changed transmission now wont start....help please
ok, i changed my transmission 2 days ago and afterwards i get everything wired up (been 5spd swapped for 6 years now) and i go to turn the key and NOTHING just the lights in the dash and thats it. no chug-chug,nothing. i took the starter to autozone tested good. got some suggestions on how to "hotwire" the starter. starts fine that way.
so now i am at a loss, all fuses are good all connections are tight. battery is charged. i used my parts car (the wifes) to see if it was the ignitiuon switch. nope thats not it. so now i am stumped, anyone have any suggestions? my next option is to make a push button start, so if anyone has any experience in that area i would welcome that advice as well.
thanks.
thanks.
Likely it's not working now because of a wire mixup, or something else, since you just worked in the area.
problem solved. i grounded one wire. a wire which i NEVER had to ground before. and it started right up. thanks for the input everyone. it helps to have more than one mind working on a problem.
I have a question....if anyone can help me please do...I have a 95 Max (VQ30DE) swapped it's an automatic n i wanted to know if a spec v tranny would fit without major complications.
__________________________________________________ __________________
1995 Maxima
VQ30DE swap
Injen Rd series Intake
1995 Maxima
VQ30DE swap
Second, the 6MT in the Spec V? ...no. Not like it is, anyway, unless you make a custom bellhousing adapter for QR-VQ.
You could swap it in from the A33B/A34, if you want a 6MT. Or use the Spec V internals with a VQ bellhousing.
Why not just go with a 5MT? Cheaper, easier, more readily available.
sctludwig
09-01-2022 01:32 PM
03-12-2020 12:06 AM
doctorpullit
07-20-2019 09:31 PM
The Wizard
24
10-01-2015 08:47 PM
