Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 05-29-2009, 01:47 PM   #1
cruise control problem. need wisdom
Before I get flamed I searched and read for many hours before posting.
My cruise stopped working a few weeks ago. Today I checked the cable, vacuum hose that goes to actuator, fuses, relays. Everything works.
What the car does:
no codes
When I turn on the cruise and set it to speed it won't keep the speed. It tries to keep it and even down shifts (4 auto). After that it just turns off. I tried to set it by holding the set button on the wheel and then turning the power to it from the dash. when I do that the cruise light starts flashing and it won't even engage for a second.
From all this I think that the actuator is working because of the down shifting. I am thinking that it's the control module in the corner of the engine bay or the speedo. How can I test those and fix the problem?
I tried to remove the control module but I couldn't.
Thanks!
__________________
Proud 4th Gen Owner!
djipka is offline   Reply With Quote
Old 05-29-2009, 01:56 PM   #2
The Golden One
IlyaK's Avatar
Try the computer under the dash. Unplug it and plug it back in.
IlyaK is offline   Reply With Quote
Old 05-29-2009, 02:01 PM   #3
Quote:
Do you mean the ECU?
__________________
Old 05-29-2009, 02:17 PM   #4
The Dirty Pearl
pmohr's Avatar
Quote:
No, the ASCD control unit.
What you're calling the 'control unit' is really just a vacuum pump:
__________________
A32 CEL Decoder | Howto Videos
pmohr is offline   Reply With Quote
Old 05-29-2009, 02:55 PM   #5
ok. so where exactly is the ASCD control unit? Under the steering wheel and that?
__________________
Old 05-29-2009, 03:19 PM   #6
The Dirty Pearl
pmohr's Avatar
As IlyaK said, under the dash. Between that and the picture, it shows right where it is.
It's mounted right near the radio.
__________________
Old 05-29-2009, 03:58 PM   #7
Also if your o/d light is flashing, that could cause it not to work. Thats what happened to me, my speedo was off by about 10km/h and my o/d would flash, it started doing it more and more, until I switched the speedo, now its all good. Anyway theres a procedure on here on how to check your tranny for codes(which is what the flashing o/d light does). If you cant find it ill post it.
__________________
vilmaxima is offline   Reply With Quote
Old 05-30-2009, 02:06 AM   #8
No O/D flashing.
I will check the ASCD module tomorrow when I get a minute.
__________________
Old 05-30-2009, 10:09 AM   #9
I need to replace the ASCD module on my 95 Maxima GLE. I know it is below and to the right of the steering column and behind the steel plate. I can remove the steel plate, but the 2 bolts holding on the ASCD module are behind the right mount of the steel plate. Please give me some suggestions on how I can remove the two bolts. Thank You.
__________________
v_c
v_c@yahoo.com is offline   Reply With Quote
Old 05-30-2009, 01:03 PM   #10
The Dirty Pearl
pmohr's Avatar
Quote:
Remove the bracket for the plate. It's a single 10mm head nut.
__________________
Old 05-30-2009, 03:07 PM   #11
The Golden One
IlyaK's Avatar
Reseating the connection on the ASCD module fixed my issue on the 97. Before that I had tried different cruise switches (on the steering wheel), reseating the connection on the module/pump in the engine bay, etc. Reseated the main computer connection and it was fine.
My 99 hasn't had a single issue yet, so I dunno if that could be a 'common fix' or if I just got lucky. It's worth a shot though.
If you remove the two small screws holding the plastic kick panel to the underside of the dash, you will see the module. As PMohr said, it has one single 10mm nut holding it to the bracket. You might even be able to unplug and plug without taking it off. I don't remember exactly how the connection was made, so I can't say for sure.
Old 05-30-2009, 10:08 PM   #12
Before going through the hassle of actually installing the ASCD module, I unplugged the old one and plugged in the replacement while twist-tying it in place. It did not solve my cruise control problem. Therefore, let me describe my problem.
