Imagine rubbing a spoon against a cookie sheet in a circle - that's the sound i have.
Sorry for not having a recording. It is coming from the front-passenger corner of the car. It only happens when the car is moving, but not predictably. It doesn't really get louder or quieter when braking; it just gets quieter as im coming to a stop whether from braking or coasting.
Any idea what this could be?
Assuming you have SE stock wheels or some sort of spokes. You dont even have to take the wheels off or jack the car up.
squat down, look through your wheel spokes at the round metal rotor that turns with the wheel (the thing the brake pad latches onto to slow the car down). Now BEHIND that, at a slightly wider diamater is a flimsier - probably rustier - piece of metal that acts as a guard to the metal rotor. Check to see if it is loose or is possibly scraping against your rotor. If it is, stick a screwdriver between it and the rotor, and bend it away so as not to scrape.
This is just one possible thing it might be, I had a similar sound and this was the diagnosis.
That's what's most likely.
OP: Have the wheels off your car recently?
i know this is 4gen but my 5.5 had the exact same sound-was the upper shim(metal plate) in the caliper and as stated, was rubbing the rotor. I took it out as none of the other wheels had it on the max and i never left them on the alti- so eff it
litch
123
01-04-2024 07:01 PM
tarun900
19
12-20-2021 06:57 PM
AaronL
08-08-2020 10:31 AM
Need help
23
10-02-2015 08:56 AM
