Easy Knock Sensor Installation! Picture Tutorial
#241
Hi guys, the Service Engine Soon light came on in my 1998 Maxima, and sometimes its solid but sometimes it flashes (typically when accelerating, but not always). I took it to autozone to read the codes and i read for a cylinder 2 misfire and a bad knock sensor. To try and fix the misfire, i replaced all of the spark plugs, while performance is now better than it was when the problem started, it still isnt as good as it used to be, and the SES light is still on and sometimes flashing. I'm going to replace the knock sensor this weekend, but since the light is still on i assume that means the engine is still misfiring. Could it be the knock sensor causing this? What should I do next? (trying to avoid paying Nissan $100 for a diagnosis).
btw, ever since the problem began, my mileage has dropped from about 25 mpg to 17ish mpg.
#242
Did my KS this evening just before sundown. 12 mil socket and 3/8 rachet was all I needed to take out the old one. small flathead to remove clip and I was ready to install the new one.
Total time: less than 20 minutes
Total cost: $10 and change for EBAY KS
Results after ECU reset: No more KS code and more power at part throttle while engine is fully warm. (Before I had gobs of grunt while it was cold that only lasted until the engine warmed up)
Next on my list is Front/Right O2 and Rear O2 sensors. EGR tube cleaning will have to wait until spring.
#244
I'm glad that I've helped so many people with this tutorial.
I'm going to be changing my KS again.. Last week my car overheated and died on me, I was hearing a lot of knock in the engine and it was very rough. I know that everyone says the KS won't cause the engine to stall.. But I'm going to try and be optimistic and hope that replacing the KS will at least allow me to drive to my mechanic and get it checked out more thoroughly..
#245
No thats not a toy, its a melted knock sensor. I feel so bad for my car for letting it overheat like that. I used a rachet this time, I had the the old one off and the new one on in literally less than 10 min. And I only got about 5 cuts on my hands and opposed to the 15+ the first time I did it.
My Maxi started and I drove it around the parking lot but I'm getting a chirping/squeaking sound from the engine, also some white smoke from the back of the engine and smoke out of the exhaust. I'm going to make a separate thread for all of this, wish me luck. And goodluck to others changing their KS's.
#247
Thor West
I just finished reading almost all of the 240 messages about changing the knock sensor. From what I read I'm not sure ( hell, I don't have a clue), what my '95's problem is. I had a light, read a KS trouble code only, and started reading about knock sensors. Then the trouble light extinguished and I've been driving it about two weeks without another trouble light. But!
For about a year my easy starting smooth running little beauty has been hard starting on the first start of the day and surging when climbing slight grades at rpms below about 2000. A local radio car guru suggested injector problems. Agressive use of my right foot causes normal great perforrmance
Have any of you seen similar problems?
#249
#250
When I do a knock sensor, and I've done many, I use the following
1/4 inch ratchet (fine tooth preferred)
Super Long (at least twelve inch) extension
1/4 inch universal swivel
Swivel 12mm socket
Expendable magnet, preferably one that you can change the angle on. Try not to have too strong a magnet.
Basically the steps are all the same, you can either bend the bracket back a little to get your hand in there, but if you've got fat hands like myself that may not work and isn't really rexommended. Use the magnet to grab the bolt after you get it loose and it falls down in the intake valley.
Remove the sensor from the harness CAREFULLY. It definitely helps to have another harness connector if you're ever at the junkyard. Mine disintegrated when I attempted to pull the safety clip from the connector. Luckily I grabbed my KS with the connector!
As far as replacing it goes, much the same as all the other info states. I personally put the bolt back in the sensor and used the magnet to weasel the sensor back onto the bolt hole, got it to catch a thread, and then forced the magnet off.
Another good thing to do, especially with any resistance spec part....test it with a meter before you use it. I got a lot of faulty parts when working for Pep Boys, so I got into the routine of doing so.
Swivel 12mm socket
#251
I just did this job on a 1998 Maxima over the weekend and was able to use a 1/4 in drive 12mm socket with a swivel and long extension to break it loose. I tried the wrench thing and did not suceed, so I changed the plan of attach. I did have to cram my hand in the small opening and the cuts and scratches are healing nicely. Thanks for all the info, it was spot on. Car now runs great after a new $8.00 part from ebay.
#252
Also, A bad knock sensor will not cause any drivabiltiy issues. It will just dial back the performance of the car a little. I bought my car with a bad KS and drove it from LA to NY. No issues. In fact it's still there right now. Of course I'm going to replace it but I'm waiting to do my 00VI/valve cover gaskets/KS/EGR/IACV all at once. Complete upper intake overhaul
DW
#253
socket method
http://www.youtube.com/watch?v=R2ntaxi7bXk
wratchet wrench
http://www.youtube.com/watch?v=fPIMO...hannel&list=UL
this dude does a lot of maintenance videos on the 4th gen, check his vids good ressources
wratchet wrench
#254
I have a cali-spec 99 i30. So I found a tutorial with much less detail and pictures and headed out to chance my KS.