I can push the little button and turn on the green light for the Cruise Control feature. That's all I can do. I cannot set and lock in any speed. Before it totally failed, I could lock in a speed but every time I hit a small bump in the road, it would unset. Now it doesn't set at all. If this sounds familiar to anyone, please share your experience on how you fixed the problem. Thanks.
__________________
v_c
Old 05-30-2009, 10:16 PM   #13
The Dirty Pearl
pmohr's Avatar
Have you checked all of the connections? If it happens over a bump, it's most likely just a loose connector.
First place I'd check is the connector on the switch assembly.
Have you done any of the diagnostics per the FSM?
__________________
Old 05-30-2009, 10:24 PM   #14
My mechanic said that there was something wrong with the ASCD module and vacuum pump. He went through the diagnostic. I bought a couple of used parts and swapped them in. No difference..
__________________
v_c
Old 05-30-2009, 10:26 PM   #15
The Dirty Pearl
pmohr's Avatar
'My mechanic said'...that's never the way to get something done.
If he thinks he knows what the problem is, then why isn't he the one fixing it?
If you don't do the diagnostics yourself, you don't know what did or didn't show up.
Again, have you or have you not checked all of the connections? That's most likely the issue.
__________________
Old 05-30-2009, 10:28 PM   #16
Coolsaber57's Avatar
Sounds to me like it's the switch on the steering wheel. I know mine didn't set at all and once I replaced that, it worked fine.
__________________
1996 Maxima GXE "My boy blue"
TS ECU|RSB|FSTB|Leather/Heated Seats|12"sub-Alpines-Rainbow SLCs-Audison SRx2|Spoiler|5.5 Gen 17's|Custom Red Clears|Viper 771|R34 TSX Retro|5th gen muffler|300zx Fuel filter
Quote:
Originally Posted by pmohr
Oh I'll show you a dingy. A reaaaaaaaaaaal small one.
Coolsaber57 is offline   Reply With Quote
Old 05-30-2009, 10:32 PM   #17
Good Idea. How do I access the CC switch wires on the steering wheel so that I can check for continuity?
__________________
v_c
Old 05-30-2009, 10:33 PM   #18
The Dirty Pearl
pmohr's Avatar
Pull the cover off, then the CC switch assy is just held on by 2 screws (IIRC).
__________________
Old 05-30-2009, 10:33 PM   #19
great. thanks. I'll try it tomorrow.
__________________
v_c
Old 05-30-2009, 10:36 PM   #20
The Golden One
IlyaK's Avatar
I believe I have a working switch if you end up needing one.
My issue was the ASCD computer, I had gotten a switch and ended up not needing it.
Old 05-30-2009, 11:59 PM   #21
I would also investigate the switch on the brake. Based on your order of events, the brake switch could be disengaging the cruise control. Should be able to adjust it if that's the cause.
jdooley is offline   Reply With Quote
Old 05-31-2009, 01:31 PM   #22
The ASCD switch on the steering wheel seems ok. Please tell me more about the switch on the brake pedal. I know that when you step on the brakes you disengage the CC. Please tell me more about this switch. I didn't see if when looking at the brake pedal. Then again, I don't know what it looks like. Thanks.
__________________
v_c
Old 05-31-2009, 01:39 PM   #23
The Dirty Pearl
pmohr's Avatar
It's mounted to the brake pedal arm bracket, should be right behind the arm. It basically just looks like a block of plastic with a connector plugged in.
Again, though; have you done the diagnostics yet? They should at least get you looking at one specific thing.
__________________
Old 05-31-2009, 05:00 PM   #24
I still haven't had time to check anything else. At least I am not the only one with the problem so you guys have given me good ideas. Thanks!
