Steering has too much wobble room
Old 07-20-2009, 09:18 AM
88FordFestiva's Avatar
So my maxima, ever since I bought it, has had a ton of play in the steering. I can easily wobble the steering wheel between 2 or 3 inches without really affecting the direction of the car.
Where do I start?
88FordFestiva is offline
Old 07-20-2009, 10:00 AM
NevadaJack_9's Avatar
Sway bar end links, control arm bushings and ball joints
NevadaJack_9 is offline
Old 07-20-2009, 12:10 PM
j2b4osan's Avatar
It's most likely the tie rod ends. That's where I would start.
j2b4osan is offline
Old 07-20-2009, 12:11 PM
njmaxseltd's Avatar
All of the above.
njmaxseltd is offline
Old 07-20-2009, 05:40 PM
$uperstarr124's Avatar
my steering wheel is really loose...i ask a mechanic but he was unsure...
$uperstarr124 is offline
Old 07-20-2009, 05:47 PM
f550maranello2's Avatar
then you should have went to another mechanic since this one doesnt know basics...
f550maranello2 is offline
Old 07-20-2009, 06:36 PM
jkahng's Avatar
i would start with the easiest / cheapest fix first.
start with the endlinks parts are cheap and relatively easy to do.
my steering was worse than my dad's olds 98 (very vague, too light)
i did the endlinks and sway bar bushings and it feels MUCH better.
jkahng is offline
Old 07-20-2009, 08:58 PM
bamboomerang's Avatar
'99 steering rack.
bamboomerang is offline
Old 01-03-2010, 08:00 AM
diamondtcb's Avatar
I had a ton of slop and it turned out to be the steering rack bushings allowing the rack to move. They were ruined from a fluid leak.
diamondtcb is offline
Old 01-03-2010, 10:26 AM
fonz's Avatar
steering
tierod end and ball joints,also check the rack
fonz is offline
Fbana41
08-29-2016 12:18 PM
worldwiderecognized
09-30-2015 01:16 PM
DC_Juggernaut
09-28-2015 04:07 PM
Quick Reply: Steering has too much wobble room
