99 Only, Do you have rear deck rattle? I think i found the problem...
i just took apart my back seat due to constant annoying rattle in the rear deck in normal driving conditions. It turns out the middle seat belt mechanism is the source of the rattle.
As you can see i attempted a temporary metal-to-metal contact fix with duct tape. Had several layers around the speaker openings and the middle seat belt opening, hell, even in-between the seat belt mechanism itself. Didnt help much. I think its the weight of the unit itself that makes the whole center of the rear deck heavier and easier to wobble.
I tested the rear deck with everything removed; Speakers and seat belt mechanism. I then banged it with my fist to mimic the bounce of the rear end when driving over uneven roads. No noise. I installed one of the speakers, repeated the process, No noticeable noise. 2nd speakers, etc..No Noise. I installed the middle seat belt housing...pounded on rear deck and voila! Noise Appears. So...this is where i duct taped the hell out of everything that touched metal but no luck.
Any suggestions?
Edit: to the right, above the middle-seat belt, you can see a X shape covered in duct tape. Thats covering up a lot of holes and slots cut out into the rear deck. I dont know their purpose but it seems to make that area weaker. You can see the uncovered version by looking at the first picture, its opposite side isnt covered with tape, but you can see the slots im talking about.
Any suggestions?
I dont have a rattling in the rear. I do have a bad rattle from the plastic that covers my gauges. If I am on a back road it is terrible. I slightly lay my hand across it and it goes away. Any ideas on fixing that?
My personal recommendation to him over AIM was to remove the '99 style center belt and hardware and install a '95-'98 style. This assumes the mounting points for the older style belt are still on the chassis, but shady seems to think they're there (I haven't seen a picture and I personally own a '98).
Seeing as I don't know what the rear deck looks like on a '99, I'm just making a guess here, but, the method I suggested may then leave a hole in your rear deck where there is no longer a belt setup.
Yep, I'm going to drive around with all that junk tape i've put on there and see if its quieter than before. If that fails, im planning on removing it entirely when i do my sound deadening install.
Kinda sucks, that middle seat belt was a nice feature :P
My rattles gone. Only thing i hear now is my change in the ash tray.
I added some hard cardboard around the rear deck and taped it all down and through the slots to stiffen it up. Seems to have done the job....temporarily.
Or wedge something between the clear plastic and the cluster trim...
Subscribed for the deck rattle. I've got it too.
raywluce
02-20-2024 02:18 PM
jskirwin
06-08-2016 08:49 AM
Huttig2009
09-25-2015 03:31 PM
