Need clutch mstr, slave, SS line QUICK!
Thanks to the org, have deduced my master clutch cylinder is shot - want to replace that, and the slave. Looks like many of you have replaced the hard line/block w/ a SS line. Is RTP the only one that carries the line? It doesn't look like they carry the cylinders. I've priced out the cylinders and the master ran from $360 (local mechanic) to $17.96 online (JazzPro Parts). Any advice on best place to buy reliable parts QUICKLY? I'm looking to get all ASAP as my car is inoperable. I'm in Northern VA - would appreciate any advice on line and/or parts. Also, read that many are using Dot 4 or 5.1 oil. Should I def not use Dot 3?
Thanks!
Thanks!
You can use 3/4/5.1, just don't use DOT 5.
I got a new master and slave for under $50 from RockAuto back when I did my swap, they're still working just fine.
Also, the full SS line you can get from the GD section for around $40.
Cool, thanks. I just found both for $71 from a local shop. Car won't drive so, I don't really have time to order anything. I'd like to have the SS line, though. I can't pull up anything in GD on the lines. Is there a link?
Thanks!
Thanks!
Thanks! Ordered! Going to be w/out Max another day but figure its worth it to replace soft line (LEAK!) and ancient hard line w/ stainless. Mechanic recommended as well.
04-16-2020 05:15 AM
06-06-2017 02:01 PM
