Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 07-01-2009, 05:02 PM   #1
Quick question on Belt
If I loosen the tension bolt (the one you see while looking down the engine bay), will that give me enough slack to replace the belt? Thanks
__________________
adithius is offline   Reply With Quote
Old 07-01-2009, 07:11 PM   #2
The Dirty Pearl
pmohr's Avatar
Yes, that's the entire point of that assembly, to tension the belt.
Obviously you can't just loosen the adjustment bolt, but the answer is yes.
Is there some part of your question that may not be very obvious? Because as far as I can see, you're asking whether or not a piece of equipment can do what it's designed to do
Also, you are aware that there are two belts, correct?
__________________
Quote:
Originally Posted by 2damax View Post
This jerk is right so often I just search threads hoping he gets something wrong so I can catch him
Quote:
Originally Posted by kizzmyazz View Post
ok so what i found out is that because of the FMU, i dont need to get injectors because it will neutralize the oil pressure to prevent detotnation
FSMs | A32 CEL Decoder | Howto Videos
pmohr is offline   Reply With Quote
Old 07-01-2009, 08:23 PM   #3
How would he go about changing the power steering belt?
loxety is offline   Reply With Quote
Old 07-01-2009, 08:28 PM   #4
What else would I need to loosen other than the adjustment bolt? What confuses me is that I see some vid on youtube (non-max, since I couldn't find any), they usually just loosen the tensioner pulley and pull back the belt. The stickys show a page where there are a few key bolts. So I'm just looking for clarification.
The one I'm trying to replace is the accessory belt (serpentine).
__________________
Old 07-01-2009, 08:33 PM   #5
G-string Money Tight.
JNCoRacer's Avatar
Send a message via AIM to JNCoRacer
You have to loosen the 14mm nut on the tensioner pulley itself first I believe, then loosen the adjuster on the top.
__________________
DNE VP
www.nissans.org
JNCoRacer is offline   Reply With Quote
Old 07-01-2009, 08:35 PM   #6
The Dirty Pearl
pmohr's Avatar
FWIW there are two accessory belts. You mean Alt/AC?
And obviously watching a video on a different make or model is completely irrelevant, as you have to follow the instructions specific to this tensioner. Loosen the 14mm head locknut, then adjust the main tensioner bolt.
Quote:
Quote:
By searching
__________________
Old 10-14-2009, 03:32 PM   #7
Okay so 3 months later I just tackled this. My 14 mm wrench was a standard, and not long enough so I had to get the tensioner pulley from below and jacking the car up. It was fairly easy, just had to wait for the Penetrating Blaster to seep in so I wouldn't ruin the nut.
I left the Power Steering belt alone for now, (1) It didnt look that bad (2) I didn't want to spend another hour trying to figure out what the best way to get at it was.
Anyone know the best way to get at the Power Steering belt? Over the hood, under the car, what type of wrenches, etc...
__________________
Old 10-14-2009, 05:43 PM   #8
I used a 14mm ratcheting wrench, from below. The open end stuck out just far enough past the axle for me to push up on it with a hammer handle to break the nut loose. After that, a lot of ratcheting. It was an entertaining test of manual dexterity.
I couldn't tell what loosening that nut did, exactly. So I didn't know how loose it needed to be. I nearly took it all the way off I think.
ATTappman is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
