Prepping for Roadtrip
Old 02-03-2009, 08:29 PM
riccohou's Avatar
so im making a big move soon and i was wondering what kind of prepping i should do right before the trip. its a 1500 mile trip. ive been on ALOT of road trips before but never in a car of mine, so i dont know what people check before making there journeys. anyone?
riccohou is offline
Old 02-03-2009, 08:36 PM
vQmaxii's Avatar
oil, tire pressure, air filter etc
vQmaxii is offline
Old 02-03-2009, 08:52 PM
No more Maximas...
pmohr's Avatar
Just jump in and go
Of course, you should be giving the car a lookover every so often, so...
pmohr is offline
Old 02-03-2009, 09:06 PM
riccohou's Avatar
yeah i was gonna just jump in and go. lol. but ive never taken my car on a road trip so i wasnt sure if it was that simple. but i guess it is. i just got a full tune up about 300 miles ago so im good on that. and what do u guys usually set ur tire pressure to? i have mine at 32.
riccohou is offline
Old 02-03-2009, 09:08 PM
No more Maximas...
pmohr's Avatar
Just set them to factory spec.
Before a roadtrip, I just throw a few gallons of water in my trunk, make sure I have my tools, floorjack, and AAA card (just in case). That's all I've ever needed to make the trip to TN and back the last 10 times.
pmohr is offline
Old 02-03-2009, 09:11 PM
EEMaxima's Avatar
This isn't the '50s when breakdowns were common. Just check the tires, change the oil and off you go. Have a good spare in the trunk just in case.
EEMaxima is offline
Old 02-04-2009, 05:59 AM
allensteiner21's Avatar
depends what states/road conditions you'll be going through. i set my all season tires (195/75/15 iirc) at 35 for the winter roads (wet/snow traction) and my summer tires (245/45/17) at 45 for less sidewall flex (dry traction) and mpg.
allensteiner21 is offline
Old 02-04-2009, 06:01 AM
loxety's Avatar
Jumper cables, bottle of coolant, a quart of oil, flashlight, twine, windshield fluid, and double check the pressure your spare tire (should be checking once a month).
I set my tire pressure at 40lbs. I get 2-3+ MPG more but the trade off is that I feel more of the bumps in the road. Cost vs. comfort
loxety is offline
Old 11-26-2009, 05:18 PM
riccohou's Avatar
sorry to bring back an old *** thread. but i made it flawlessly. im a resident of houston tx. lol
riccohou is offline
Old 11-26-2009, 10:14 PM
aackshun's Avatar
From where? I drive between KS and TX 6x a year, car runs fine....
Welcome to Houston!!!!
aackshun is offline
Old 11-27-2009, 06:32 PM
lisa1999maxima's Avatar
will not start
I have changed the fuel pump, cam sensor, crank sensor and I have fire and gas to everything and it will crank but will not run what else can I do? Please help me
lisa1999maxima is offline
Old 11-27-2009, 09:14 PM
Leo_Koneval's Avatar
EDIT: Sorry I only read the first post and didn't see that the author had already made the trip LOL
Hmm... 1000+ miles you say? This might be a over the top but here is a list my family uses whenever we travel to California.
1. 1 quart or 1 gallon of engine oil
2. 1 gallon of coolant
3. Bottle of windshield fluid
4. Check tire pressure
5. Bring spare tire, jacks, lug nut remover
6. Spare battery
7. Flash light
8. Check air filter
9. Check fuel filter
10. Jumper cables
11. Water/Food
12. Duct tape
13. Temp tire sealant bottle
14. Spare tail light, headlight bulbs
I believe if your car is in good shape, like not consuming oil does not have codes for major things, and doesn't consume coolant, then you only need at least the jacks, spare tire, and lug nut remover, and duct tape.
