Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 12-16-2008, 10:18 AM   #1
my retrofit!
Hi everybody
I'd like to share the build log for my headlights.
The goal: Install HIDs in them. I could just drop 9004 HID bulbs in them and call it a day. But I wanted a proper beam pattern and no glare. I picked up a pair of projector lenses. Projectors have a "cutoff shield", which blocks light above a certain point. This is the reason that if you stand in front of a car with HIDs, it looks like the lights are dim, but if you duck and look under the shield, they're super bright.
I drive a 1997 Nissan Maxima. The stock headlights are a crappy 9004 single relector design. The beam pattern is terrible and if I'm driving through a place with streetlight, I can't even tell whether the lights are on or not. The 95-99 Maxima has two different headlights. 95-96 uses a fluted glass lenge, and 97-99 uses a clear plastic lens. I got a good deal on a pair of 95-96 headlights. I was told that the fluting on them would disrupt the beam pattern from my projectors, so I decided to install them on my car for spares, and do the retrofit on my stock 97-99 clears.
Here we see a comparison, 95-96 on bottom, 97-99 on top
So, with the fluted lights on my car, I got to work on the clears.
First thing first, I opened them up. Baked them at 250 for 10 minutes, pried them apart. Hint: It would have been a lot easier with another person helping hold them.
Next, the projectors. These are Stanley projectors, from a MDX or Camry. They're originally halogen, using a H11 bulb, rather than the D2S that a HID projector will use.
I test-fit them in the reflector bowls. Later on, I'll cut out the back of the headlights to let them sit deeper in, and allow me access to the bulbs after I seal the headlgihts back up.
__________________
*nalc
97 Maxima SE 5MT - Neptune Blue
R34 Quad Projectors - M35/MDX
nalc is offline   Reply With Quote
Old 12-16-2008, 10:18 AM   #2
The first thing to do was cover up the squirrel finders. Most halogen projectors have something called a "squirrel finder" which is a narrow flap in the cutoff shield that allows light to go above the cutoff shield. It's not usually a problem with dimmer halogen bulbs. Since I'm using HIDs, I sealed the flap closed, to prevent glare to other drivers.
The upper wide opening is the area that the light comes through. The small rectangular below it is the squirrel finder opening. Because we're shooting this through the lens, the image will be inverted, which is why the opening is on the top.
I put the bulbs in and fired them up for a trial. As you can see, I missed a tiny slit in the squirrel finder, but I later filled it in.
Now, through a bizarre sequence of events, I ended up with two projectors and one cutoff shield. So, I had to fabricate another out of aluminum sheet. I went crazy with my power drill, dremel, and a file, to get this
Updates coming soon.
__________________
*nalc
Old 12-16-2008, 10:22 AM   #3
Land Shark, Jr.
Tatanko's Avatar
Send a message via AIM to Tatanko
Good to see more retrofitted cars. Why that projector, though? You must have gotten a killer deal on those to choose them over a proper single-xenon counterpart.
__________________
SHIFT_obsession
Tatanko's Maxima Site & VQ35DE.com
Tatanko is offline   Reply With Quote
Old 12-16-2008, 10:35 AM   #4
i keep hearing people say "why halogen pojectors and not the proper projectors?", but at the same time to someone that doesnt really know much about them, like myself, they seem to perform the same, and the beams definitely look the same. so why is that? how are they different and why are halogen projectors so much worse? (just trying to learn here)
__________________
The FIRST AWD Maxima'97 Black/Black SE 5 Speed: DEK swap, K&N, Budget Y, Budget Test Pipe, Budget B, Dynomax Muffler, Exedy Clutch, Shortened shifter, Mustang GT shift knob, Smoked Red/Clears, AE'd Headlights, Yellow Fogs, Ebay FSTB, Ionic front Lip, Intrax Springs, 17in G35 Coupes.....EManage Ultimate!
MaximaSpd85 is offline   Reply With Quote
Old 12-16-2008, 10:54 AM   #5
Well, the MDX projectors are a "gem in the rough" so to speak. Do not expect results like this from most halogen projectors.
Most halogen projectors have a smaller bowl, and focus the light more towards the center. a HID projector will usually have a wider beam.
Another problem with the smaller bowl is that it could overheat easier.
Here is my MDX projector next to a H3 projector out of those ebay projector headlights
In addition, some halogen projectors have a weird cutoff. A HID projector is flat with a 'step' in the mdidle. A halogen projector often has more of a slope, which can blind drivers to your right. A halogen beam isnt as intense there, so its ok.
