Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 05-26-2009, 07:14 PM   #1
Points: 9,279, Level: 64
Points: 9,279, Level: 64 Points: 9,279, Level: 64 Points: 9,279, Level: 64
Activity: 2.8%
Activity: 2.8% Activity: 2.8% Activity: 2.8%
Send a message via Yahoo to WhiteMaxima9600
STARTER RELAY QUESTION
I've posted about my prob. already and im pretty sure my starter relay is going out. My question is...... Where in the world do you find one? I've found many other relays but none for the starter. They have those universal type at the parts stores, but im not really sure what I can use. Any help would be appreciated!
__________________
SHIFT_ HIGH MILEAGE
96 Pearl white GLE, 20% tint, 03 17" SE wheels, Carbon fiber dash kit, Custom spoiler, Tein S-tech springs,Tokico, 12" kicker cvr, JL amp, pioneer head unit
WhiteMaxima9600 is offline   Reply With Quote
Old 05-26-2009, 07:26 PM   #2
The Dirty Pearl
pmohr's Avatar
Points: 22,165, Level: 92
Points: 22,165, Level: 92 Points: 22,165, Level: 92 Points: 22,165, Level: 92
Activity: 2.5%
Activity: 2.5% Activity: 2.5% Activity: 2.5%
Are you referring to the inhibitor relay or security relay? Basically, the grey one in front of the battery, or the black one in the box on the right?
__________________
A32 CEL Decoder | FSMs | Howto Videos
pmohr is offline   Reply With Quote
Old 05-26-2009, 08:45 PM   #3
Activity: 2.8%
I'm refering to the one in the box on the right. Actually I did not think of the inhibitor relay, where is it exactly? Would it cause a "click" or no start at all when the key is turned? That's what mine's been doing for quite a while.
__________________
SHIFT_ HIGH MILEAGE
Old 05-26-2009, 08:48 PM   #4
The Dirty Pearl
pmohr's Avatar
Activity: 2.5%
Quote:
Inhibit relay is in front of the battery:
Click the image to open in full size.
You likely wouldn't hear it click at all, not from inside the car. Same with the security relay.
I would imagine you've got some bad/corroded connections to the starter if you're occasionally getting clicks, or more likely a bad solenoid.
__________________
Old 05-26-2009, 09:08 PM   #5
Activity: 2.8%
Well, the starter has been replaced once. I thought it might be the solenoid but I wanted to try the relays first. It mostly just makes a audible "click" the first time you turn the key after that does nothing. Half the time it fires right up, the other times you have to turn the key 2-10 times before it kicks the starter in.
I did replace both terminals and cleaned the all starter connections but it did not make a diff.
__________________
SHIFT_ HIGH MILEAGE
Old 05-26-2009, 09:10 PM   #6
The Dirty Pearl
pmohr's Avatar
Activity: 2.5%
Ever replaced the ignition switch?
__________________
Old 05-26-2009, 09:14 PM   #7
Activity: 2.8%
No i have not, I considered that as a culprit but since I was at least getting "clicks" I figured the power was getting through the switch.
__________________
SHIFT_ HIGH MILEAGE
Old 05-26-2009, 09:16 PM   #8
The Dirty Pearl
pmohr's Avatar
Activity: 2.5%
If you can get a multimeter out when it's doing the no start thing, you could try to rule out components one by one.
__________________
Old 05-26-2009, 09:22 PM   #9
Activity: 2.8%
Funny thing as long as I keep the multimeter it will never do it. Do you know where I can find those relays at??
__________________
SHIFT_ HIGH MILEAGE
Old 05-26-2009, 09:27 PM   #10
The Dirty Pearl
pmohr's Avatar
Activity: 2.5%
Personally I would just go to a junkyard, all you really have to do is bring a battery, some wire, and a multimeter to test them (IIRC a 9v battery should trip them no problem). As long as it's the same color, you can grab a relay from pretty much any Nissan.
That, or the classifieds here. I have no doubt any of the people who part out cars regularly (Teaner, Maxima_Joe, etc) have a big stash of them.
