Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 05-12-2009, 06:14 PM   #1
Stupid oil changer
He put about 5 quarters after draining the old engine oil (filter also replaced).......will be there any dangerous problem that needs immediate interaction?
I discovered that after I returned home and checked the dipstick ...
mahanddeem is offline   Reply With Quote
Old 05-12-2009, 06:37 PM   #2
JwaxMax99's Avatar
See, that's why you change your own oil!
(drain a little out)
__________________
NO, my car does not burn a drop of oil, and after 5K the oil still LOOKS clean!
JwaxMax99 is offline   Reply With Quote
Old 05-12-2009, 06:43 PM   #3
The Dirty Pearl
pmohr's Avatar
Your engine can't run on 5 quarters.
It's only 3/4 quart overfilled, it won't cause any immediate or extreme damage. Just drain out the extra when you get a chance.
__________________
Quote:
Originally Posted by 2damax View Post
This jerk is right so often I just search threads hoping he gets something wrong so I can catch him
Quote:
Originally Posted by kizzmyazz View Post
ok so what i found out is that because of the FMU, i dont need to get injectors because it will neutralize the oil pressure to prevent detotnation
FSMs | A32 CEL Decoder | Howto Videos
pmohr is offline   Reply With Quote
Old 05-12-2009, 06:46 PM   #4
or the 167k engine will burn it in 1 month
Old 05-12-2009, 06:48 PM   #5
JwaxMax99's Avatar
Quote:
It's not 5th gen 3.5L.
__________________
Old 05-12-2009, 08:46 PM   #6
...........something funny...idiots mechanics
Old 05-12-2009, 08:48 PM   #7
JwaxMax99's Avatar
...but you continue to take your car to these idiots?
__________________
Old 05-12-2009, 09:18 PM   #8
Quote:
F u c k me if I will again
Old 05-12-2009, 09:19 PM   #9
JwaxMax99's Avatar
Good answer!
__________________
Old 05-13-2009, 12:49 AM   #10
haha. I suggest you go and **** them!
__________________
Signature pictures are to be no larger than the allowed size of 550 x 325 pixels
tosheto is offline   Reply With Quote
Old 11-03-2009, 11:42 PM   #11
Pretty much have the same experience at last oil change. So now I am looking for used cheap jack stands, so I don’t have to deal with auto shop morons.
Does anybody know tip or trick to check level on dipstick? Every time I try to read the level it’s just guessing. I tried to remove the dipstick in lots of ways and still no luck, every time I get different reading and every time it covered in oil over the FULL mark.
VVS_75 is offline   Reply With Quote
Old 11-04-2009, 05:13 AM   #12
Search next time.
Dumb question about oil level
Is checking the oil supposed to be this difficult?
__________________
Current: AE KT3 MT | 5.5 HIDs | Fog-Light Rewire
Old: 96 KH3 MT | Fog-Light Rewire (sold 11/9/09)
AEMAXIMA01 is online now   Reply With Quote
Old 11-04-2009, 09:00 AM   #13
Send a message via AIM to pavelsmax
In my stock ride height 95 gxe I can change my oil without jacking it up at all. Its tough and much easier if you remove the right front fender splash gaurd but possible.
__________________
Heated black leather | I30 headrests | I30 auto dimming mirror | I30 door handles | LED interior | OEM fogs | OEM wood trim | Custom Sirius | SE wheels | 99 Headlights | Clear corners | Red Rear Turn signals | Optima Battery | Roof Rack | OEM FTW!
pavelsmax is offline   Reply With Quote
Old 11-04-2009, 11:21 AM   #14
Check your oil first thing, before starting or running the engine. Pull the dipstick once, wipe clean with a paper towel, reinsert dipstick all the way in, then pull back out and read level. To change the oil - have synthetic 10W30 and a filter on hand. I run engine to normal op temp then run up on ramps, have a fram quick change drain bolt valve installed already and mines done in 20 minutes tops. Beats going to the idiot-hut-oil- change-overfill-to-cover-my-a$$-place. Had enough of that...
__________________
97 Super Black Max...
maxirob is offline   Reply With Quote
Old 11-04-2009, 12:09 PM   #15
Quote:
Our cars use 5W30.......not 10W30
Old 11-04-2009, 12:29 PM   #16
wxm
10W30 will be fine for the warm weather area.
wxm is offline   Reply With Quote
Old 11-04-2009, 12:48 PM   #17
This is a perfect example of why most orgers work on their own cars....especially basic maintence items.
I think whatever mechanic that changed your oil doesn't know how to read the specs and measure to those specs I would then then ask them to give my $$$$ back for the s*** job they did.
__________________
John 3:16---> "This is the reason why I live!"
Q8BallMAXIMA is offline   Reply With Quote
Old 11-04-2009, 02:02 PM   #18
Yes, sorry 5W30 is preferred, but here in Texas, no need for it! In fact, it's hard to find in stock anywhere 'round heh.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
