.
If you are worried about the key being discovered, just conceal the chip portion of the key behind the steering column cover. You could do something as simple as filing down the ridges in your key to make it inoperable, then hide it. You will still need another key from your pocket to start and drive the car, which will make it just as hard to steal as any other 10 year old car is.
__________________
Unless you do it exactly like I did, your results may vary.
oldngivout is offline   Reply With Quote
Old 07-29-2009, 01:27 PM   #5
Quote:
The better half does... I have yet to lose, break one!
Old 07-29-2009, 02:18 PM   #6
The Dirty Pearl
pmohr's Avatar
If you want to bypass the entire system, just throw in an earlier ECU, repin the engine control harness, problem solved.
__________________
A32 CEL Decoder | Howto Videos
pmohr is offline   Reply With Quote
Old 07-30-2009, 06:32 AM   #7
Quote:
More detail please.....
Old 07-30-2009, 09:40 AM   #8
This is the way to go. You only need the plastic top of the key. Well really only the transponder chip to be near the antenna. The car would not know the difference then if you used a standard key. (remove all the chips from any other keys)
Why would you want to go through any more work than that? Everything else you do will be more work with no better function.
FYI: I installed a 2000 maxima motor into a different car. Overriding the NATS is not an option (maybe in japan some hackers could but no where in the states). I installed all the NATS componets and taped a key top to it. Vrroom.
__________________
'96 Maxima SE 5-speed (wife/family car) Forsale!
'93 BMW 325i sedan (black) with LS1 and 6 speed manual (current dailiy driver)
'99 Land Rover Discovery (it was cheap)
'93 BMW 325i Sedan (blue) converted to Electric power (No gas)
Thaniel is offline   Reply With Quote
Old 07-30-2009, 10:05 AM   #9
Quote:
I'm down to my last key (chip). If the chip goes bad I really don't want to hassle with it.
Plus, I like the challange....
Old 07-31-2009, 08:58 AM   #10
maximabebe's Avatar
As someone stated above, I think the easiest method would be to hide the chip near the ignition and then use a $2 copied key.
__________________
maximabebe is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Advertising - Terms of Use - Privacy Policy - Jobs - Maxima Forums - Archive -
Top
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.0
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
