Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Sign in using an external account
Register Forgot Password?
Register Photos Classifieds FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Sponsored by: FCP Import
Click Here
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 02-15-2009, 04:12 PM   #1
1995 maxima very hard to start when cold and have 2 codes..p0400 and p0325?
Hey guys My 95 runs perfectly but its hard to start at first attempt in the morning(cold start) or if I let it sit for half of day. I have these 2 codes p0400(egr flow malfunction) and p0325(knock sensor). Could any of these contribute to the cold start problem? I am assuming I have to change the pesky little knock sensor due to the code...is there only 1 of these knock sensors? On the egr do I replace the egr or?? Thanks in advance.
porshapower928 is offline   Reply With Quote
Old 02-15-2009, 07:50 PM   #2
Points: 5,956, Level: 50
Points: 5,956, Level: 50 Points: 5,956, Level: 50 Points: 5,956, Level: 50
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Send a message via AIM to ZaxWhite97Max
Quote:
Knock Sensor
ZaxWhite97Max is offline   Reply With Quote
Old 02-15-2009, 08:25 PM   #3
Hello Thank You for the reply. Are you saying the knock sensor is causing the hard to start problem and throws the egr code on as well? Thanks again
Old 02-15-2009, 08:28 PM   #4
Activity: 0%
Wrong Sensor
Old 02-15-2009, 08:41 PM   #5
Although I dont hear any knocking(sounds perfect cranking) the knock sensor is detecting it?
Old 02-15-2009, 08:43 PM   #6
Willing to learn
oldngivout's Avatar
Points: 8,781, Level: 63
Points: 8,781, Level: 63 Points: 8,781, Level: 63 Points: 8,781, Level: 63
Activity: 1.2%
Activity: 1.2% Activity: 1.2% Activity: 1.2%
Quote:
Originally Posted by ZaxWhite97Max View Post
In short it's falsly sensing knock which won't allow your car to start.
It could be something else though? But most likely that.
That's nonsense. You can take your knock sensor out and flush it, car will still start just fine. You have other issues. And it's not the EGR either. Flow issues usually mean there isn't any EGR flow. Does not affect starting.
oldngivout is offline   Reply With Quote
Old 02-15-2009, 08:45 PM   #7
GOT RETROFIT?
Points: 15,372, Level: 80
Points: 15,372, Level: 80 Points: 15,372, Level: 80 Points: 15,372, Level: 80
Activity: 6.5%
Activity: 6.5% Activity: 6.5% Activity: 6.5%
I have those same 2 codes. They've been there so long that I don't even care bout them anymore.
ChrisMan287 is offline   Reply With Quote
Old 02-15-2009, 08:55 PM   #8
Activity: 0%
Quote:
You are right, I'm sorry. I got that and a crank shaft senor changed at the same time, tend to get the two mixed up. not sure why or how though.
EGR will not do anything. a lot of people don't even run it.
Old 02-15-2009, 09:05 PM   #9
Thanks everyone for the replies. Basically Im wasting my time changing or cleaning the knock sensor as it has nothing to do with starting up? How about the temperature sensor does it affect cold starts?
Old 02-15-2009, 09:45 PM   #10
Points: 3,604, Level: 37
Points: 3,604, Level: 37 Points: 3,604, Level: 37 Points: 3,604, Level: 37
Activity: 0%
okay i would try looking at these things....since a hard starting could be anything..i would start at basic...three basic things needed for an engine to run: air fuel and spark....so i would check the easiest first...a really dirty airfilter could cause this....then work backwards....if not that i would check spark plugs, then backwards (coils..etc)....then injectors...follow it backwards..its a good technique...also i would suggest searching this forum...use keywords like "hard start cold" im sure ur not the only one...good luck...
__________________
If you want a photo shoot of your car lemme know, im looking to expand my experience. I'm located in the minnesota twin cities area.
ruckus1027 is offline   Reply With Quote
Old 02-15-2009, 10:12 PM   #11
Send a message via AIM to QNO_A32
YES coolant temp sensor could cause hard cold start. it can be checked with a multi meter and if needed, changed easily.