Auto parts stores should be able to special order them.
FWIW, should you want to buy them brand new...
Inhibitor relay:
25230-C9962, $21.96 each at Courtesy
The security relay has many different options, so can't give you an exact part number on that one.
__________________
Old 05-26-2009, 09:30 PM   #11
Activity: 2.8%
ok, thanks pmohr. You've been most helpful.
__________________
SHIFT_ HIGH MILEAGE
Old 05-28-2009, 11:49 PM   #12
What is this security relay yall are refering to ? Ive R&R inhibit relay ,no help, ign switch at steering colum, no help . starting to suspect nuetral safty switch , am i missing a relay maybe?
pepylepew1961 is offline   Reply With Quote
Old 05-28-2009, 11:51 PM   #13
The Dirty Pearl
pmohr's Avatar
Activity: 2.5%
Quote:
If you're going to ask for help about your issue, it would help you out a lot to do it all in one place.
Preferably the correct place, the newbie thread.
__________________
Old 05-31-2009, 08:47 PM   #14
´96 Maxima 3.0 QX (V6 24V Automatic) doesn´t crank at all. You turn the key and the ignition relay (on the fuse panel) can be heard. If you open the hood and turn the key I think you hear the INHIBIT Relay (before I thought it was the fuel pump relay).
I don´t think the problem is on the ignition switch because every single time I turn the key I hear the ignition relay. Everything else looks like to work fine (radio, fan, lights, ...) but the starter doesn´t want to kick. I am pretty sure the battery is fine and the A/Theft light also blinks as usual. The lights on the console are normal (airbag light goes off after some seconds, and the rest stays including the “engine check” light). I doubt it is the starter because I never had a problem with it before (always starts easily).
I had some problems with the grounding in the past but I do not think it is that, maybe I am wrong. I hope it is the inhibit relay but I do not know how to test it; with a multimeter maybe?, how?. Could it also be the fuel pump relay?, where is it located?.
Any ideas?, I am puzzled and I really need the car!. Thank you very much.
RUDDER is offline   Reply With Quote
Old 05-31-2009, 08:50 PM   #15
The Dirty Pearl
pmohr's Avatar
Activity: 2.5%
Quote:
Originally Posted by RUDDER View Post
´96 Maxima 3.0 QX (V6 24V Auto) doesn´t crank at all.You turn the key and the hear ignition relay (on the fuse panel) can be heard. If you open the hood and turn the key I think you hear the INHIBIT Relay (before I thought it was the fuel pump relay).
I don´t think the problem is on the ignition switch because every single time I turn the key I hear the ignition relay. Everything else looks like to work fine (radio, fan, lights, ...) but the starter doesn´t want to kick. I am pretty sure the battery is fine and the A/Theft light also blinks as usual. The lights on the console are normal (airbag light goes off after some seconds, and the rest stays including the “engine check” light). I doubt it is the starter because I never had a problem with it before (always starts easily).I had some problems with the grounding in the past but I do not think it is that, maybe I am wrong. I hope it is the inhibit relay but I do not know how to test it; with a multimeter maybe?, how?. Could it also be the fuel pump relay?, where is it located?.Any ideas?, I am puzzled and I really need the car!. Thank you very much.
First, black text on a dark background...
Second, have you tried cranking in any gear position other than Park or Neutral? Wiggled the gearshift around in Park?
Have you tried bypassing the inhibitor relay? Checked all fuses?
__________________
Old 05-31-2009, 09:18 PM   #16
I tried to crank on all gears and also wiggled the gearshift and the car itself. Do you think can be a sensor or the neutral switch?
I checked all the fuses and I was thinking on bypassing the relay but I do not know what the inhibitor relay is for and what could be damaged if bypassing it. Should I bypass it then without any caution?
Old 05-31-2009, 09:20 PM   #17
The Dirty Pearl
pmohr's Avatar
Activity: 2.5%
Let's keep this to the newbie thread, better than conversing across multiple threads.
__________________
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
