Climate control?
Climate control?
Awhile back I noticed the climate control doesnt work right at all. Like it doesnt work at 1, 2, 3, but it only works at 4. I figured it may have shorted somewhere on in the climate control fan control, hopefully that is the problem. How do I check, I dont want to simply ruin it, bend something, or even accidentally pull a wire, and cant fix it.
Does anybody have a sulotion, buy that one part, or fix it myself. I would rather try to fix it myself, but I dont know how to pull the thing out. I managed to pull my burnt clock out. I would really hate to buy a hole new climate control thing, because mine is in such good condition, and to have another one that may have acratches on it is not happening in my car.
Any suggestions??
Any suggestions??
no ,because what the "relay" or resistor does is directs different amounts of voltage (less for slower and more for higher fan speeds) . It only works on 4 because at that speed it uses full system voltage, it sorta bypasses the resistor (relay).
No, one is cheaper than the other. They sound like the same thing, but I need to know if indeed they really are the same thing, they plug into the same spot, they look the same.
Is this what I need? http://www.autopartsworld.com/Part.a...ling-fan-relay
Pretty sure its this one. http://www.autopartsworld.com/1995_n...tor_parts.html
I'll get a mechanic to look at it, because to me, thats alot of money just to spend on how the air conditioner(or in my case, heater, because I havent got a condencer in my car, yet). I'm going to the shop tomarrow to get a vaccum leak check.
Edit: If I do so happen to look at it myself, is there away to tell if its bad or not? What would it look like?
also the difference in the two different parts is one is for AUTO climate control and the other is for manual climate control. sorry I dont have time to read all the way to see if you have mentioned what it is.
also ...do it your self ! save some money.its easy and takes like 5 mins.
but if not ,your mechanic really shouldnt cahrge very much at all...if anything.
hope that helps
It is a 5 minute job, did mine several months back
There is a resistor assembly mounted on the air duct close to the blower motor. That part has failed. It is used to control fan speeds 1, 2, and 3. Speed 4 is the maximum blower motor speed, so no resistors are involved. Replacing the resistor assembly is something the home mechanic can do. The only tool needed is a Phillips screwdriver. The replacement part costs about US$25.
The blower motor is located just above the passenger's feet. Look at the wires leading away from the blower motor. Just inches away from the blower motor there is an electrical connector located on the air duct. That's the resistor assembly. It is easy to remove and replace.
Replacement is the usual remedy. However, if a spot of localized damage is seen it may be repaired with a soldering gun.
There is a good photo of the blower motor and resistor assembly in the Haynes repair manual, page 3-8. If you don't already have a copy of this book, please get one. It will be money well spent.
a) Move the front pass seat all the way back (for convenience)
b) Remove a harness connector (with 4 wires I think) running into the bottom of the blower motor.
c) Remove the 2 philips screws that hold the blower motor resistor in place.
d) Put new one in, reverse install.
Blower Motor Resistor Part Number: 27150-1E405
You can get it here:
http://www.nissanparts.cc/cart/?pn=27150-1E405
Should be $28 at your local dealer. It's $28 delivered from discount Nissan parts sites.
Edit: If you are handy with a soldering iron, you can try to fix it yourself. See this thread.
stickies ftw
Hey, "fat kid", is that what I should get? Thats a really cheap price!!! I knew I seen it somewhere when I was looking through the stickies, but when I just looked through them, I couldnt find it.
mine from the dealership in town was $22-23 i think. if you go to the dealership and tell them you need the blower resister they will know what you are talking about. this is a pretty common problem with nissans and infinitis. they tried to sell me a new blower too but you dont need it fyi
So I need this part ????? http://www.nissanparts.cc/cart/?pn=27150-1E405
Sorry for the double post, but I need to know this now. I'm fixing to replace it tonight, and I cannot find out how to find the part I need to replce, and replace it. I looked on the net, and in my Maxima book.
Other than the resistor being in a tight spot (I think I laid backwards and upside down on the passenger side seat to get my head under the dash to see what I was doing), it's one of the easiest things to change on our Maximas. As someone here already said, 5 minutes tops, once you find where it is.
I dont know what FSM it is, like theres so many different letters, I dont understand them all, the only one I understand is fwd.
Edit, Thanks nafddur, I know its under the glove box, but like right or left. I'll figure it out, its very dark out, its really foggy, I have to look up-side down to find it (I dont know where to look for it), and to top it all off, my next door neighbor keeps there stupid *** barking dogs outside, all the time. Bark Bark Bark....
Well, I fixed it. I didnt know it would be out in the open like that. I figured it would be hidden somewhere, but I guess not. It works perfectly now, now alls I need is a condencor.
Thanks to all that helped me out!!!!
tarun900
19
12-20-2021 06:57 PM
tseng1023
10-15-2015 08:30 AM
RealityCheck
10-02-2015 06:34 PM
DC_Juggernaut
09-28-2015 04:07 PM