__________________
Old 05-31-2009, 06:01 PM   #25
just sell your car and buy honda. problem solved
__________________
Signature pictures are to be no larger than the allowed size of 550 x 325 pixels
tosheto is offline   Reply With Quote
Old 05-31-2009, 06:58 PM   #26
I've decided that a modern car probably only lasts 15 years in a fully functional state. Afterward, expect more electronics to fail until the car doesn't work anymore. This would be a really scary statement for contemporary cars for which hybrid/electric cars are 100% dependent on electronics. My car still runs, for a contemporary car, is it game over around 10-15 years? Just following tosheto's tangent. I'm still trying to figure out how to fix my CC.
__________________
v_c
Old 05-31-2009, 08:04 PM   #27
Come to think of it before you replace the switch, you can test the switch with a multimeter according to the FSM.
__________________
Old 06-01-2009, 02:52 AM   #28
the Honda thing was just a joke man. I would buy any Nissan before I buy a Honda
__________________
Old 06-01-2009, 11:22 AM   #29
Old 06-01-2009, 03:59 PM   #30
so here is a little update. I unplugged and reseated just about everything I could get to: switch on steering wheel, ASCD module under dash, vacuum pump in engine bay.
I went on the hwy for a test and still the same. This time I kept my foot on the gas as I was setting the cruise so that I can feel if it goes down as usual. Well, it didn't. The green cruise light came on and the speed started dropping as if nothing was on. I kept my foot to see if the pedal will go down when the car down shifted. It did down shift but that was not triggered from the TB or cruise cable pulling, it was an electronic shift I guess.
So now I am thinking that it's either the vacuum pump or the actuator. I pulled the actuator off the car but am not sure how to test. I don't have the FSM where I am at right now so no idea if it says something there.
How do I take the vacuum pump off? I can't seem to figure that out
__________________
Old 06-01-2009, 04:04 PM   #31
The Dirty Pearl
pmohr's Avatar
The pump is easy, just 1 10mm head bolt on the strut tower, 2 10mm head nuts in the wheel well. Which reminds me, I need to put those nuts back in...without them, every time you activate the cruise control, the pump rattles like a bastard for a second.
For the actuator, just apply vacuum to it and see if it draws in the throttle cable.
__________________
Old 06-02-2009, 02:35 AM   #32
I will have to look into that.
any easy ways to check the actuator without a vacuum pump handy? I don't have one
__________________
Old 06-02-2009, 02:36 AM   #33
The Dirty Pearl
pmohr's Avatar
Hook it up to a vacuum hose from the intake.
__________________
Old 06-02-2009, 03:22 AM   #34
Quote:
you are smart, you know that?
oh, and by the way, do you ever sleep? every time I get on the forum and you are online
__________________
Old 06-02-2009, 03:24 AM   #35
The Dirty Pearl
pmohr's Avatar
I sleep when absolutely necessary. Not a very efficient use of time.
__________________
Old 06-02-2009, 07:05 AM   #36
The Golden One
IlyaK's Avatar
OP.
What green light comes on? The one on the BUTTON on the dash (to the left of the security light) or the one under the gas gauge/speedometers that says "CRUISE"?
If it's the one on the button and the one on the speedometer doesn't turn on, it's not your pumps that are bad. It's your ASCD module. If the light on your speedometer cluster turns on, then your 'electrical' parts are working fine and it's your pump/actuator that's bad.
lol.
lol.
Old 06-02-2009, 07:43 AM   #37
check the computer under the dash....
__________________
thanE[img]http://************.info/images/e6cbc650cd5798a05dfd0f51d14cde5c.gif[/img]
denice25 is offline   Reply With Quote
Old 06-02-2009, 07:52 AM   #38
The Golden One
IlyaK's Avatar
Quote:
We already told him that.
Old 06-02-2009, 11:31 AM   #39
OP.
lol.
lol.
the CRUISE one by the security and that is what comes on.
so you are saying that its either pump or actuator as I thought after my last test drive on the hwy.
__________________
Old 06-02-2009, 11:33 AM   #40
The Dirty Pearl
pmohr's Avatar
If you can get the cruise light to flash...DO THE DIAGNOSTICS.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