__________________
QNO_A32 is offline   Reply With Quote
Old 02-16-2009, 01:40 PM   #12
Quote:
Its relatively cheap also!
K.Hall is offline   Reply With Quote
Old 02-19-2009, 06:44 AM   #13
Points: 3,040, Level: 33
Points: 3,040, Level: 33 Points: 3,040, Level: 33 Points: 3,040, Level: 33
Activity: 0%
Send a message via AIM to flyestblackmax
change both sensors when the knock sensor goes bad ur car runs like shyt my motor was knocking and stumbling and other stuff
__________________
The maximum allowable size for a signature on maxima.org is 550 pixels wide by 325 pixels high including image and text.
flyestblackmax is offline   Reply With Quote
Old 06-28-2009, 06:32 PM   #14
My '95 is hard to start cold. Starter spins fine, engine tries to catch up but will not. Had the temp sensor changed last winter (code for this showed up). Did not help the cold starting though.
This thread is a little convoluted, but I believe everyone is saying it could be the crankshaft sensor?
John
"Revenge is what separates us from the animals"
Al Bundy
amixam is offline   Reply With Quote
Old 06-28-2009, 06:54 PM   #15
The Dirty Pearl
pmohr's Avatar
Points: 21,102, Level: 91
Points: 21,102, Level: 91 Points: 21,102, Level: 91 Points: 21,102, Level: 91
Activity: 7.8%
Activity: 7.8% Activity: 7.8% Activity: 7.8%
John
Well...codes? Always something you need to mention when asking for help.
Did you do anything, have anything done, or did anything happen to the car immediately prior to this hard cold start happening?
__________________
A32 CEL Decoder | FSMs | Howto Videos
pmohr is offline   Reply With Quote
Old 06-28-2009, 08:58 PM   #16
Points: 6,277, Level: 51
Points: 6,277, Level: 51 Points: 6,277, Level: 51 Points: 6,277, Level: 51
Activity: 0%
Did you check your battery ? Starter ?
Might be coolant temp sensor "ECTS", I have one for sale if you need it.
I don't see any relation between your codes and the starting issue.
I would start by bringing the battery to Autozone or whatever to get it checked.
matrix11229 is offline   Reply With Quote
Old 06-29-2009, 06:37 AM   #17
The engine code light is not on. It was when I had the coolant sensor replaced. Could there be a code without the light being on?
Fuel filter has been replaced fairly recently. Just happened gradually. I wasn't asking for a diagnosis, just exploring the possibility of the problem being the crank sensor.
John
Old 06-29-2009, 09:11 AM   #18
The Dirty Pearl
pmohr's Avatar
Activity: 7.8%
John
Then sure, it's possible.
__________________
Old 06-29-2009, 02:12 PM   #19
I don't see how anything MORE than possibilities could be given here.
John
___________________________________________
"Never fight an ugly person-they don't have anything to lose"
Charles Barkley
Old 07-10-2009, 07:14 PM   #20
Alright, guys, here's what fixed my hard to start cold '95 Maxima: ignition switch.
When the problem first started, my wife kept telling me I just didn't know how to start it. What she was doing was turning the key really hard, and it would fire right up. I read on another forum some guy's Maxima had the same problem and he found the switch was at fault.
Considering everything, I felt this had to be it. Bingo.
Just to pre-empt someone coming along and telling me that this was on "Maxima.org" somewhere, and I just didn't read enough, I don't have time to read every word posted here, or anywhere else for that matter.
And for whomever wrote "all 95's are OBD II", or something similar, it just ain't so. My '95 is not OBD II.
John
"say it ain't so, Joe"
Old 07-10-2009, 07:15 PM   #21
The Dirty Pearl
pmohr's Avatar
Activity: 7.8%
What brings you to this conclusion?
Also, production date?
__________________
Old 07-10-2009, 07:44 PM   #22
Willing to learn
oldngivout's Avatar
Activity: 1.2%
We old timers love when the newbies come on here and tell us what is what!
__________________
Unless you do it exactly like I did, your results may vary.
