Removing Upper Intake Manifold (UIM) w/pics
Old 05-08-2014, 05:12 AM
  #121
The_Fixer's Avatar
Trust me bypass it and remove the 1 uim mounting bracket on that side also.i ran into the issue that everytime i seated the uim that damn U shaped hose would find its way between the back of the manifold and the VC causing the uim not to sit correctly.after the 3rd time DELETE happened!
The_Fixer is offline
Old 05-08-2014, 10:14 AM
  #122
CS_AR's Avatar
I'm with ya! I adapted the mounting brackets (picture below) so the bracket bolts can be pre-mounted into the UIM. Now that I don't need to wrestle with the coolant hose, the UIM can be dropped into the slots and on the intake runner with minimal effort.
CS_AR is offline
Old 05-08-2014, 06:15 PM
  #123
Trini Boom's Avatar
No need for the bracket after I removed it and added a 1ft hose back there. Now the UIM comes to me when I need it off. Haven't had to take it off in 3 years.
Trini Boom is offline
Old 05-09-2014, 12:32 AM
  #124
CMax03's Avatar
I think that's a good Idea! keeps that UIM and LIM unified and possibly increases the gasket life.... I'll do the same or make me one out of steel tubing.....
CMax03 is offline
Old 08-23-2015, 04:07 PM
  #125
yippzter's Avatar
Hi guys I finally removed Upper Intake Manifold for 2hours. Been struggle with the hose behind the manifold cuz hard to access there. I took it out and saw some oil in the manifold (I forgot to take picture) I am not sure if its normal or not so I took throttle body and saw oil on it too. Is it normal?
yippzter is offline
Old 08-23-2015, 08:42 PM
  #126
^Yes, that's normal.
The Wizard is offline
Old 08-24-2015, 05:02 AM
  #127
rbuswell's Avatar
EGR feeding gunk into intake
I believe the source for the oily build up is the Exhaust Gas Recirculation (EGR) system. Since you have it apart, it is probably a good idea to clean out the throttle body with a good throttle body cleaner. I used the Wurth product but I think there are several good ones on the market. I also flushed the intake manifold itself in my parts washer. It wasn't sparkly clean but it was certainly cleaner when I was done.
rbuswell is offline
Old 08-24-2015, 07:51 PM
  #128
It's actually from the PCV valve, as oil vapors pass through the system. Install a proper catch can, and this oil build-up would stop.
Old 08-25-2015, 03:37 AM
  #129
rbuswell's Avatar
Correct
I believe The Wizard is correct about the PCV contributing to this as well. I know when I did this work to my car there was a lot of oily looking crude in the EGR tube bolted into the intake manifold.
rbuswell is offline
bumpypickle
09-20-2015 08:22 AM
bumpypickle
09-19-2015 01:07 AM
Mahmuth
09-17-2015 11:45 AM
Maxboy23
09-09-2015 10:37 AM
Quick Reply: Removing Upper Intake Manifold (UIM) w/pics
