Squealing like a pig
My alternator blew and since the mechanic was already gonna be in there, I had him change the belts with OEM Nissan belts. Now when I start the car, it squeals like a pig if the AC is on. If I turn off the AC, it stopped and when I turned it back on, it was fine. Any idea why that might happen?
Yep, just a loose belt.
Its not hard to do.
- take your wheel off.
- remove the plastic that hides the engine compartment.
- loosen [dont remove] the bolt on the tensioner pulley, IIRC its a 14mm, May be a 12mm.
- tighten up that weird lookin bolt on top of the tensioner pulley. [14mm]
- go back down under the car and tighten up that pulley bolt.
- Put it back together.
Its not hard to do.
04-16-2020 05:15 AM