Cutoff comparison:
Plus, as I mentioned before, squirrel finders
But, a good halogen projector can handle HIDs. There isn't a magical aspect that a HID projector has that a halogen doesn't. If you seal up the squirrel finders, give it a good shield, and the bowl doesn't overheat, it works fine.
__________________
*nalc
Old 12-16-2008, 10:56 AM   #6
Quote:
I would like to know as well.
darklegend06 is offline   Reply With Quote
Old 12-16-2008, 11:09 AM   #7
Send a message via AIM to OOmaxSE
Will you be putting D2S's in here or h11 HID bulbs? If you're putting D2S... what kind of modifications are to be done to interchange these? Looking great so far!
__________________
OOmaxSE is offline   Reply With Quote
Old 12-16-2008, 11:13 AM   #8
Land Shark, Jr.
Tatanko's Avatar
Quote:
Everyone should keep what he said in mind when reading my comments Basically the main difference between HID projectors and halogen projectors is that HID projectors are made to have the proper optics to go with an HID capsule vs. a halogen projector. The reason halogen projectors aren't designed more like HID projectors is because they don't have as much light to spread around as HID projectors do. For example:
H3 - 1450 lumens
D2S - 3200 lumens
__________________
SHIFT_obsession
Old 12-16-2008, 11:17 AM   #9
Ok, I finished up the custom cutoff shield and painted it.
From 20 feet away, at eye level. Now, this was taken with all the lights off, in a basement. All shots are at exactly the same camera settings, unaltered.
THIS IS WHY YOU USE PROJECTORS AND DONT JUST DROP THAT ISH IN YOUR STOCK HOUSINGS
Notice that the light has about the same intensity as your 1156 reverse lights.
Now let's drop under the cutoff.
Wow. There's where all the light is hiding.
Beam pattern at 20 feet. I'm pretty impressed with my cutoff shield. $2 in sheet metal and an hour with a drill, a dremel, and a file gave me this. The beam is actually wider, but due to the weird shape of the basement, that was all that was visible. The rest was hitting another wall
Close-up of the color.
__________________
*nalc
Old 12-16-2008, 11:19 AM   #10
Quote:
H11 re-based bulbs.
Basically, to do D2S in a H11 housing is doable. You need to shave 2.8mm of material off the back, because the D2S capsule is not as far from the base as the H11 filament, so you need to let it sit further in.
This was instrumental in helping me with my retro:
http://www.cardomain.com/ride/578450
__________________
*nalc
Old 12-16-2008, 11:30 AM   #11
Somethng more then nothng
DrunkieTheBear's Avatar
Send a message via AIM to DrunkieTheBear
wow thats really nice dude.
__________________
Decision has been made...
Supercharged LSJ (not the SS)
DrunkieTheBear is offline   Reply With Quote
Old 12-16-2008, 11:54 AM   #12
Looks good so far, in for pictures of the final product!
__________________
1999 Super Black SE 5MT '00VI|VAFC-II|Fed Spec Conversion|Cattman Y|Budget B|HKS Rear Section|Stillen Hi-Flow Intake
OBX STS|18" Mille Miglia Evo 5s|Stillen FSTB|Progress RSB|Intrax Springs|KYB AGX Struts|AE Pedals+350Z Dead Pedal
Escort Passport 8500 Hardwired|Red/Clear Tails|Clear Bumper Lights|35%/25% Tint|Nismo Shift Knob|I30 Leather E-Brake+Autodim Mirror
Exedy Stage II Clutch|I30 VLSD Transmission
99BlackMaxMS is offline   Reply With Quote
Old 12-16-2008, 11:57 AM   #13
I decided to fab up some brackets.
I wanted to do JnC's method, but the housing is really cramped. I would have been much better off springing the extra money for "R34 style" housings. They look much easier to work with.
The stock adjustment brackets allow a goofy kind of diagonal rotation. I decided to make my projector brackets to allow adjustment in the opposite diagonal direction. Between the two, I should be able to adjust them properly.
So, the brackets are going to be a piece of aluminum L-channel. I liquid-nail'ed two washers on the bottom of each, and a 1/4" nut on the top of each. I'll bolt them to the bottom through the 1/4" nut, and tighten them. That will let me pan them left and right. Then, I'm going to use a 4" machine screw through the top of the projector on the opposite corner, allowing up/down tilt.
__________________
*nalc
Old 12-16-2008, 12:27 PM   #14
Send a message via AIM to ChrisMan287 Send a message via MSN to ChrisMan287 Send a message via Yahoo to ChrisMan287
Damn everything looks good. Subscribed for the final outcome.
__________________
http://www.cardomain.com/ride/3135334______http://www.cardomain.com/ride/3171620
Crackhead prices on these items:
Mint '95-'96 headlights, 2 sets of stock 9004 bulbs, 1157 red LED bulbs, mint front bumper lights, license plate lights. PM me if interested.