Old 07-11-2009, 04:15 AM   #23
"old timers"?? You might look at my join date first.
John
Old 07-11-2009, 04:36 AM   #24
Three highly qualified technicians.
Doesn't matter, it's a 1995. VIN code 'S'. The statement was "all 1995's are OBD II", or something to that effect. It didn't say "with some exceptions" or "except early models", or any other disclaimers. It said that all 1995 Maximas were OBD II.
I will get the production date as soon as possible. It probably is an early production.
Look guys, I came here looking for a solution to a problem. I asked a simple question-could it be the crank sensor? I saw no need to go into a detailed explanation when I had had all the logical things done or checked.
One question-was it possibly the...? and I get a bunch of static. I, despite this, once again posted with what turned out to be the solution to my problem, hoping that it might help someone else, and again-static.
"Old timers" who evidently are on a mountain somewhere...12,000 posts does not make one an expert, just a proficient typist. Not to say that they are NOT experts.
John
__________________________________________________ ___
“…and sometimes he saw an enormous disk of ocean, a cold, uneasy sea, endless miles of desolation, the comfortless element in which he was at home.”
Patrick O’Brian
Old 07-11-2009, 09:43 AM   #25
The Dirty Pearl
pmohr's Avatar
Activity: 7.8%
That's not how, that's who. As was in my sig, the DLC is not in the OBD-II mandated location, it's on the passenger side of the car by the ECU.
I do hope these three 'highly qualified technicians' weren't mistaking the CONSULT port for OBD-I or similar.
I never said 'with exceptions', I was asking for the production date out of curiosity. In any case, I can all but guarantee you that there is an OBD-II DLC in your vehicle.
__________________
Old 07-11-2009, 10:40 AM   #26
ColombianMax's Avatar
Points: 11,463, Level: 70
Points: 11,463, Level: 70 Points: 11,463, Level: 70 Points: 11,463, Level: 70
Activity: 0.6%
Activity: 0.6% Activity: 0.6% Activity: 0.6%
Send a message via AIM to ColombianMax
John
Patrick O’Brian
I hate how "highly trained technicians" are "always" right. I got my 95 last June and wanted to get OBDII reading and all these "highly trained technicians" told me the exact same thing they told you. Went home, looked up on org, found post by pmohr stating they were all OBDII, went to Idiotzone and got it checked...actually almost couldn't convince the idiots to come out to the parking lot cuz they kept insisting it was a 95 and it did not have OBDII. Not that it matters as stated above but my 95 is probably one of the earliest 4th gen if not the first batch made. I believe its 07/94
__________________
SHIFT_I cant it's Automatic!!
1993 Maxima GXE Super White, Ebay FSTB, 97-99 SE Rims, KYB GR2s, BlehmCo Lower Tiebar, BlehmCo Parallel Link Kit, BlehmCo RSTB, BlehmCo Swaybar Links, Addco RSB, z31 rear disc upgrade, Assurance TripleTreds.
1995 Maxima GXE-5 Dark Blue Pearl, 03 SE TE RIMs, I30 leather w/rear headrests, KYB GR2 on Progress springs, Progress RSB, ES Poly in front end suspension,WarpSpeed YPipe, Pioneer InDash Navi, Kzoosho LED tails and FX35 HID retrofit
2002 Maxima SE 6spd Sterling Mist, adjustable Tokicos on H&Rs- stock
ColombianMax is offline   Reply With Quote
Old 07-12-2009, 09:54 AM   #27
That darn P0325 Code is really annoying. There is only one Knock Sensor, located under the Intake Manifold. It is pretty hard to get to although manageable. Try some swivel extensions.
HoustonSE99 is offline   Reply With Quote
Old 08-07-2009, 11:20 AM   #28
On my 1999 Max SE the no flow code(po0400) turned out to be a blocked EGR tube on the back of the engine block going into the head. As to the hard to start I replaced the PCV valve, cleaned the Throttle body and the IACV ( Idle Air Control Valve). worked for me.
Gary
bettsgt is offline   Reply With Quote
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
