AC Bypass Belt with Motorstorm UDP
After putting up with the noise for over two years, I’m finally giving in and going to tackle the AC compressor clutch bearing noise. I know it is the bearing b/c I had the belt off and turn the clutch freely and can hear it squeal/grind.
Anyone know what length belt I need to bypass the AC but using a Motorstorm UDP? I’m guessing most aftermarket UDPs are similar in size so a bypass belt with an Unorthodox UDP would work too.
Subtract 7 inches from whatever belt you're using now, give it a shot.
The Unorthodox UDPs use 41.5" belts, so you'd need a 34.5" belt. Try K060345, it should be just around the right size, from what I see.
05' MaximaMan
10-08-2017 06:36 PM