But make sure you have duct tape, because it is a life saver! Several, SEVERAL years ago, on our way to California we stopped at a hotel for one night and in the morning someone had smashed the drivers window and stole our camera case sitting in the car, luckily we took the camera into the hotel to take pictures and so all they got was the spare battery, extra film, and ect. But we used duct tape to temporarily seal up the window until we got back to Washington to fix it.
Leo_Koneval is offline
Old 11-28-2009, 11:51 PM
DIAMONDS98SE's Avatar
a concern i have before taking my max on a road trip is the rpms. when im in 5th gear on the highway, im over 3000 revs doing 65 or 70. it seems cruising at 3-4k would be hard on the engine for extended periods of time. let me know if im paranoid
DIAMONDS98SE is offline
Old 11-29-2009, 02:38 AM
shadyonedeath's Avatar
6. Spare battery
7. Flash light
8. Check air filter
10. Jumper cables
11. Water/Food
12. Duct tape
...where do you keep your luggage?
shadyonedeath is offline
Old 11-29-2009, 03:23 AM
In my pocket
And also, the family doesn't use my car for road trips LOL, that is what the Lexus SUV is for, I don't trust my car enough to take it 1000 miles, even though it has no codes and doesn't consume oil or anything
Old 11-29-2009, 03:57 PM
nymax99se's Avatar
i just came back from Florida with my 99 and no problems going or coming back...(pre trip)I had my mechanic check the engine and suspension,my tires a few months old brakes are not new but still in good condition...no overheating no nothing.
its a maxima it will last.
nymax99se is offline
Old 11-29-2009, 04:01 PM
ceboyd's Avatar
lol.. we are about to drive our newly purchased 97 from phoenix to chicago the long southern route to see sights along the way right after new years (tombstone, carlsbad caverns, white sands, etc.)
ceboyd is offline
Old 11-29-2009, 04:37 PM
tyler5619's Avatar
Originally Posted by pmohr
Just jump in and go
ain't you ever seen Final Destination?
lol.
tyler5619 is offline
Old 11-29-2009, 04:52 PM
aackshun's Avatar
Over 6 years (95-01) Nissan made the Maxima knowingly well that it would be doing that for extended road trips, I just lay my faith on to the engineers who had the foresight to design such a short 5th gear that they knew the engine would be kept there for extended periods of time.... Wait... 3k is 74mph and 3.5k is 85mph, you shouldn't be cruising any higher than that anyways....
aackshun is offline
Old 11-29-2009, 04:59 PM
tyler5619's Avatar
^^ am i the only one running at 3k at 65?
sheesh, something is wrong with my car.
Old 12-01-2009, 03:51 PM
Im leavin work in 30 minutes. ill see what speed is at 3k. i think its around 60 or 65. ill post when i get home
Old 12-01-2009, 06:15 PM
HandsonMaxima.'s Avatar
i have an RPM digital display in my car,
70@2.8kRPM
approx.
but on my road trip i did not go below 80 from Ohio to Florida 16 hours straight, still got 28MPG with a busted coil halfway down.
HandsonMaxima. is offline
Old 12-02-2009, 10:41 AM
aackshun's Avatar
http://www.zealautowerks.com/transcalc.php
http://www.vibratesoftware.com/html_...nsmissions.htm
http://www.vibratesoftware.com/html_...rive_axles.htm
Do work son.
aackshun is offline
Old 12-03-2009, 07:32 AM
70@2.8kRPM
approx.
I guess 70mph is around 2800 rpm. My bad. just seemed a little high. i guess nissan knows what theyre doing though
Old 12-03-2009, 07:53 AM
99Maxima1714's Avatar
245 on a 17..youhave a pick of your rim and tire?? are they 17x7 or 17x7.5? that is huge and heard not very safe. I heard the biggest to go with was 235 and the best was a 225.
99Maxima1714 is offline
redmaxpa007
09-28-2002 09:05 PM
Monil
08-27-2001 04:38 AM
Paul6speed
11-28-2000 09:39 AM
Quick Reply: Prepping for Roadtrip
