HELP- SEATS WONT MOVE, WINDOWS WONT MOVE
Like the title says, my seats no longer move(checked wires) and my windows wont go down. I know it could be a fuse or a relay but which one? I know the panel near my drivers side contains many fuses but the guidelines only shows you show little..So I was wondering which fuse number should I check for both the window/seats..Thanks alot....
98 Maxima!!!
98 Maxima!!!
Its not that hard, look on the pull off fuse cover (if you have it) and look for fuses for the interior electrical system, one might even be labeled windows or seats. Or pull them all out and check for blown ones, even that wont take more than a few minutes.
That 30 amp fuse I mentioned is actually a fusible link, it's much larger than a fuse, it's located in the underhood fuse box. It's one of the few things that will take out both the windows and the seats. How did the problem start? Were you or someone else working on the electrical system?
^My vehicle was involved in a minor car accident which resulted in me needing a left fender and door..(fuse box was slightly moved)...Alright, so if that doesnt fix the problem, worse case scenario?
My guess is that the link or wiring got moved and is not making contact so it is not providing power to those circuits.
What I did when one of my fuses went out is pulled each one and placed it back that way you'll find it. The way you can tell it is bad is if the metal part in the middle of the fuse is melted or not touching.
06-06-2017 02:01 PM
carid
09-17-2015 05:00 AM
ik95
09-16-2015 08:11 PM
