Question on headlight Retro,
Im currently doing my retro,
everything is mounted on the housing just waiting to get dark to try them on the car, I have the Housing lens just tape up,
But How are you guys resealing the Headlight Housing, do you used the same
tar on the housing, or remove it and put new silicone?
I would just try to reseal them by heating up the grey silicone w/a heatgun.
If you do scrape out the grey tar.... it's gonna take at least 30 minutes per each light. It took me about an hour each. Not to mention, its a nice workout.
On the bright side, I used nissan rubber butyl sealant and it is amazing stuff. The consistency is much easier to work with than what the headlight comes with. It's so ply-able that i was able to put it onto the headlight lens and press the housing together. With a little help from some metal clamps, it sealed very well. I've redone my retro 3 times and each time the rubber butyl was easy to remove and easy to apply.
Keep in mind that the rule at 25 ft:
a 2 inch drop from the top of the projector to the lower step. I made this mistake and it was aimed too low...had to take apart my sealed retro
WAY too high.
According to kzoosho, stock headlight height is 26". That means the lower portion of the cutoff needs to be at 24"
The idea is to aim them slightly below level... if your cutoff is 5 feet off the ground, you're way above level.
AaronL
11-15-2020 11:52 AM
03VQMAX
11-10-2015 03:39 PM
sdotcarter
09-02-2015 09:53 PM
