SLIP, ABS, TCS dash lights always lit
Old 07-11-2009, 02:14 PM
progrocker's Avatar
Since spinning my wheels in the snow last winter my SLIP and ABS dash lights are always lit. Also the Traction control is stuck in the OFF position. If I disconnect the battery for a period of time will these lights reset? If not any suggestions? Thanks all.
progrocker is offline
Old 07-11-2009, 02:37 PM
VQrebuild96's Avatar
4th gen with traction control?
VQrebuild96 is offline
Old 07-11-2009, 02:48 PM
modenaf1's Avatar
I would start by checking the fuses. After that, I would look in the 1999 FSM. I believe there is a diagnostic procedure to get it to flash a code.
Some 99's got it.
modenaf1 is offline
Old 07-11-2009, 03:21 PM
FallenOne's Avatar
there is, i would also check to make sure that your grounds and battery terminals are sufficiently tight, and that the ABS sensors are not dirty or damaged.
FallenOne is offline
Old 07-11-2009, 03:51 PM
No more Maximas...
pmohr's Avatar
Have you not tried this yet? It's been what, 7 months since the wintertime? Disconnecting a battery cable takes 10 seconds...
pmohr is offline
Old 07-11-2009, 05:11 PM
progrocker's Avatar
First thing I did was disconnect the battery cable for a couple of minutes. My question asked if it had to be disconnected for some period of time for a reset. Try completely understanding a question before offering up a condescending half assed remark genius.
Old 07-11-2009, 05:13 PM
No more Maximas...
pmohr's Avatar
If you're looking for help, that's not the way to talk.
Did you mention that you had already disconnected the battery? ...no, I didn't think so.
I understood the question well enough, and I've actually got the answer as well.
Anyway, I'll move along now.
pmohr is offline
Old 08-23-2009, 12:36 PM
Darkstonian's Avatar
Well before you do, I'd like the answer, cause I'm having the same problem, 5th gen though. If you don't want to share with the aforementioned, shoot me a PM plz. Thanks
Darkstonian is offline
Old 08-23-2009, 04:45 PM
max ride 41's Avatar
wow pmohr, it just dawned on me that your like the chef ramsey of the maxima forums. i can imagine that you'd be screaming your replys at these guys if you had your own show.
max ride 41 is offline
mvm062
11-30-2020 09:00 AM
MaxLife17
06-27-2019 01:37 PM
MaxLife17
09-08-2015 02:36 PM
maximusrising
09-02-2015 09:55 AM
Quick Reply: SLIP, ABS, TCS dash lights always lit
