Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 12-13-2008, 07:30 PM   #1
Brake pad wear indicator - which side?
Hello,
I'm trying to do my first brake job (front), and I have a question which might seem silly, but I haven't been able to find a definitive answer.
My new pads only have one wear indicator for each side (at least that's what I'm assuming the little plate of metal to be).
1. Does the pad with the indicator go on the inside or outside of the rotor?
2. Does the indicator go toward the front (meaning a given spot on the rotor would meet it after passing the pad when driving forward) or toward the back (rotor would meet it first, then the pad)?
For the record, they're currently on the outside toward the back. But they were last changed at a body shop following an accident, and based on the rest of the hack job they've done, I can't trust that they've done it correctly.
I don't think it'll make any difference, but the rotors and calipers are being changed out as well.
Thanks.
__________________
99 auto GXE
donut is offline   Reply With Quote
Old 12-13-2008, 07:41 PM   #2
The Dirty Pearl
pmohr's Avatar
Points: 22,165, Level: 92
Points: 22,165, Level: 92 Points: 22,165, Level: 92 Points: 22,165, Level: 92
Activity: 2.5%
Activity: 2.5% Activity: 2.5% Activity: 2.5%
Stock they're inboard and up, but it really doesn't matter:
Click the image to open in full size.
__________________
A32 CEL Decoder | FSMs | Howto Videos
pmohr is offline   Reply With Quote
Old 12-13-2008, 07:42 PM   #3
KRRZ350's Avatar
Points: 15,958, Level: 81
Points: 15,958, Level: 81 Points: 15,958, Level: 81 Points: 15,958, Level: 81
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Send a message via AIM to KRRZ350
I've always put them on the outside, but it doesn't matter.
__________________
Maximaparts@hotmail.com
KRRZ350 is offline   Reply With Quote
Old 12-13-2008, 07:50 PM   #4
Thanks a lot for the quick replies. It's very helpful.
__________________
99 auto GXE
Old 12-13-2008, 10:01 PM   #5
ThurzNite's Avatar
Points: 26,245, Level: 96
Points: 26,245, Level: 96 Points: 26,245, Level: 96 Points: 26,245, Level: 96
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Send a message via ICQ to ThurzNite Send a message via AIM to ThurzNite Send a message via MSN to ThurzNite Send a message via Yahoo to ThurzNite
Personally, I'm an 'inny', as opposed to an outty. My reasoning is because, if your slide pins are stuck and don't slide, that warning tab will continuously scrape the rotor after you let go of the brake pedal, scoring the rotor.
The warning tab is supposed to touch the rotor only when you're braking.
Dr J
__________________
Show your support! Custom MAXIMA.ORG lanyards Link
ThurzNite is offline   Reply With Quote
Old 12-15-2008, 10:00 AM   #6
Points: 34,868, Level: 100
Points: 34,868, Level: 100 Points: 34,868, Level: 100 Points: 34,868, Level: 100
Activity: 27.9%
Activity: 27.9% Activity: 27.9% Activity: 27.9%
Send a message via AIM to njmaxseltd
I always put them on the inside against the piston. If the caliper gets sticky the inner pad will wear faster, and usually always does (slightly) anyhow.
njmaxseltd is offline   Reply With Quote
Old 12-15-2008, 07:15 PM   #7
TunerMaxima3000's Avatar
Points: 17,683, Level: 84
Points: 17,683, Level: 84 Points: 17,683, Level: 84 Points: 17,683, Level: 84
Activity: 0.8%
I also put them on the inside, as said, the the slider pins are sticky, not only will it scrape, but the inboard pad will wear much much faster, and you won't know that your pads are down until they're scoring the crap out of the rotor.
__________________
'03.5 6MT G35:
460 BHP Sedan
Official Canadian retailer for THERETROFITSOURCE.COM Contact me for discounts and Retrofit services.
V35Glycerin@Hotmail.com
TunerMaxima3000 is offline   Reply With Quote
Old 12-16-2008, 09:27 AM   #8
ThurzNite's Avatar
Activity: 0.8%
Quote:
I rotate tires every oil change, 3000 miles... I'm always inspecting the pads while the wheel's out... also inspecting suspension and what-not down there. If there's 1mm of brake pad left, it's prob a good time to start looking for new pads. Then next oil change, the new pads go in. I really don't like scoring rotors, esp expensive high performance rotors.
Dr J
__________________
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
