4th Generation Maxima (1995-1999)Visit the 4th Generation forum to ask specific questions or find out more about the 4th Generation Maxima.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Install was easy...just had to get the mounting right. Well, it was finally dark out so I took some pics of the output. Here they are:
The LED reverse lights are from V-LEDs (search for vleds on ebay).
I'm going to have to recenter the license plate ones a bit more to the left. The dots on the plate are a reflection. The LED's themselves are not visible unless you're on the ground looking up at them.
Thought I'd share it with you guys in case anyone was interested in something like this.
**** NOTE: If installing in the trunk like I did, or setting them against metal, put electric tape between LED strip and metal surface. Otherwise, you'll short the strips. ****
Best thing is...those strips are cuttable. They come 4 or 5 per group...and like 5 groups per strip. You can cut off the ones you don't need to use so it's not as bright, etc.
I spliced the trunk ones to the trunk light (red wire I believe - or maybe it was purple? lol). Had to remove the rear seats and remove the rear deck lid to get to the wiring but I've done that so many time for speakers so it only took me like 20 min total.
License plate I just unhooked the stock harness, shove the wires in to the connector (didn't cut or splice anything) and then taped the crap out of it so the wires don't pop out. Been good so far.
As for mounting, I completely removed the bracket and just zip tied the lights to the bumper. You'll see where to zip tie them.
you wont get bothered with lights that bright? they are nice lookin, but where i am from i would probably get pulled over.
No. New Lexus GS's and LS's (I think) come with HID white LED license plates.
I had a cop behind me the first night I had em and he did a u-turn after realizing he had nothing to pull me over for. If anything, it helps the cops cause they don't have to get up to your bumper to read your plates hahaha.
I have to re-center the license plate strip, but I'm pleased. For $15 or whatever I spent, not bad.
they look great, thinking of getting these too, but i wouldnt put them on the license plate area, now the cops wont ever have any problem seeing your license plate.
slow down and learn your roads and where the cops hide, took me a couple of tickets before i got to know. i even know their shift changes....
Yea the road I got the ticket on, I drive it everyday at least twice and have never seen a cop. He was hiding in the garage of this house that is under construction too...sneaky mofo
One question though, are they flexible? I plan on opening a set of black bumper lights and LEDing them and was considering using these strips.
__________________ 1996 Maxima GXE "My boy blue"
TS ECU|RSB|FSTB|Leather/Heated Seats|12"sub-Alpines-Rainbow SLCs-Audison SRx2|Spoiler|5.5 Gen 17's|Custom Red Clears|Viper 771|R34 TSX Retro|5th gen muffler|300zx Fuel filter
Quote:
Originally Posted by pmohr
Oh I'll show you a dingy. A reaaaaaaaaaaal small one.
No. They are on a stiffish type of board. They have a little flex, but not enough to do bumper lights.
Google LED strips. There are a couple I also considered which were ultra flexible. I didn't use those because I knew where I was putting them and I wanted something 'rigid' that wouldn't flop around, etc. That's what she said...hahaha.
I'm actually thinking of picking up two more strips of blue and cutting them down to size to have a nice glow (not too bright - kind of like the 07-08 TL's) on when the lights are on under the dash and seats.
Also, my headunit (Kenwood DNX8120) has a couple of 'switches' options that you can connect external things to and I can enable/disable the lights via the headunit.
Gotcha, thanks!
They are 921 LED's bulbs from V-Leds (on ebay). Just search for vleds.
I would use those, but my 95/96 Maxima uses 1156 bulbs. I've heard since the bulb is at an angle in the taillight housing, the led bulbs won't produce a good output.
Thanks.
__________________
95 Maxima SE 5 Speed - 17x8 Drag Dr31 w/235/45 Falken 512, Budget Y/B pipes, H&R/GR2 drop, Stillen Kit, CAI, Painted Interior Graphite, Tint, 5K hid kit, more...
96 Maxima GLE Auto - Trunk lip spoiler, 97 SE wheels, painted interior, clear bumper lights
Ilya - did you have to put a resistor in to make your reverse lights work or is it inside the bulb? i'm asking because i got led bulbs for my front blinkers and they don't work...so i'm assuming i'll need a resistor for those (got them cheap on ebay).
Rather than make a new thread, I'll ask here. Since you mentioned the use of LED bulbs...I got a few from PepBoys before for my bumper light side marker, and it didn't work. I got one for my dome light, and it too didn't work. Any idea why that would be? The bulbs are the correct kind I know that..
But those LED Strips looks great. They come pre-wired I assume, just power and ground?
But the neons are more of a bright glow. Im tryin to light up the whole inside of my car. Are LED's strong enough?
If you get enough, yes.
Look at my cardomain. If I turn my lights on inside the car, it's as clear as day. I used 24 LED boards in my dome light and 12 LED boards in my map light.
Did you turn them around? They only work one way, but plug in multiple ways.
Yes, they come with wires. Just splice to a power, and splice to a ground.
Ahh well. Thanks for the info, I'll probably buy some of these soon! They look great!
Edit: I also just visited the site and saw this --and I was wondering if this would be useful anywhere? At first I was thinking hey this would be easy to just plug into the door light harness but then...that wouldn't work would it..because it's like male to male so to speak?
The ones I got came with such wiring. And no it doesn't work with our wiring.
Quote:
Originally Posted by maxified
Nice look. It seems that you can see your plates clearly from quite a distance.
