1995 Maxima help!
1995 Maxima help!
My 95 maxima has a cylinder 3 misfire. I changed the spark plugs, coil packs, fuel injectors and I ran a compression test. I don't know what to do.
Also I've been running 87 grade gas in my car for 2 months and I don't know what the previous owner used. I want to switch I've to 93 grade but will it affect the engine if there is 87 still in the tank?
+1 on oem coil and ngk plugs. Anything else will result in failure and lost money.
Try inspecting the wires that run to the coil and the injector and make sure everything is neato.
Im going to go out on a limb and guess you didnt get an OEM coil/ NGK plug as its a very easy mistake to make. However if you did, and all your wiring is correct, then you have me stumped.
Team STILLEN
08-10-2015 04:29 PM
