Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 01-11-2009, 04:39 PM   #1
Super Member
TunerMaxima3000's Avatar
Strange electrical problem.. Air bag light flashing, car dies. Help needed!
1997 5spd SE (Canadian) 243,000 km (151,000mi)
Well as the story goes, I was driving today and out of nowhere as i rounded a corner the Air bag light started flashing at me, and all my indicator lights and clock, etc started to dim badly. I pulled over and checked under the hood. I was unable to find any indication of an issue. I revved the engine up and as I did the Defrost light started clicking on and off with the RPM.
I shut it off, started it again, started fine, no lights, drove around the corner and it happened again, and the car almost died.
I pulled the codes and got a 0901 (O2 Front right bank)
I just replaced the O2 6 months ago with an OEM one. I doubt this could cause my issues, but I don't know for sure.
I drove it a bit further and it died. I got a boost and it started, drove around the corner and the air bag light started flashing again and it died.
The water in the battery was a little low so I topped it up, charged the battery, and I made it home fine.
The thing that has me stumped is the Air bag light and Defrost clicking on and off.
I've been through the dead battery and alternator issues many times, and not once on this occasion did my battery light or brake light come on.
The bulbs for both are fine.
Does anyone have any ideas? I'm sending it to an electrical shop tomorrow to have them check it out, but I'm stumped here and if they dont find anything..... I hate being stranded.
Sorry for the lengthyness just trying to give as much info as I can.
What do you guys think?
Thanks,
Matt
EDIT: The Air bag light started flashing AFTER I made the turn
Also, the battery is only about 8 months old.
__________________
______________
<<'87 Z31 VG30ET (SOLD JUNE 09/09) <> '97 A32 VQ30DE (WROTE OFF FEB 12/09) <> POS '95 Grand AM for now... spare tire deal but it moves. >>
TunerMaxima3000 is offline   Reply With Quote
Old 01-11-2009, 05:00 PM   #2
The Dirty Pearl
pmohr's Avatar
Having issues with the airbag while turning seems like clock spring, losing power could be explained by the ignition switch as well.
Not sure on the defrost, though
Do you happen to have an aftermarket remote start or keyless entry system?
__________________
Quote:
Originally Posted by 2damax View Post
This jerk is right so often I just search threads hoping he gets something wrong so I can catch him
Quote:
Originally Posted by kizzmyazz View Post
ok so what i found out is that because of the FMU, i dont need to get injectors because it will neutralize the oil pressure to prevent detotnation
FSMs | A32 CEL Decoder | Howto Videos
pmohr is offline   Reply With Quote
Old 01-11-2009, 05:09 PM   #3
Super Member
The air bag light started flashing randomly, didnt seem to have anything to do with turning or otherwise. Seems more like an indicator that there's an issue and the car is going to die, but I've never heared of this before,
I'm thinking a short somewhere thats causing issues, and that would explain the battery drain.
I have no auto start or any other aftermarket system wired into the car.
I'm going out to check the stereo wiring and disconnect the fuse now, just to eliminate it as a possibility.
__________________
______________
Old 01-11-2009, 05:10 PM   #4
The Dirty Pearl
pmohr's Avatar
So it doesn't matter if you turn the wheel or not for the airbag light to turn on?
I see, you only mentioned it above specifically while turning.
__________________
Old 01-11-2009, 05:29 PM   #5
Super Member
No, it happened for the first time after the turn, but both times after it was driving straight down the road and it just started flashing.
__________________
______________
Old 01-11-2009, 06:55 PM   #6
Sounds like it may be a battery or battery connection problem. Make sure both posts are clean and secure. Airbag light will start flashing if battery voltage drops. I had this happen recently when I accidently shorted the positive post to ground momentarily.
Nopike is offline   Reply With Quote
Old 01-12-2009, 04:57 AM   #7
Super Member
Quote:
Thanks man, I'd never heared of the Air bag light flashing because of a low voltage situation, but it's possible maybe thats all it was. It's the fact that the battery light never came on, and the defrost switch wigging out that have me most concerned.
Anyways I'm taking it into the shop this morning to be safe, I'll post back what they find.
__________________
______________
Old 01-13-2009, 05:00 PM   #8
Super Member
UPDATE: Apparently the alternator went out of the car.... I have to wait until Saturday to take it to the shop that put the alternator in, it's under warranty.
this is the 3rd time in 2 years. There is something wrong here.
This is the first time that the battery light and brake light didnt come on, also the first time the Air bag light was activated.
This all seems very odd to me. I'll post back when I find out more.
__________________
______________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
