Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 02-19-2009, 12:46 PM   #1
Extremely wet driver and passenger floor
yes I've searched and from what I found, it seems to be the drain hose for the sunroof.
my questions is, how to remove the A-pillar properly to get access to the hoses so I can see if they are clogged or disconnected?
will I have to remove my headliner as well?
thanks
kL
Digitized is offline   Reply With Quote
Old 02-19-2009, 01:07 PM   #2
Coolsaber57's Avatar
This thread was NOT about what I thought it was going to be about
But I thought the A-pillar just popped off like the b-pillar does?
__________________
1996 Maxima GXE "My boy blue"
TS ECU|RSB|FSTB|Leather/Heated Seats|12"sub-Alpines-Rainbow SLCs-Audison SRx2|Spoiler|5.5 Gen 17's|Custom Red Clears|Viper 771|R34 TSX Retro|5th gen muffler|300zx Fuel filter
Quote:
Originally Posted by pmohr
Oh I'll show you a dingy. A reaaaaaaaaaaal small one.
Coolsaber57 is online now   Reply With Quote
Old 02-19-2009, 01:18 PM   #3
Send a message via AIM to njmaxseltd
Clear and or inspect the hoses from the sunroof frame corners.
Pulling down the headliner helps expose everything.
__________________
As the 4th gen ages, its owners get younger.
njmaxseltd is offline   Reply With Quote
Old 02-19-2009, 01:48 PM   #4
where should I be pulling the headliner from ( don't want to accidentally rip or break nothing)
Old 02-19-2009, 02:01 PM   #5
You can't friend yourself
Kevlo911's Avatar
Corner, where it meets apillar, IIRC, I took the screws out from the sunvisor
__________________
97 Pearl White Max GLE
I has car
LED tails for sale for 97-99 as well:
http://forums.maxima.org/4th-generat...-interest.html
Kevlo911 is offline   Reply With Quote
Old 02-19-2009, 02:55 PM   #6
Thanks Kevlo, will look into that..
Old 02-19-2009, 06:55 PM   #7
Send a message via Yahoo to blktalon456
Hey fellas mine is doing the same thing just not as bad as yours. It depends on how much it rains I guess. I didn't know it when I bought the car. I also had the plastic A pillars and swapped to the nice upholstered ones with the tweeter from a bose sutup and that is when I noticed it. Let me know how this works out. The hoses go down the roof line on each side right?
__________________
97 Maxx SE
Mecc Rep
blktalon456 is offline   Reply With Quote
Old 02-19-2009, 07:14 PM   #8
Send a message via AIM to Xfactor22
look for screws, but most of the stuff on maxima's just pop off with a little force.
Xfactor22 is offline   Reply With Quote
Old 02-20-2009, 12:20 PM   #9
I had that issue a while ago on the passanger side. It turned out to be a hanful of dirt and debris in the lower body compartment that blocked the drain hole underneath the sunroof drain hose. If I remember correctly, I had to remove the front splash guard to get access to that area.
shilov is offline   Reply With Quote
Old 02-20-2009, 12:33 PM   #10
Same prob here with different solution.
After carefull inspection I found the water was leaking in along the top windshield seal. Do you have any rust along the top next to the windshield? I put a bead of black RTV along the roof line windsield seal and that solved the problem. Af far as I can tell your not suposed to get water in the area where those sunroof drain tubes are. If you have bad sunroof seals water will get in there then go down those drain tubes. I soaked the top of my car with the garden hose and not a drop of water was near those drain tubes.
av8orjb is offline   Reply With Quote
Old 02-20-2009, 12:46 PM   #11
Quote:
Sawzall.
If you want to remove the a pillar trim you just grab is at the top and pull it towards you.
98maxse5spd is offline   Reply With Quote
Old 02-20-2009, 03:59 PM   #12
Thanks for all the input guys, I will definately check that out..
so far I pulled out the carpet , dried out the floor and going to go for a car wash to see where the water is coming in from..
will keep you guys posted..
one thing for sure, wow, cabin noise increased so much withouth the carpetting
Old 02-21-2009, 06:06 PM   #13
Quote:
So do I need to remove the inner fenderwell? Also where do the hoses exit the car at? Just so I know where to look. Thanks in advance.
