Transmission Trouble
Old 01-17-2009, 12:02 PM
XAugusta MoonX's Avatar
So I recently had a transmission leak. It was pretty bad, due to the axle all but falling out. Anyway, I drove about 300 miles topping off the transmission constantly (Had no choice). So I finally fixed the axle and there's no leak. Transmission is topped off. The problem I'm having is going into gear. Sometimes it will let me get into 2nd or 4th and sometimes I can't get into any gear. I have to force 1st and 3rd and sometimes even that doesn't work. It doesn't matter what I do with 5th, it won't go in. Reverse sometimes works and sometimes doesn't. Is my tranny done?
XAugusta MoonX is offline
Old 01-17-2009, 01:38 PM
Maintenance Monster
dgeesaman's Avatar
Sounds like a fragment of something is loose and inside the tranny. It will tend to fall to the bottom of the trans case and block the shifter mechanism. (I know from experience - a piece of the speedo gear once did that and I got the same symptoms you have).
Drain the oil and maybe you can find the loose piece though the position sensor opening.
dgeesaman is offline
Old 01-17-2009, 01:53 PM
So would a broken tooth or anything like that cause me to have to replace the transmission?
Old 01-17-2009, 01:59 PM
No more Maximas...
pmohr's Avatar
Chances are you didn't break a tooth off of a gear, you'd definitely notice that (assuming it was a gear that you can actually get into, that is).
It wouldn't require replacing the trans, but depending on how much you're willing to pay, a replacement is generally cheaper than a rebuild.
pmohr is offline
Old 01-17-2009, 03:06 PM
Well, update: Shifter just broke. Pretty sure it's at the linkage where the actual shifter and shifter linkage combine underneath the car over the cat. I'm gonna get it back into the air and see if that's true. Stuck in 4th gear now.
Old 01-17-2009, 04:48 PM
Any thoughts?
Old 01-17-2009, 08:02 PM
Llfe's Avatar
is your check engine light on and if so do u know the codes?
Llfe is offline
Old 01-17-2009, 09:09 PM
Haha yeah, my check engine light is on but it's only for my IACV seeing as I don't have one. My support bracket came off. That's why the shifter "broke" on me. I'm gonna try fixing that and see if it solves my problems. Anyone have tips on how to get the support bracket into the shifter linkage cause I tried for 2 hours earlier and got nowhere.
Old 01-18-2009, 04:31 AM
Maintenance Monster
dgeesaman's Avatar
Are you talking about the bracket that fits onto the rod leading into the transmission?
That is not easy to do. In most cases I need to use a press to remove that bracket from the striking rod and I only do that with the trans completely disassembled. If you heat up the bracket pretty good it may slip onto the rod easier, but make sure it stays lined up at the roll pin holes and you don't burn up the oil seal and rubber boot.
Old 01-18-2009, 09:16 AM
guygti22's Avatar
http://car-part.com/cgi-bin/search.cgi
here are some trannys for ya. sounds like yours is gone. might have overheated bearings inside or broke something. but doesnt sound good.
guygti22 is offline
Old 01-18-2009, 10:13 AM
No, it's where the shifter and shifter linkage meet. It's not anywhere near the transmission. It's right above the catalytic converter.
Old 01-18-2009, 10:30 AM
Maintenance Monster
dgeesaman's Avatar
Gotcha. That shouldn't be too hard to fix.
Dave
hcarter1112
42
07-18-2022 03:35 PM
Pied
09-26-2015 03:29 PM
zmcneely13
09-26-2015 02:26 PM
Quick Reply: Transmission Trouble