The KS was hidden behind a crap load of cali crap added to the car. Took me 5 hours. I had to make custom hooks and holders out of hangers and a swivel head saved me. A socket extender with a swivel had difficulty fitting much less a hand. To remove it I got the socket there and used a clothes hanger to align the socket on the bolt and removed. Getting it back was the problem. I put the screw in the new KS and plugged it in then used hangers.
only on fed spec.
only on fed spec.
Just replaced my KS on my 96 max yesterday. getting it out was easy. I removed the air cleaner all the way to the manifold to make it easier to see things. Remove the green connector. it gives you more room.
I cut the bottom straight wire part on a metal coat hangar at either end. I electrical taped the sensor connected to the harness to one end of the cut coat hangar and taped the harness about 4 inches up as well. this prevents the sensor from spinning on the coat hangar. bend the lower part of the coat hangar so that when you insert the hangar it positions the sensor parallel with the bolt hole. You'll see once you try it. Once positioned on the bolt hole, sneak your swivel and extension over the bolt and carefully turn the bolt until it catches. took about 10 minutes. worked like a champ and no deep gashes trying to get my fat hands in the access area.
#255
Any one have any more suggestions for getting this sensor in? I've tried all of them and no joy after 7 hours.
Getting it out was easy! 5 minutes. Getting it back in I simply cannot get my hand in there and the coat hanger trick was nice but I can't get the bolt to catch.
#256
Did you try using masking tape? I was nearly in hysterics myself, when I was trying to put mine in a few months ago. Mine was only a couple hour job though. 7 hours and I would have lost it!
I used blue painters tape to hold the knock sensor and bolt in place, and then once positioned, I used two fingers (middle finger and index one on my right hand), to spin the bolt until it caught. Once it caught, I gave thanks to the Lord, and took the masking tape off before using my wrench to tighten it up!
The way I taped the bolt and KS together, I had the bolt loosely taped at the top but sticking up so it would stay in place once I started turning it with my fingers and I also had just a bit of tape on on the bottom of the KS as well.
Give that a try if you haven't already...
#259
My friend's 99 I30 however, you can't see s$%&^* because of all the emissions stuff in the way. If that's the case with you, then you have a 99 Cali spec maxima. The lower intake manifold is different too because 99 cali have swirl valves whereas 98 and lower don't, and probably 99 Fed Spec.
#260
Ohh wow, haven't been on this site in a while. I'm glad to see my tutorial is still helping people out and that the pictures are still up after almost 4 years
I'll probably be on here more often, my 98 SE I bought last year has a LOT of work to be done to get it nice.
#263
I wish I have seen your post before. I paid some $$s to the guy to replace it thinking it is not for me.
Your kindness of sharing these pictures will save money for several people who are a bit more confident and take your helpful message post.
thanks a lot for your kindness!
regards
regards
#264
#268
regards
regards
#269
Question, is there a particular knock sensor that I need to buy, a name brand that's better than another generic knock sensor? should I look for the price or make of the knock sensor company, I saw one on Amazon for about 7 dollars.
#270
thats probably the same as ebay ones, which were proven to be good on the forums
#272
Andy
#273
where did you relocate it to? I might try that if I can access the harness and pull the wire out
#275
#277
The KS is fine just the way it is. This is only a temporary solution until I install the 00VI setup this spring. When I have the old manifold off and out of the way I will remove the old KS and install the newer one (pictured) correctly.
Andy
Andy
#279
The sub-harness connector unplugs easily as it is located just to the right of the intake manifold ( if standing at the front of your car ). If you plan on relocating the KS you will want another sub-harness as well since the other end of the harness is connected to the KS under the manifold. If you are unable to loosen your original KS, odds are you will not be able to disconnect the sub-harness at that end and a new or junkyard harness will be much easier.
Andy
Andy
#280
Easy KS installation- tutorial
My '95 had the same connector in the way. I took the 10mm nut completely off, popped it out and used a zip tie to hold that sob out of my way. That little sucker kept popping out of wherever I would stuff it and ruin any progress I made. Made the job much, much easier.
A couple of other tips I realized while replacing the KS in my '95 today:
1) If you are a righty, your left hand is slightly smaller (usually). After several unsuccessful and bloody attempts trying with my right hand, I switched to the left and was in and out in 20 minutes.
2) Tired of wrenches and bolts dropping into the abyss of your engine compartment?? Stuff some cloth or paper towels into the crevices and holes around the area. I did this after losing my wrench about 5 times. Thank god I had a telescoping magnet, but after I plugged up the holes, there wasn't anywhere for things to get lost anymore.
This thread saved me hundreds. KS from AutoZone: $124.00 - KS from E-bay: $20:00. Labor quote from the shop: $250 - $300. I diy'd it in under 2 hrs. $0.00.
6. With needle nose pliers or a flathead slide the metal clip on the harness up. Don't take it off though
7.
Attach the replacement knock sensor in the harness and slide the clip down to secure it.
8. Be careful not to drop knock sensor when manuevering through the crevice. Screw in the bolt by hand. And tighten it slightly.
Job done.
You just saved yourself hundreds of dollars, and a few hours of manual labor.
7.
Job done.