__________________
97 Maxx SE
Mecc Rep
Old 03-10-2009, 11:21 AM   #14
UPDATE
Well, I''ve removed the carpet, done water test and it turns out the water leaks in from off the windshield ( so when raining) and when it slides off the glass to the fender drain, most of it gets drained out to the floor, but some of the water infiltrates..
so at least I know it's water that slides off the windshield..
anyone ever have this problem? and how to fix it?
thanks
kL
Old 03-10-2009, 06:47 PM   #15
I had the same problem on my 96 maxima from Montreal, I never fixed it and ended up having my floor completly rotted out.... that and the eastern Canada winters were the demise of my old maxima I just bought a 98 on the west coast and there is not a spec of rust! ANYWHERE!!
Good luck with your leak, I would try and have it fixed ASAP before your car turns to a rust bucket like my old one!
skimax42 is offline   Reply With Quote
Old 03-10-2009, 09:02 PM   #16
Kevlo911's Avatar
Re-seal the window?
__________________
I has car
Old 03-10-2009, 10:54 PM   #17
got the same problem here in montreal canada i take the carpet out its was 1 inch deep of wather i take out the fender the wather its coming front under the windshield where is the drain plug i take some picture gonna post dem tomorow we have to fix that asap cuz the floor is starting to be rusty and by the way i not leaking from the sunroff this is driving me crazy i luv the car so much but to know ist a boat piss me off
davinator is offline   Reply With Quote
Old 03-11-2009, 07:19 AM   #18
Quote:
Originally Posted by Kevlo911 View Post
Re-seal the window?
problem is, it has nothing to do with the window..
when the water slides off the windshield, the water gets channeled into the fender drain holes..
The problem is once the water pours into the fender drain hole, 2/3's of the water will leak out from under the car, but 1/3 of it will find it's way into the cabin...
I really want to fix this cause I like my max, it still has plenty of life left and I really don't want to have to get rid of her to buy a new car..
Old 03-11-2009, 08:13 AM   #19
Kevlo911's Avatar
Ohhh, the first thing you want to do is see where it enters the cabin. Then we can go from there.
__________________
I has car
Old 03-11-2009, 08:28 AM   #20
I'll try to take a pic tonight..
Old 04-29-2009, 09:14 AM   #21
UPDATE
Water comes in from the wiper drain channel..
so water runs off the windsheild, onto the cowl and in the the channel where the wiper arms are..
that channel forms an arc so water flows to either side of the car..
currently, the water flowing to the passenger side to exit from the fender drain is leaking into the car.. anyone know how to fix this? I am unable to actually see where the water is coming in from but I know for a fact it's in the wiper drain channel..
I'll try to take pics tonight.
thanks
kL
Old 06-01-2009, 09:48 AM   #22
PROBLEM FIXED!
it was actually the fender drain channel that had rusted! wo0T!
leak has been fixed.. no more pool inside the car ( it was bad)..
time to put the carpet back in and have a little bit of sound insulation.. hahaahha
Old 06-14-2009, 07:56 AM   #23
hi i try everything but i never think about the fender drain channel can you tell me where it is and how you fix that and also did you check the passenger side cuz mine start to do it the isolator foam its a little bit wet ya will never know only by touching the carpet thanx
Old 06-28-2009, 07:37 PM   #24
I have the same problem. I inherited a 1995 Max. SE with 80,000 miles from a friend of mine. Pass side floor had about 2 inches of water in it... It would be great if you could post some pictures of the area where it leaked ....Can the wiper drain channel be removed, its plastic and has a hole under each wiper arm. Once this is done I will see why It's running on only 5 cylinders.
thanks
HW
GT-40 is offline   Reply With Quote
Old 06-28-2009, 08:40 PM   #25
subscribed
Kadantsev is offline   Reply With Quote
Old 07-02-2009, 03:48 PM   #26
O.k.. these are not my pics nor does it show the passenger side, but it's the same..
The water flows down the windshield and into the wiper channel... the wiper channels the water into the fender channel ( in the frame of the car) which then channels the water out from the under side of the car.. throughout the years and moisture, the channel will rust/ rot due to water sits there until it's drained..
The following picture shows where to access that leak/ rusted/ cracked channel
Notice, the owner of this maxima had to cut open the access bigger ( when you take off your fender , you will understand)
once the opening is cut bigger ( I cut mine diferently by preserving the bevelled surface to preserve the frame structure) you will be able to see what rusted/ cracked surface I was refering to.
Now in these pics, the owner used a piece of aluminum and tar and silicone to cover/ patch the hole..
I used plastic metal to fill in the hold/ crack and then used a rubber guard spray to coat the whole surface to make sure the water doesn't get onthe plastic metal ( it's like putty , but hardens)
again these are not my pics, but this is what I used to guide me to fix my leak.
anything happens to your maxima while performing/ following this repair is to your own risk.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
