Left driverside air vent stopped working
Old 01-21-2009, 12:52 PM
Crushed's Avatar
Recently just found out my left vent wasn't working after I had my heat on. Every other vent is working fine, just no heat came out of that one. Never had this type of problem before, had pretty much all of the other ones that comes with a 4th gen though. Not sure what needs to be checked or done. I haven't tried the AC yet though.
Crushed is offline
Old 01-21-2009, 02:03 PM
No more Maximas...
pmohr's Avatar
The one in the dash next to the door?
Done any work under the dash lately? Likely the tube that feeds it got disconnected somehow.
pmohr is offline
Old 01-21-2009, 02:08 PM
Quickywd01's Avatar
Did you check the "switch" that you turn to open or close that vent?
Quickywd01 is offline
Old 01-21-2009, 07:54 PM
Crushed's Avatar
nah i didnt mess with the dash any, to fix it do I have to go through the dash and not under the hood? the vent is open like the others....when I turn my air on high, I can barely feel the air coming out but it has no force behind it or something
Crushed is offline
Old 01-21-2009, 07:58 PM
klemenz's Avatar
i'm pretty sure there's a little valve that opens inside your dash that lets the air through that vent. it's probably stuck. find out how to pop the vent out of your dash and look inside it
klemenz is offline
Old 01-21-2009, 08:04 PM
No more Maximas...
pmohr's Avatar
IIRC that vent is screwed to the dash from the inside.
Why would you go under the hood?
I would say it's the vent door, but if that were closed I don't believe you'd be getting air out of any of them.
pmohr is offline
Old 01-22-2009, 12:30 PM
nitromax's Avatar
just a stab in the dark...did you try to turn the little wheel under the vent? that's the
airflow on/off.
nitromax is offline
Old 01-22-2009, 03:02 PM
fat_kid's Avatar
+100
fat_kid is offline
jerrod99_se-l
08-27-2015 08:27 PM
MidnightMaxima_22
08-19-2015 01:01 PM
kirkhilles
08-08-2015 10:53 AM
kenc15
08-05-2015 08:29 AM
Quick Reply: Left driverside air vent stopped working
