Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 01-06-2009, 06:42 PM   #1
99 Maxima a/c Compressor clutch
My compressor clutch is shot. I'm searching for a new or rebuilt one with no luck. Can any one point me in the right direction.
Thanks Steve
__________________
98 Black GXE 5 spd. 324,000 miles. Burns quart every 1000 miles. 99 Black GXE 169,000 5spd
Stevenjc is offline   Reply With Quote
Old 01-06-2009, 11:46 PM   #2
Is it the clutch or the compressor itself? If the compressor freeze up, the clutch would slip too.
SVI30 is offline   Reply With Quote
Old 01-07-2009, 04:11 AM   #3
It is the a/c compressor clutch. When the a/c is off you hear the bearings making excessive noise, when you turn on the a/c most of the noise goes away.
Thanks for the reply.
Steve
__________________
Old 01-07-2009, 04:35 PM   #4
Clutch is hard to find as most of the replacement compressors comes with clutch installed already.
The clutch comes off with a special tool. Kind of a "Y" with a key at each tip that fit into holes in the clutch face. Then turn the center nut to get it off. My old failed compressor is actually still around but I have no way to get the clutch off.
Old 01-07-2009, 04:48 PM   #5
Nissan has the clutch only for $425.00.
__________________
Old 01-07-2009, 05:04 PM   #6
Send a message via AIM to alg@nemobile.com
Quote:
Thanks Steve
Autozone has it for less than 300 complete won't have to rebuild anything. I just did it
__________________
Why Would you not buy a Maxima Is there a name for whats wrong with you Shift_Drive NOW
alg@nemobile.com is offline   Reply With Quote
Old 01-07-2009, 05:33 PM   #7
The Dirty Pearl
pmohr's Avatar
Quote:
FYI, your sig pic is way too big. 1024x763? 550x325 is the limit.
SIGNATURE PICTURE GUIDELINES: READ before posting a sig pic!
Quote:
Originally Posted by phenryiv1 View Post
Since people seem to have FORGOTTEN the rules...
As a courtesy to others, please avoid extra wide signatures. They are annoying to others. When your sig is so wide that it makes other users scroll to read the whole thread it is annoying and time-consuming. A good guide is 550 pixels wide at the widest. Also, please avoid extremely long signatures as well. 325 pixels will be considered the limit of signature height.
__________________
A32 CEL Decoder | Howto Videos
pmohr is offline   Reply With Quote
Old 01-07-2009, 05:49 PM   #8
Try this place. They may be able to sell you a clutch.
http://tcw-us.com/compressor_apps.as...ssan&year=1998
I got my factory compressor from Meridian in San Diego. Although clutch is not listed, it's worth a try.
Old 01-07-2009, 05:53 PM   #9
I found this in the stickys
MAINTENANCE and MECHANICAL Information- Don't Post Questions Here! (UPDATED)
Post # 50
__________________
Old 01-07-2009, 06:06 PM   #10
Yes, the compressor don't need to come off the car. You can get to it from the right side wheel well.
http://i48.photobucket.com/albums/f2.../DSCN9302a.jpg
In this pix I dismounted it to get the alternator off but left all the hoses intact.
Old 01-07-2009, 11:00 PM   #11
I just had the same problem with mine. I just replaced the whole compressor with a rebuilt one though. I found it for $145 for the reman compressor. It was from a shop in Van Nuys. If you are in so cal id reccommend you go there.
quique is offline   Reply With Quote
Old 01-08-2009, 06:08 AM   #12
it sounds like the issue is the pulley bearing.
that being the case, just the bearing can/needs to be replaced.
remove the compressor clutch plate and the pulley.
take the pulley in to a local A/C shop.
They can press out the old bearing and press in a new one.
the cost should be somewhere b/t $30 and $60.
__________________
Turbobink is offline   Reply With Quote
Old 01-08-2009, 08:44 AM   #13
I appoligize and will take care of that asap
Old 01-08-2009, 02:23 PM   #14
How am i going to find that specific bearing,I guarantee Nissan doesnt sell it.
__________________
Old 01-08-2009, 08:22 PM   #15
wxm
Stevenjc, take a look at this thread (http://forum.ih8mud.com/80-series-te...sor-noise.html). It is for LandCruiser, but on post #7, the guy specializes in a/c business. You can contact him (you might get "mud" discount if you pm him directly from the forum - mud users usually take care of each other there.). Following the thread, you may even get him to press the bearing on.
Good luck
wxm is offline   Reply With Quote
Old 01-09-2009, 05:36 AM   #16
just take the pulley to an A/C shop... they'll have the bearing.
for crap's sake... there is no factory in Malasia making A/C pulley bearings for only the Nissan Maxima to subsequently supply them only to the pulley bearing underground blackmarket.
that bearing is used on tons of cars across lots of makes and models.
the A/C shop will have it.
they may not stock it as a bearing for a '99 Maxima A/C pulley but if the one they have is the same size and type, who gives two sh@#s.
that's why you need to take the pulley to them... so they can properly size and type the bearing that's be coming out of your pulley.
__________________
Old 01-09-2009, 07:55 PM   #17
According to my mechanic it can be done, but often the compressor fly wheel easily warps from heat when it seizes. He stated it is more reliable to just spend the extra money and do right with a new clutch.
__________________
Old 01-10-2009, 03:34 AM   #18
My a/c clutch was shot too, and I just went to a local junk yard and picked mine up for 100 dollars. and it worked perfect! Maybe try calling around, you might be lucky and find one in working order.
azn_mint is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