ChrisMan287 is offline   Reply With Quote
Old 12-16-2008, 01:33 PM   #15
Coolsaber57's Avatar
Nice man, you're going to be a pro at retros soon. Excellent job on the cutoff shield.
Good choice on putting the Pjs in the plastic housing, I took a look at my lenses earlier this week and the light would definitely be messed up going through them.
Btw, blue 4th gens ftw.
__________________
1996 Maxima GXE "My boy blue"
RSB|FSTB|Leather/Heated Seats|12"sub-Alpines-Rainbow SLCs-Audison SRx2|Spoiler|5.5 Gen 17's|Custom Red Clears|Viper 771|R34 TSX Retro|5th gen muffler|300zx Fuel filter
Quote:
Originally Posted by pmohr
Oh I'll show you a dingy. A reaaaaaaaaaaal small one.
Coolsaber57 is offline   Reply With Quote
Old 12-16-2008, 02:50 PM   #16
Send a message via AIM to kzoosho Send a message via MSN to kzoosho Send a message via Yahoo to kzoosho
Just a little tip for ya. 200 degrees for 20 mins the lens will fall off. Alot easier and you wont melt anything either
__________________
97 SE Auto stock for now
97 5sp SE New build Holset HX52 and spray. More to come.
91 GXE Auto bone stock beater
Led retro's Pm me
kzoosho is offline   Reply With Quote
Old 12-16-2008, 02:57 PM   #17
Next, I wanted to get some stuff done with my harness.
Because the stock headlight wiring is thin and runs from the fuse box to the steering column then to the headlights, the high powered HID ballasts risk melting it.
I used 10awg wire. The 9004 is switched positive hi/low. I put a diode between them so that high beams or low beams will fire up the ballast. I then connected a 6800uf cap across low beam and ground, so that if for some reason I switch to high beams, the lights won't flicker in the half second that neither has power.
Then they trigger a relay, which switches power directly from the battery to the two AMP connectors for the HID ballasts.
__________________
*nalc
Old 12-16-2008, 03:02 PM   #18
Um if you are using a single xenon why would you make a harness to run both high and low? Just wondering.
__________________
Led retro's Pm me
Old 12-16-2008, 03:40 PM   #19
Land Shark, Jr.
Tatanko's Avatar
You planning on cleaning up those lenses? I recommend wetsanding them in a sink or something while they're off the headlight.
__________________
SHIFT_obsession
Old 12-16-2008, 04:45 PM   #20
Yeah, I was going to wetsand them then hit them with a clearcoat of something. Should I dremel the little nubs off?
The harness was kinda an experiment. I wasn't sure what direction I wanted to go in. Not having high beams is kinda shaky... I may try to put some cheapo halogen bulbs inboard of the MDXs to be my highs, or possibly rewire the fogs as high beams. I was going to deal with that once I finish dealing with mounting them.
__________________
*nalc
Old 12-16-2008, 07:14 PM   #21
looks go so far, in for final pics
__________________
Car Ramrod
Don't tase me bro!
SHIFT_3.ooohhh
fat_kid is offline   Reply With Quote
Old 12-16-2008, 09:02 PM   #22
Send a message via MSN to Snypa
Very nice work....keep updating.
__________________
FOR SALE
97-99 Headlights $80 shipped obo
Snypa is offline   Reply With Quote
Old 12-16-2008, 09:47 PM   #23
Send a message via AIM to travmaximas1998
gah all the retros
i really got to get to reading up!
what was that forum just for HIDs and what not?
__________________
travmaximas1998 is offline   Reply With Quote
Old 12-16-2008, 09:52 PM   #24
www.hidplanet.com/forums
__________________
Led retro's Pm me
Old 12-17-2008, 07:45 AM   #25
The Original CF Maxima
Flava_24/7's Avatar
Im a bit confused as to where are these brackets being mounted and attached to?
__________________
Flava_24/7 is offline   Reply With Quote
Old 12-17-2008, 08:36 AM   #26
Those brackets are being 'sandwiched' in between the projector bowl and the cutoff shield. Then a bolt is going between them and the bottom of the housing.
Here is the projector mounted in the housing. The bracket is supporting the bottom, and a long machine screw is holding the top.
__________________
*nalc
Old 12-17-2008, 10:50 AM   #27
How are you going to adjust the projector's position then, if you don't use JNCs method?
__________________
Old 12-17-2008, 11:36 AM   #28
G-string Money Tight.
JNCoRacer's Avatar
Send a message via AIM to JNCoRacer
What shrouds are you going to be using?
