Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 11-17-2001, 01:22 PM   #1
Send a message via ICQ to Riot^
Engine code
Hi, befor anyone flames me, yes I did check the ECU descriptions for codes and did a seach.
I got a code 0803 (Absolute Pressure Sensor, but it is not in the description.
Can someone poste feedback on this please!?
What is it? where is it? How to fix it?
thank you
Riot^ is offline   Reply With Quote
Old 11-17-2001, 05:21 PM   #2
Re: Engine code
thank you
If I'm right, it'll be in the intake, just kinda shoved in a rubber grommet on the side below the filter box (atleast on my '97). Don't know how to fix it. I'd check the connection, though.
Dave Holmes is offline   Reply With Quote
Old 11-17-2001, 10:39 PM   #3
Info and testing
From Chilton manual - The absolute pressure sensor is connected to the MAP/BARO switch solenoid valve by a hose. The sensor detects ambient barometric pressure and intake manifold pressure, and sends a voltage signal to the ECM. As pressure increases, the voltage rises. The absolute pressure sensor is not used to control the engine system. It is only used for on-board diagnosis.
Testing
1. Remove sensor with its electrical harness connected.
2. Disconnect the vacuum hose from the sensor.
3. Turn the ignition swithc "ON".
4. Backprobe the sensor connector and check output voltage, from the white wire and ground.
5. The voltage should be 3.2-4.8 volts.
6. Connect a hand powered vacuum pump and apply a vacuum of 7.87in.Hg(26.7kPa).
7. Voltage should be 1.0-1.4 volts lower than the value in step 5.
8. If voltage is not within specification or does not respond as specified, check the power and ground circuits.
9. If the power and ground circuits are okay, the sensor may be faulty.
__________________
Yup that's a Stillen TYPE II wing!
Ravq is offline   Reply With Quote
Old 11-17-2001, 11:38 PM   #4
Re: Info and testing
Quote:
Testing
clee, maybe you could add this to the dct codes sticky?
__________________
'96 Nissan Cefiro VQ25DE 140kw (190hp)
My Ignore List:
KCTYPHOON
NZ Max is offline   Reply With Quote
Old 11-17-2001, 11:51 PM   #5
Re: Re: Info and testing
Quote:
Looks like I got it fixed, it seems the sensor came off a little.
Thanks to all for the input
Old 07-15-2002, 12:41 AM   #6
MaxJag's Avatar
Send a message via Yahoo to MaxJag
Re: Engine code
I'm getting this same code. Has anyone else figured out how to fix this?
thank you
__________________
2003 Maxima SE
2004.5 Infiniti G35 Coupe
MaxJag is offline   Reply With Quote
Old 07-15-2002, 07:34 AM   #7
Evil Administrator - "The Problem"
bill99gxe's Avatar
I must be the only one here who can type "0803" as a search string and come up with results.
bill99gxe is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