__________________
DNE VP
www.nissans.org
JNCoRacer is offline   Reply With Quote
Old 12-17-2008, 01:10 PM   #29
Send a message via AIM to AndrewR2442
It is like JNC's mounting method. The nuts that are welded onto the bracket... are threaded. Then the large bolt... on this last picture.... is his vertical adjustment.
Right?.....
nalc, what's going into the big hole in the housing?
AndrewR2442 is offline   Reply With Quote
Old 12-17-2008, 01:41 PM   #30
it's not quite JnC's method... he uses a pair of brackets individually adjustable, I use a single one. His has rotational adjustment and up/down tilt, mine has left/right and up/down tilt. I am going to mount them up in the housings and put them on the car and do adjustments with those two bolts and with the stock aiming bolts. Hopefully I can get a decent aligment.
The hole... we'll see. Might do a pair of H3 driving lights inboard, wired as high beams.
__________________
*nalc
Old 12-17-2008, 06:43 PM   #31
KH3 by popular demand
maxgtr2000's Avatar
Send a message via Yahoo to maxgtr2000
Good job on everything, especially the shield, the cut off looks very nice.
__________________
Retrofit headlight services
My VQ30DET
Emanage Blue and Ultimate Forums
There can be no peace until you possess the Prince of Peace.
maxgtr2000 is offline   Reply With Quote
Old 12-17-2008, 08:04 PM   #32
Quote:
Hey man, I was wondering. Since you're one of the first people to do the foglight highbeams inboard of the projectors, how do you change the bulb? Every kind I've seen requires taking apart like half the housing, and I have no idea how I'm supposed to do that if it's baked in my headlight.
__________________
*nalc
Old 12-17-2008, 08:43 PM   #33
maxgtr2000's Avatar
Well, look at it this way, i've had my retrofit since 05' and we are going into 09' and haven't had to change them yet. I don't use high beams alot though either. I don't think if you have to change it out every 3-4 years would be that bad to take the headlight apart, you might not even decide to keep your maxima by the time it needs to be changed out.
Old 12-17-2008, 09:26 PM   #34
I was tossing around the idea of just mounting a pair of round driving lights on the bumper, and wiring them as the highs. like a toned down 'rally' look
I bought a pair of 1.5" pep boys foglights... and they are just kinda dumb looking. Everything they had was with a blue tinted lens, which looks ricey. I'm going to paint the inside of the housings a dark gunmetal color, and I think they'll stick out like a sore thumb.
__________________
*nalc
Old 12-17-2008, 11:31 PM   #35
Send a message via AIM to michaelsevilla
nice work there!
michaelsevilla is offline   Reply With Quote
Old 12-18-2008, 11:02 AM   #36
Well, I put the driver side one on the car to test, got it all wired up, then realized that my ring terminals on the harness are too small.
Time to go to the hardware store and pick up some decent connectors.
__________________
*nalc
Old 12-18-2008, 06:14 PM   #37
i can't even count how many annoying mistakes i've run into with my retro
Old 12-18-2008, 08:28 PM   #38
I got the right terminals. then couldn't get the positive one threaded because it hit the clamp funny. So I had to put it on with a M6 nut.
then, it didn't work.
I tried everything until I realized that the fuse was blown. Replaced it and everything lit up fine, until the cap started smoking. Cut out the cap and now everything's dandy.
I'm going to work on shrouds now, and work on cutting the other side housing.
__________________
*nalc
Old 12-18-2008, 08:39 PM   #39
I painted the housing first, and remounted them in the aiming brackets (which I had to dremel a little bit)
Then, I mounted the projector and temporarily taped the cover on. I hit this with Meguiar's PlastX, and it cleared it up. I'm going to do another coat soon. I don't want to sand if I don't have to.
Here's the projector installed
Then, I worked on the harness. I had to replace my old terminal connectors with new ones that actually fit.
Here's the cutoff! Don't mind the height, it was on a sloped driveway. I was just glad that it was parallel to the ground and that it was pretty much straight ahead. Hopefully I won't have to do a ton of adjustments. Don't mind the odd green color, it was taken on an overcast day against a stained and patched garage wall.
__________________
*nalc
Old 12-18-2008, 08:46 PM   #40
The Dirty Pearl
pmohr's Avatar
Send a message via AIM to pmohr
FWIW, your front valve cover is leaking, battery terminals and tie down are corroded to hell, and your FSTB is missing
__________________
ALL 4TH GENS ARE OBD-II
Quote:
Originally Posted by 2damax View Post
This jerk is right so often I just search threads hoping he gets something wrong so I can catch him
FSMs | A32 CEL Decoder
pmohr is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
